Question about Panasonic Televison & Video
Clock wont set on Panasonic DMR-EZ48V
When i go to record my shows the display shows clock not set. Press Ok to change but no response. can i reset the machine.? thanks RR
Posted by Ron Rothe on
binay biswas
    Master:
  • 407 Answers
Set time & date.try change memory ic or" repogram for reset the machine.
Posted on May 30, 2012
5 Related Answers
Anonymous
SOURCE: Set Clock Greyed out
I have the same problem - clock set is grayed out. Called Panasonic tech support .. this is the solution I was given. It works, but too bad the root problem can't be fixed (bug ridden unit).
Solution is to "reset" the unit - then go back into the menu system and set the clock. How to reset the unit (don't worry - anything on the HD stays intact):
1) go to DVD mode
2) remove any DVD in player & close tray
3) on front panel, behind door - press & hold BOTH channel up & down keys for 5-10 secdons -- until you see a message that the system is rebooting
4) wait till it reboots, go back in the menu and set the time.
-Craig
Posted on Dec 19, 2007
Anonymous
SOURCE: Panasonic DVD Recorder DMR EX95VEBS remote control only displays DVD3 how can I reset this to get back to proper functions?
Dear FixYa
Thank you for your support. I have solved the problem on my DVD Recorder by reading other peoples solutions to this problem. My DVD display was showing DVD3 and all buttons would not work. So on the handset I pressed the ENTER/OK button and no. 3 button together for a few seconds, this cleared DVD3. I was so pleased that this worked. croneruk, 6/10/2008
Posted on Oct 06, 2008
nandosnut
Mike C
  • 112 Answers
SOURCE: panasonic dmr-e55 won't work, just says "hold" on display
HOLD or X HOLD? If the latter - which is most likely - then the Child Lock has been activated! Press and hold ENTER and RETURN simultaneously until HOLD disappears!
Posted on Apr 24, 2009
Anonymous
SOURCE: DMR-EZ48V Clock no longer displayed on the front panel
Turn off power saving.
Posted on May 27, 2009
Robert
  • 176 Answers
SOURCE: Unable to view/record cable channels with Panasonic DMR EZ48V
Here is what you will need. This is assuming you do not have a HD cable box.
1) A two port cable splitter available at your local hardware or electronics store. VERY IMPORTANT- this splitter needs to pass up to 1000 mghz so you do not interfere with the functions of the cable box. Also, when purchasing this don't be fooled gold does not always equal good (a common mistake made by folks).
2) 1 small coax cable.
3) 3 Additional coax cables. (1 long enough to reach from the wall to the cable box. 1 long enough to reach from cable box to the TV. 1 long enough to reach from wall to the VCR. These cables should be RG6 coax cable (about the width of a standard wooden pencil)
4) 2 RCA cables (Yellow/Red/White)
Here is how you need to connect the cables....
1) Use the small coax cable and connect it from the WALL to the INPUT of the two way SPLITTER.
2) Use one of the coax cables and connect it to the OUTPUT of the SPLITTER. Connect the other end of this cable to the INPUT of the CABLE BOX.
3) Use one of the coax cables and connect it to the OUTPUT of the CABLE BOX to the INPUT of the TV.
4) Use one of the coax cables and connect it to the OUTPUT of the SPLITTER. Connect the other end of this cable to the INPUT of the VCR.
5) Use one of the RCA cables and connect to the DVD/VHS COMMON OUT on the VCR. Connect the other end of this cable to the VIDEO IN on the back of the TV.
6) Use the other RCA cable and connect it to the VIDEO OUT on the back of the CABLE BOX. Connect the other end to the IN 1 on the back of the VCR.
Here is how to set up the VCR-
1) Tune the TV to the video input that you connected the VCR to.
2) Go to the auto program in the menus for the VCR and select "CABLE" as the source and you should now be able to get all the channels you would normally get without the cable box.
3) This will give you the option to record shows from basic cable on the VCR. While copying these channels you will still be able to tune the TV to CH 3 for the cable box and watch TV normally through the cable box.
4) If you want to copy one of the channels that is only available with the cable box you will still be limited to only being able to watch that channel while it is recording but here is how you will do it.
  • Tune the CABLE BOX to the channel you want to record.
  • Tune the TV to the VIDEO INPUT you have the VCR connected to.
  • Select either VCR or DVR on the VCR.
  • Select recording mode.
  • Press the INPUT SELECT button.
  • Select IN 1.
  • Press RECORD.
Hope this has been helpful....
Good Luck....
Posted on Jan 22, 2010
Can't get into the setup on Panasonic dmr ez48v remote says rc2 I tried to switch to rc2 on the remote it does nothing
See if you can access the factory reset on the VCR, that should send everything back to normal.
Oct 23, 2016 | Panasonic DMR-EZ48V DVD Recorder
Dmr-ez48v when you press the remote dvd2 appears unit will work but not with remote
Press and hold the [OK] and [2] buttons down at the same time for 10 seconds. The remote will begin working.
