Question about Simplex Locks & Locksmithing
Need a diagram to repair a model A1022 Simplex jack
Just received parts from simplex and need a break down diagram of the jack
5 Related Answers
Anonymous
SOURCE: Bought house from bank and trying to retrive lock combination
I'm trying to remove a unican lock from my door but I can't see how to get the handle off. any suggestions?
Posted on Aug 22, 2009
Anonymous
SOURCE: how to change the combination of a Simplex pushbutton lock
Your screwed.
Posted on Mar 18, 2010
Coaltowner
  • 963 Answers
SOURCE: I have a Simplex Kaba
I believe you can find this to be relevant:
I found this instruction elsewhere on this site ( thanks to pctuneup191):
PROCEDURES TO CHANGE THE COMBINATION OF
SIMPLEX 1000 SERIES CIPHER LOCKS
1.) ENSURE THE DOOR IS OPEN.
2.) INSERT THE DF-59 CONTROL KEY INTO THE COMBINATION CHANGE PLUG ASSEMBLY (ON THE BACK OF THE DOOR) AND UNSCREW THE CYLINDER BY TURNING THE KEY COUNTERCLOCKWISE.
3.) TAKE THE CHANGE PLUG ASSEMBLY COMPLETELY OUT OF THE DOOR.
4.) TURN THE OUTSIDE DOOR KNOB CLOCKWISE ALL THE WAY UNTIL IT STOPS, THEN RELEASE THE KNOB.
5.) PRESS IN THE EXISTING COMBINATION FIRMLY.
6.) INSERT THE SPANNER WRENCH IN THE COMBINATION CHANGE SLEEVE. IT SHOULD INSERT AT THE NINE O'CLOCK POSITION.
7.) TURN THE SPANNER WRENCH GENTLY CLOCKWISE UNTIL IT STOPS AT THE 12 O'CLOCK POSITION. NOTE THE NOTCHES IN THE COMBINATION CHANGE SLEEVE MOVES AS THE SLEEVE IS MOVED.
8.) TURN THE SPANNER WRENCH COUNTERCLOCKWISE BACK TO THE NINE O'CLOCK POSITION UNTIL IT STOPS. REMOVE THE SPANNER WRENCH.
9.) TURN THE OUTSIDE DOOR KNOB CLOCKWISE (ALL THE WAY, UNTIL IT STOPS), THEN RELEASE.
10.) INSERT THE NEW COMBINATION BY PRESSING IN THE BUTTONS. USE AT LEAST three numbers and a maximum of five.
11.) TURN THE DOOR KNOB CLOCKWISE ONCE, ALL THE WAY, UNTIL IT STOPS. HOLD IN THIS POSITION AND CHECK IF THE LATCH IS RETRACTED.
12.) RELEASE THE DOOR KNOB.
13.) TURN THE DOOR KNOB CLOCKWISE ONE MORE TIME TO THE STOP POSITION. AT THIS POINT, THE LATCH SHOULD NOT RETRACT UNLESS YOU USE THE NEW COMBINATION.
14.) REINSERT THE CYLINDER INTO THE BACK OF THE DOOR BY SCREWING IT IN CLOCKWISE WITH THE DF-59 CONTROL KEY (DO NOT OVERTIGHTEN!)
REMOVE THE KEY.
A Df-59 key can be purchased at this site:
http://absupply.net/kaba-access-control-lock-1000-series-key-df59.aspx
The spanner wrench (SMPBC201278 Simplex:SpannerWrench $9.00) referred to can be purchased from this site:
http://www.ckilock.com/Mpage18.asp
Here is the "literature grid" from the KABA website, which has manuals and parts lists for the Simplex mechanical pushbutton locks:
http://www.kaba-ilco.com/access_control/literature/literature_grid_mechanical_pushbutton_locks.aspx?id=13
Here's the website to continue your search:
http://www.kaba-ilco.com/access_control/products/eplex.aspx?id=6
Good Luck!
Posted on Mar 06, 2011
Coaltowner
  • 963 Answers
SOURCE: I NEED TO RESET THE
O'CLOCK POSITION.
maximum of five.
REMOVE THE KEY.
this site:
aspx?id=13
Good Luck!
Coaltowner
  • 963 Answers
SOURCE: comment faire pour changer la
English to French translationJ'ai trouv? cette instruction ailleurs sur ce site (merci ? pctuneup191):
PROC?DURES POUR CHANGER LA COMBINAISON DE S?RIE CIPHER SIMPLEX 1000 SERRURES
1.) ASSURER LA PORTE EST OUVERTE.
2.) Introduire la cl? CONTROL DF-59 ? l'Assembl?e de changement de combinaison (SUR LE DOS DE LA
PORTE) et d?visser le cylindre en tournant le CLE.
3.) Consid?rer que l'Assembl?e PLUG changer compl?tement hors de la porte.
4.) Tournez le bouton PORTE EN DEHORS dans le sens horaire jusqu'? ce qu'il s'arr?te, puis la rel?cher.
5.) PRESSE DANS L'actuelle combinaison FERMEMENT.
6.) Ins?rer la cl? de b?tons dans les roues MANCHON changement de combinaison. IL YA INSERT sur les neuf
Heures.
7.) Tourner la cl? CLE DOUCEMENT montre jusqu'? ce qu'il s'arr?te ? la position 12 heures. NOTE
Les encoches de combos LA MANCHE CHANGEMENT QUE le manchon est d?plac?.
8.) Tourner la cl? CLE ANTIHORAIRE RETOUR ? la position neuf heures jusqu'? ce qu'il s'arr?te.
