How can I change it? got as far as default gateway 19.168.0.1.
That's depends...First, do you have the password to log into the modem? it seems that the default is
admin/motorola. If that hasn't been changed, you could log in and
remove the WEP key.
In addition, most modems and routers will reset to factory defaults if you press and
hold in the reset button for around 30 seconds with the device turned
on. Forgetting the password is a common problem. Don't be worry...Or if these all can not work, you can call or ask directly to the customer service of Most modems and routers will reset to factory defaults if you press and
on. Forgetting the password is a common problem. Don't worry... or if the above ones all didn't work, you can call or ask the Motorola customer service directly, maybe they know the solutions because they produce it!
SOURCE: What is the default user name and password to login the Prestige via the browser?
To restrict only the adminstrator can configure the router, there is a login procedure prompted for asking User Name and Password. The default User Name is 'admin' and the default password is the default SMT password, '1234'.
SOURCE: how to change router default name and password
you can't change the default name...that is always left blank, but you can change the password.
Access the user interface & click on Administration. It should automatically be in the Management section at this point.
Enter your desired password in the Router Password field.
Re-enter to confirm the password in the next field.
Click on Save Settings.
For more information on working with your router, you can access the User Guide provided by LinkSys:
http://www.linksys.com/servlet/Satellite?c=L_CASupport_C2&childpagename=US%2FLayout&pagename=Linksys%2FCommon%2FVisitorWrapper&cid=1166859837401&displaypage=download
SOURCE: user name and password
After trying for a long time i decided to call customer support, they informed me there is no default user name, the only option you have is to reset the router by pressing the reset button for at least a minute than when you go into the configuration ip address you will be prompted to enter a new user name and password
SOURCE: what is the default user name and password for
By default both the username and password are admin.
Good luck and if you have any more questions, just come back here and leave a comment - I'm happy to help.