Mar 31, 2014 | Panasonic DMR-EZ48V DVD Recorder
How to reset the pin for Panasonic DMR-HW120EBK 500GB HDD Recorder with Twin Freeview +HD Tuners (2012)
This is the definitive answer from Panasonic Customer Services. It worked for me.
In response to your enquiry, I am writing to inform you that you can reset the PIN number to the default 0000 and then change it, based on your preference. In order to reset the PIN, please follow the next steps:
1. Switch ON the unit;
2. Press and hold the OK, YELLOW and BLUE buttons, at the same time, until you see 00 RET displayed on the unit;
3. Press, repeatedly, the RIGHT ARROW buton until you see 03 VL;
4. Press OK and you should see "INIT" displayed on the unit.
This will reset the PIN number to the 0000 factory preset.
Furthermore, you should also be able to remove the message that is asking you for the child lock PIN while attempting to play back a recording. In order to do this, please follow the next steps:
1. Press SETUP;
2. Choose HDD/USB HDD;
3. Select CHILD LOCK FOR PLAYBACK;
4. Input the default 0000 code;
5. Switch it to OFF.
After performing these steps, the recorder should no longer ask you for the PIN when trying to playback a recording.
I trust that the above information will be of assistance to you. However, of course, if you should have any further queries, please do not hesitate to contact us.
Kind Regards,
George
Customer Service Team
Panasonic UK
Feb 19, 2013 | Panasonic DMR-EZ47V DVD Recorder/VCR
I HAVE A PANASONIC DVD,VHS RECORDER MODEL #DMR-EZ48V.WHEN TRANSFER A VHS CASSETTE TO A DVD THE THUMNAILS ON THE DVD HAVE THE DATE OF 1/1/2000. HOW CAN I PUT THE ACTUAL DATE OF THE RECORDINGS ON EACH OF THE...
Try setting the clock on the remote press [FUNCTIONS] go to SETUP menu - locate the CLOCK option (it should be under 'OTHERS' in the setup) and set the current time, press [ENTER/OK] to store if necessary, then press [RETURN] to exit the setup. Once clock is set correctly, future DVD thumbnails will show the actual date/time of recording in this (and similar) model combo units. If auto clock setting is not possible, set it manually as above.
I assume in spite of the wrong date/time, your DVD recordings have been successful. Incorrect clock and date setting usually only affects timer recording for VHS.
If you have lost or misplaced your original owner's manual, you can download a free pdf version (for Region 1 model) from:
http://www2.panasonic.com/consumer-electronics/support/Video/DVD-Recorders-Players/DVD-Recorders/model.DMR-EZ48VK
or, if you live outside USA, download the 'Australia/NZ' pdf version of the manual (for Region 4 model) from:
http://www.panasonic.com.au/Products/DVD+and+Blu-ray/DVD+-+Players+and+Recorders/DMR-EZ48V/Downloads
either one of these will provide you a full copy of the original user guide/setup including clock.
All free. Hope these suggestions help.
May 02, 2011 | Panasonic Televison & Video
How do you reset clock on your DVD Recorder DMR-ES15. Can't find booklet that came with recorder.
You can either copy and paste the following link into your browser, for quick-view, and/or save the .pdf document (instructions for Panasonic DMR-ES15 DVD recorder):
http://videolinq.tafe.net/attached_docs/pdf/equipment/Panasonic_DMR-ES15_User_Manual.pdf
(verified and complete to give you a basic operation manual for FREE download)
or you can try to set the clock manually, do this:
press [FUNCTIONS] on the remote while unit is on, to bring up the setup menu, scroll to 'OTHERS' look for 'CLOCK' or 'CLOCK SET' option, highlight it, click it, set the clock. Press [ENTER/OK] to access the date hour minute, etc., then press the relevant remote arrow buttons to select correct time/date, then press [ENTER/OK] to store the current setting. Then press [RETURN] to exit the setup. Clock is now set (this model does not offer automatic clock adjustment for daylight saving).
If the above suggestion does not work, download the pdf and save it for accurate reference. Either may help you.
May 01, 2011 | Panasonic DMRES15 DVD Recorder
Panasonic DVD VHS combo DMR-EZ48V will not play region 1 dvd
This is happening because your DVD is NOT all region, you need to change the Code.
en.wikipedia.org/wiki/DVD_region_code -
www.dvdexploder.com/ -
www.dvdexploder.com/multihacks.htm
www.allformp3.com/dvd-copy.../dvd-region-code- free.htm -
www.dvd.reviewer.co.uk/info/multiregion/ -
Ok check those links out they will help you sort it.
Apr 01, 2010 | Panasonic DMR-ES40VS DVD Recorder/VCR
Panasonic dmr-ez48v error f09 what is it?
If I have got the right machine than F09 is an electrical fault. If It is a K Deck model (you need to check) then it means: No serial clock linking IC2004, IC7005 and IC7701.
Nov 14, 2009 | Panasonic Televison & Video
Panasonic DMR EZ48V will not go into Functions
HI I WILL LIKE TO DO A FACTORY RESET ON MY panasonic dmr-ez48v, WHAT DO I HAVE TO DO?
May 03, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
Televison & Video Logo
883 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Muntejaya Ginting
Muntejaya Ginting
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
