Had trouble with sink drain at time & water back flowed into dishwasher since then pump won't stop & F2 is displayed.
There is water in the lower pan that you must access by removing the toe kick plate and then the panel behind it. you will see water in the overflow area. Clean that out and all will be well. Asko's are awesome dishwashers that capture any water they may overflow or leak internally instead of it going on your floor, then a float switch triggers the F2 error and runs the drain pump.
SOURCE: f2 code flashing
Have you tried to reset the dishwasher to clear out the error code? Toreset, you hold down the "Start/Stop" button (or "Wash Program" buttonon units that don't have the "Start/Stop" button) for 3 to 5 seconds.This should clear the code. Try running a cycle to see if the problemreturns. If it does, you can, if you are completely comfortable withyour mechanical abilities, remove the toe kick plate, the access panel,the "T"-shaped kick bracket and the galvanized guard plate to see ifthere is water in the basepan. I would only remove these panels if I was POSITIVELY comfortablewith doing it. * To remove the screws, you'll need a 20 TORXscrewdriver. If water is present in the base pan, vacuum with a wet/dryvacuum or soak up with a towel or sponge. Run a cycle and inspect forleaks. If the problem continues, contact a local service center: Toll-free @ 1-800-898-1879. Hope this helps...
SOURCE: Asko D3350 code F7
Service manual says:
LED L1+L2/Fault code F7, Pumping out fault
(machines with pressure sensor)
Water not evacuated after 120 seconds’ pumping
out. Programme interrupted.
Check: Drain pump, hoses, installation of drain
hose, control unit and wiring.
SOURCE: F2 error message flashes, cannot reset.
Try to find out from where water leaking from (pump or inlet valve). The leaking one, should be replaced. Good luck !
SOURCE: Faulty Asko dishwasher
We were told by an ASKO technician that it has something to do with a balance issue. You could try tilting the machine forward (make sure you've removed side screws into walls first though otherwise you could damage the cupboards).
SOURCE: Asko D3230 dishwasher pump will not turn off, with main switch on
This is a anti flood activation. It is a safety device (polystireen float and micro switch at the base of the washer) that keeps the drain motor running due to water leak / spill detection. Dry the water and rectify the leak (normaly pipe or clamp leak) and this should solve the problem.
Hi
Dishwasher not draining issue usually occurs due
to kinked drain pipe, clogged drain filter or drain pump. First make sure that
the drain is not clogged and remove clogs if present. If no visible lint is
present then remove the lower front access panel to check the drain filter and
drain pump for any clogs, you'll need to clean the drain filter and drain pump
completely. Also, check for any food pieces stuck near the pump impeller &
clean the chopper assembly. Please note that dishwashers don't drain out the
complete water such that heating element doesn't overheat. Hope this helps...
Please post back for any further assistance.
Daniel
