Question about Ricoh Aficio 2027 All-In-One Laser Printer
Pasword on photocopy
I want to set password in my photocopy machine so that no one can copy in my absence
Posted by afzal shaheen on
General Systems Consulting
    Top Expert:
  • 5,051 Answers
Read the manual.
Get online and got to www.google.com In the google search box type: "Ricoh Support" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operating system when requested. Look for Manual.
Posted on May 31, 2012
How do i connect Konica Minolta photocopy Biz211 to a computer for network printing?
First of all, make sure that there is network interface card is installed in your photocopier.
If yes, then connect the network cable to the machine.
Then from the control panel of machine, Go to "Administrator Mode" Administrator Setting.
Press--Utility---then select "Admin Setting"
Now enter Admin Password=000000, press "OK"
Now go to "Network Settings" and Assign the IP address to the machine.
After assigning the IP address, install the relevant printer driver, (compatible with your operating system) You can also download the drivers from the internet.
During the installation of drivers, select "TCP/IP Port" This port is used for network printing.Enter the IP address of Photocopier in this port number.
After finishing the installation, your machine is ready for printing.
If you are still facing difficulty at any point, feel free to ask any time.
Jul 01, 2015 | Konica Minolta bizhub Office Equipment &...
Toshiba estudio 255 Cannot usefunctions
you must connect the machine with you're computer.you want the fax you must check the you're photocopy machine have a fax board.you want the scan & printing connect the photocopy machine to the computer.(network cable)
Jan 27, 2014 | Toshiba estudio 255 Copier
How can i unlock my samsung gravity t- steel i forgot my password
go TO THE SERVICE CENTRE AND DONT TELL U HVE FORGOT THE PASWORD TELL THEM THAT TIERE IS A SOFT WARE PROBLEM IN UR DEVICE THEY WIL UPDATE UR SOFTWARE AND PIN CODE WIL AUTOMATICALY REMOVED.. AND DONT FORDET PHOTOCOPY OF UR BIL. DERE. . AND VOTE MY ANSWER
Feb 10, 2011 | Cell Phones
Toshiba estudio 160 Password
Code 08- 263 does not work with the e160
And I cannot find anywhere in the service manual where it specifies how to read it...
Nov 09, 2009 | Toshiba Office Equipment & Supplies
Copy limit
the only way is to goto additional functions > System Settings> dept I.D > set a user code and password, then you can set a copy limit per user id, once a copy limit is reached you have to reset it or create a new user I.D. Thats the only way, you can also get reports on how many copies each I.D has done..
Hope this helps
May 16, 2008 | Canon imageRUNNER 3300 All-In-One Laser...
Pasword reset
This answer is for the Toshiba eStudio 45
hi,
im not 100% sure what you need help with so if you want to delete all the department codes on your copier but you do not know any of the current codes or the master code and need to change the master code follow these steps:
  • turn the copier off
  • while holding down 0 & 8 turn on.
  • key in 672 press start
  • press [INITIALIZE] (you might have to hit start if nothing happens i cannot remember)
  • this could take a min then you need to turn the copier off and back on.
  • you department codes should be cleared.
please let me know if i have helped or if i have not answered you question.
Apr 28, 2008 | Kyocera RI-4530 Black and White Copier
Ricoh Aficio 2027 All-In-One Laser Printer Logo
61 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Ekse
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