Retirer la cl? CLE.
9.) Tournez le BOUTON DE PORTE EN DEHORS (tout le chemin, jusqu'? ce qu'il s'arr?te), puis rel?chez.
10.) Taper la combinaison en appuyant sur les boutons. Utilisez au moins trois chiffres et un
maximale de cinq ans.
11.) Tournez le bouton PORTE MONTRE UNE FOIS, tout le chemin, jusqu'? ce qu'il s'arr?te. HOLD dans cette position et
VERIFIER SI LE p?ne est r?tract?.
12.) COMMUNIQU? la poign?e de porte.
13.) Tournez le bouton PORTE DROITE One More Time ? la position STOP. ? ce stade, LE LOQUET
Doit pas se r?tracter sauf si vous utilisez la nouvelle combinaison.
14.) REINSERT la bouteille dans le dos de la porte en la vissant dans une montre avec la DF-59
KEY CONTROL (NE PAS TROP!)
Retirer la cl?.
Un Df-59 cl?s peuvent ?tre achet?es sur ce site:
La cl? de serrage (SMPBC201278 Simplex: SpannerWrench 9,00 $) vis?s peuvent ?tre achet?s sur ce site:
Vous trouverez un lien pour t?l?charger le manuel de votre mod?le sur cette page:
Ce sont des fichiers PDF, n?cessitant Adobe Reader pour ouvrir. Il ya un lien sur la m?me page pour t?l?charger Adobe Reader.
Service ? la client?le peut ?tre contact? directement depuis ce lien:
http://www.kaba-ilco.com/access_control/support_contacts/service_and_support.aspx
Assistance technique ? partir de ce lien:
http://www.kaba-ilco.com/access_control/support_contacts/technical_support.aspx
Bonne chance!
2350 manual simplex
If this is for a pa/ bell system for simplex grinnell I would contact them for service as that particular system is a proprietary system that only simplex authorized personnel can work on.
Sep 08, 2014 | Radio Communications
Lost the df-59 key and need to change the combination
For $9 you can get the df-59 key and spanner wrench from this company:
http://www.ckilock.com/Mpage18.asp ,10th item down on page
C.K.I. Wholesale Lock Supply 1-800-445-5230
Their item number SMPBC201278
Hope this helps!
Feb 22, 2012 | Simplex Kaba Ilco Unican 1000 keyless...
How do I change the handles from right to left?
If you don't have the print instructions for your lock, go to this web page:
On the grid, go across from L1000 to the "Manuals" column & click on PDF, which will download the file of the manual for your lock.
If you cannot open the file to view it, you need to install Adobe Reader first. You can get the download (free) from here:
http://get.adobe.com/reader/
Now you should have the manual for reference.
Someone else who was wanting to change the handle sent me this information:
"I've got a Simplex L1000 series combination that needs the Outside Lever Assembly-Right Hand and Outside Sleeve Assembly changed on it. I have the parts needed but I can't figure out how to remove the Outside Lever from the Front Lock Housing.
I had the original question. For others viewing and needing the answer it's as follows: After looking and removing the internal parts I still couldn't find the solution, so I ended up sending it to a locksmith to replace the parts. They told me later that ALL internal parts from the Front Lock Housing needed to be removed, then rotate outside lever 180 degrees. Using spanner wrench depress the front knob retainer, then outside lever should slide off. Remove Drive Assemply and Front knob retainer from rear of front lock housing. *The key was rotating the lever 180 degrees. Nowhere in the directions was this mentioned nor was it mentioned in the email reply I received from Simplex.. So for all you out there, Good Luck! And make sure to add this key step to your directions."
As you will find in the manual, you need a special spanner wrench for this operation.
Aug 11, 2011 | Simplex Kaba Ilco Unican L1000 keyless...
Where to go for repair to a simplex series 1000 lock
Any locksmith worth his salt can repair one of these locks.
Dec 25, 2010 | Simplex Kaba Ilco Unican 1000 keyless...
I have forgotten the code for my code lock which is on my bedroom door.
aspx?id=13
You'll need Adobe Reader installed, as these are PDF files. The manuals show installation and reprogramming instructions.
You can also research other models of locks from this page.
Dec 09, 2010 | Simplex Kaba Ilco Unican 1011 keyless...
Is there a repair manual available for the Simplex 1000 series locks.
aspx?id=13
Good Luck!
Nov 17, 2010 | Simplex Kaba Ilco Unican 1000 keyless...
Hi, i have an older set of uniden radios that i no longer have the manual for. one of them is stuck on a setting where i can transmit, but can't receive. anybody know how to change this? i'm not sure how...
if i've ever had this prob its because one radio is on "duplex" mode and other is on "simplex", if you know what i'm talking about this info is prob useless, but on most hand held radios there's a button that says d/s, dup/sim or just dup or sim, press or hold to change from simplex to duplex , probably see it on display, but anyway have em both set on same setting either simplex or duplex
Aug 12, 2009 | Uniden 7 Mile two-way Radio
Intimus simplex SE
Call the mfg, Schleichner, 919-775-7318. They'll give you the name and number of your local distributor for parts. The part number for the big white gear with the large holding pin is: M-76954.
May 27, 2008 | Intimus Simplex se Shredder
Locks & Locksmithing Logo
125 people viewed this question
Top Simplex Locks & Locksmithing Experts
JonSnell Electronic
JonSnell Electronic
Chris Walker
Chris Walker
Are you a Simplex Lock and Locksmithing Expert? Answer questions, earn points and help others
