Two thing you need to check:
1. Are you replaced genuine carriage belt?.. Original belt having two type of inner tracks.. Right side horizontal & left side vertical tracks. Are you fixed it properly or not..
2. Check carriage assembly play.If it is over play(carriage bushes may be warn out) alignment won't complete, If bushes are available in your country replace them & do the calibration..If not go down how to alter bush. see the snap shot
3. While carriage movement pl check trailing cable flexibility.
Carriage Bush:
Note:This modification only professional not for users:
Un screw screws both sides as shown in fig, take out bushes estimate how much warn out happened.
Thing needed:
Fevi quik(glue),small peace of miler sheet,scissor & tweezers.
Cut miler sheet in to small peace & insert warn out place of bush(between bush & rail) & apply glue, fix it permanently,do it both sides & check for the carriage play.. once its finished try for alignment.. For this activity no need to remove carriage assembly from the rail. Main aim is alter bush warn out..
SOURCE: Replacement carriage belt for HP DesignJet 800
The part number is; C7769-60182 runs at around $70.00.
This component needs to be installed by a service technician. You can seriously damage this plotter if you remove the carriage ribbon connectors and do not install them properly. You will fry the pca board (a $1,100 mistake).
SOURCE: Replacement carriage belt for HP DesignJet 800 Printer
It is not recommended that the user replace the carriage belt, on any HP printer. Any damage caused by the user, won't be covered by the warranty and will likely result in a completely useless, but very expensive doorstop. Or paperweight..
I do believe your printer has since been discontinued for support, however only an HP Customer Service Representative would be able to confirm that. I would suggest phoning HP for technical support or to at least confirm whether support is available.
Even if your printer is no longer a) under warranty, which I suspect it's not, or b) out of support completely, they may be able to provide you with a list of Authorized Service Providers (ASPs) within your area.
1-800-474-6836
Best Of Luck.
SOURCE: replace HP designjet carriage 5000 belt
you need some skill and expertise, if you have, download the service manual
http://www.eserviceinfo.com/equipment_mfg/HP_22.html
SOURCE: need instructions to replace carriage belt for hp
When you order the belt from hp it will come with the instructions, if not email me and I will send it to you.
