Question about Razor USA Razor Pocket Mod Electric Scooter
Razor bella will not go?
Batteries are extremely hot after taking off the charger and charger green light does not come on after charging overnight.
Posted by Brent Weisenauer on
Sylvester Willingham
The batteries are new scooter still slow
Posted on Jun 25, 2013
Adam Fjeld
    Genius:
  • Razor USA Master
  • 1,508 Answers
One or both of the batteries must be bad, lift the seat up the remove the screws that hold the compartment down and then you should be able to see the two batteries below there, first visually inspect the batteries to see if they look like they are bulging, then test each battery with a multimeter and make sure it is showing at least 12 volts, chances are one or both of the batteries will not show more than 12 volts
Posted on May 31, 2012
Hi there,My girls Razor E300 is a year old wont fully charge...
My guess is the batteries have gone bad. They only last about a year before they need to be replaced. You can buy them fairly cheap off of Ebay.
Jan 04, 2013 | Razor E300 Scooter
When plugged into the charger the throttle light and charger light are green but when I remove the charger the throttle light immediately changes to yellow and it will not move and i hear a clicking sound
your battery voltage is dropping straight off the charger - batteries are not holding charge & need replacing. You can have your batteries load tested at the battery shop to confirm.
There are guides to battery replacement and trouble shooting here
http://www.razorama.com/razor-installation-guides.html
Jun 28, 2012 | Razor MX350 DIRT ROCKET - BLUE
Razor Bella scooter problem
yes sounds like the control module, you can always jump the batteries directly to the motor to make sure that the motor is ok
Jun 25, 2012 | Razor USA Razor Pocket Mod Electric...
Changed plug were u connect to charge the bella now the charger light stays green
check the charger end with a multimeter and make sure that its showing that its putting out the correct voltage
May 22, 2012 | Razor USA Razor Pocket Mod Electric...
Bella won't charge
check it with a multimeter and make sure that its putting out the correct amount of volts, it should be at least 24 volts
May 21, 2012 | Razor USA Razor Pocket Mod Electric...
I have replaced joystick, batteries, motors and the chair still losing lights will go about 1/4 mile and loses all green lights with in 1/2 mile loses all the yellow lights, drove on 1 flashing light for...
Janice check your charger it could not be charging the batteries. Now always charge your batteries overnight while you sleep When you get up lights on the charger should be red and green if they are red and yellow then the charger hasn't fully charged the batteries and overnight should be more than enough time to charge fully. This could indicate a bad battery remember new doesn't always mean good. Like they say always charge before use and this goes for new batteries too you need to charge new batteries nightly for 10-15 days before they start operating at 100%. If when you plug in the charger before bed and the lights are red and green then there is a problem with the charger or the batteries or the charger circuit Hope this helps you
May 23, 2011 | Spirit Activecare /wildcat Foldable Power...
When I plug in the charger is shows green, but the scooter does not run. Should I replace the battery or the charger? E100 razor.
Check the voltage output of the charger. It should be about 28 volts. Most likely your batteries are dead (over 2 years old?)
Mar 28, 2010 | Razor E100 Electric Scooter
Razor e200 runs slow
This could be a sign of a dying battery, although it charges and lights the green light it cannot maintain enough juice to power the machine when it has weight on it.
Dec 07, 2008 | Razor E200/300 Electric Scooter Battery
Norelco Advantage red light meaning and source of manual
the steady red light showing when in charger shows that
it is charging. the blinking red light when taken out of
charger or turned on and off means it is not fully charged.
leave it in charger till red light turns green.
Mar 04, 2008 | Norelco Advantage 6705 X Electric Shaver
Razor USA Razor Pocket Mod Electric Scooter Logo
340 people viewed this question
Top Razor USA Toys Experts
Marvin
Marvin
Tom Chichester
ray gallant
Are you a Razor USA Toy Expert? Answer questions, earn points and help others
