There is a line at the top, and one about 3/4 of the way down that blocks the numbers inputted. Is there a way to fix?
SOURCE: Calculator screen stratified black lines
I've had a similar problem in the past. With mine though it was white lines. It still happens sometimes when I don't use it for a while. To fix it, all I did was set the screen to its darkest setting and left it on for 10 minutes (keep it from turning itself off, by pushing buttons ever few minutes.) It works great, and the calculator is fine unless you leave it unused for a month or so. A similar solution may work for you.
SOURCE: ti 86
Hi I got a problem with Ti-86 which is a line of the screen pixel missing. I tried to increase and decrease the intensity of the screen (2nd and up, down). Also tried to go to MODE function. I have tried those for several times. It works great. The line of those missing screen pixel came back. I don't know why. Just try it.
SOURCE: TI-83 Plus calculator--fractions
just type it in, e.g. 1/2 or 3/5. if you want to have answers display as fractions, press [MATH] ENTER.
SOURCE: texas instruments ti-86 screen problem
The TI-86 uses a very small, very thin ribbon cable to connect the display board to the LCD. The cable is about 2.5 " wide and about 4" long, and is only slightly thicker than a piece of paper but has about 40+ leads buried inside. Over time the leads will break at the folds (there are at least two folds in this cable to fit it down inside the case). There is no cheap solution to fix this problem. You might have some "Mr. Fix-it" try to fix it, but he will tell you to throw it away after he renders it completely inoperable. The calculator uses two Torx bit screws at the bottom of the case (T-6 size) so you will have to get the correct screwdriver to open the case. Save your money, sanity and time and use it till you can't stand the missing lines and throw it out. Even the data cable looks like it is glued down so if it lifts off after being cooked or frozen a couple of dozen times in the back of your car you can't fix this.
SOURCE: Low screen display contrast
Adjust the display contrast by pressing and releasing the 2ND key, then pressing and holding the Up key to increase the contrast or the Down key to decrease the contrast.
