Question about Carrier Beverage-Air CRG74-1 Commercial Refrigerator
Evaporator fan motor bad?
IT makes lots of noise first close door then noise fades away after few minutes. Is motor going bad? I have Beverage air CRG74-1
Posted by Scott on
binay biswas
    Master:
  • 407 Answers
Open Evaporator fan & clean.
Posted on May 30, 2012
My whirlpool sixth sense fridge freezer is reading F01% (fridge side) the motor seems to be overworking(making noise) but doesn't;t do so when fridge door is open. The freezer seems to be fine and...
the motor is suppose to stop when the door opens and turns on when closing the noise could be ice building up and the fun blade rubbing the ice if unit is empty you should leave the unit disconnected so ice melts and noise will go away when reconnecting if no motor replacement is needed.
Dec 26, 2014 | Whirlpool Refrigerators
How do I fix a noisy fan blade. Can't figure out what it is hitting. The noise doesn't happen till fridge is on for few minutes.
oight be caused by build up of ice or unbalanced/worn fan, try defrosting it. if you still have problem have the fan checked out
Jun 02, 2011 | Beverage-Air Beverage Air MT12 12 Cu. Ft....
When i accelerate up a hill i smell a foul odor like rotten eggs. then my car sounds like a straining noise i believe its my transmission going bad and a sound from the rear leaving me to believe that its...
no the rotten egg smell is the catalytac convertor stopping up. smelled it many times not to know.it will slow or even make your engine die because the motor has to have air to run! as the engine operates the valves are opening and closing and sucks air from the rear through the exhaust,or if not when you go through a whole lot of water while driving how come the engine dies? because it sucks water in through the exhaust pipe up to the motor. have your convertor replaced and that crazy stuff will go away. thank you for choosing fixya,com
Jan 15, 2011 | 2003 Jeep Liberty
I have a Frigidaire Beverage Center Model FFBC46F5LS It was installed on Friday and worked fine until today (Sunday) where it has started to beep constantly. If I press the light button at the bottom of...
I recently purchased a Frigidaire Beverage Center and had the same constant beeping issue as strivieri. I found my problem to be the door sensor. The door sensor is located on the lower bottom right of the unit and there is a metal plate mounted on the swinging door that is suppose to push that sensor in when the door is closed. However, this was poorly designed as it fails to do its task. I had a few adhesive floor protectors laying around that I used to stick to that metal plate that gave it the extra thickness needed to push in the door sensor when closing the door.
I hope this helps anyone else there having the same issue.
Nov 14, 2010 | Frigidaire FFBC46F5LS
Fan in top of the refrigerator is making a high pitched whine when running
The high pitched noise is likely a bearing on the fan motor going out. You should replace the motor soon as it may fail completely.
Oct 18, 2010 | Beverage-Air Beverage Air KR48-IAS 44.9...
Beverage air ucr27 was working fine when plugged in and checked one day, then few days later went to plug in to use, and it produced heat-unplugged, left for day or two, plugged in again, not making heat...
I would first check to see of the condenser fan is working and the condenser is clean. Some noisy compressor could be bad but I'd check make some checks first. Let me know if we need to go any further.
Oct 03, 2010 | Beverage-Air UCR27 Refrigerator
MOTOR NOISE AFTER ICE CUBES DROP - LASTS 2 OR SO MIN UTES The noice is not always the same - sometimes steady hum as if small plane is going over - lasts a few minutes. Sometimes noise is loud for a...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Sep 07, 2010 | Amana DRS2660B Side by Side Refrigerator
Central air condtioner making beeping noise!
it means it has a fault. try resetting unit by switching circuit breaker off and on it might go away
Jun 04, 2009 | Amana ACD106R Wall/Window Air Conditioner
LG LRFC25750 Refrigerator French Door
Freezer section evaporator fan motor bearing are going out. This would be indicted by a high pitched squealing noise. Have the fan motor replaced and it should solve your problem.
Jul 31, 2008 | LG LRFC25750 Refrigerator French Door
Strange Noise - Creaking
I had the same problem. My fridge would make a creaking sound as soon as the freezer was closed. I took 10 minutes to trouble shoot the problem and pinpointed that it was coming from the icemaker. After wondering if I was going to have to replace it, I noticed a piece of ice wedged in a way so that the ice maker arms could not fall into the basin to make ice. The sound was the motor creaking because of the jam. Removed the ice and the sound went away. Now, I'm sure the motor will **** out in a few months since it has been jammed for 2 weeks burning up the motor. Oh well. Hope this helps.
May 01, 2008 | Kenmore 73503 Stainless Steel Bottom...
Carrier Beverage-Air CRG74-1 Commercial Refrigerator Logo
216 people viewed this question
Top Carrier Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Dennis
Are you a Carrier Refrigerator Expert? Answer questions, earn points and help others
