Question about Fisher RS920
Fisher receiver on stanby dont now how to fix it
Fisher and Paykel dishwasher Two drawers. Took top drawer out to fix leaking problem When put back together, closed the door and it is seized shut.
These use a claw type catch that rotates on a fixed loop catch receiver. Try removing the dishwasher lid, and remove the catch receiver to allow the door to open, With care you can then free the catch, and it will need to be adjusted correctly to prevent over rotation again. In the worst case, you may need to remove the inner door panel to free the door catch / receiver.
Feb 02, 2018 | Fisher and Paykel Dishwashers
How to fix power button on model 737 fisher receiver
open the top cover, remove the front panel cover , find the micro power switch and clean it with a contact cleaner
Nov 29, 2016 | Fisher Audio Players & Recorders
Fisher receiver model RS-636 it comes on and kicks itself back off after 15 seconds. Whats the fix?
Check and replace the damaged [shorted] component/s at it audio output stage circuit. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Oct 23, 2016 | Fisher Audio Players & Recorders
How to fix 1508 panel lock on
1) turn off the main power button (not the big LED stanby button)
2) press and hold "input mode" and "speakers" button simultaneously
3) press and hold the main power button for seconds, until display flashes.
4) release all those buttons. The AVR is already reset to factory mode.
Jun 27, 2014 | Denon Audio Players & Recorders
My reciever standby led light stays on after I reset it then clicks off the reciever.How do I reset the reciever so it does not turn off?
hi :good morning i have a fisher receiver i set the timer off by mistake,now the stanby red light stay on and the receiver give no sound at all,what sould i do to set the timer back on ?
Apr 10, 2011 | Fisher Audio Players & Recorders
On the Fisher CA-9435 i dont get sound from speaker outlets but hook it up to surrond or center speaker and clear. how can i fix this problem?
i would take off the cover and try checking and replacing the fuses mental note unplug the unit before such there is going to be two fuses side by side change them both if that dont fix the problet then it is a relay that is bad
Jan 20, 2010 | Fisher Audio Players & Recorders
Wont come out of stanby mode ??
The trouble your describing tells me that theres a short in the output circuit of this unit. Unless you know how to troubleshoot solid state electronics, Please take to a pro to have it serviced , as there are no user serviceable parts inside this unit. Good Luck
Jul 24, 2006 | Panasonic SA-XR50S 6.1 Channels Receiver
59 people viewed this question
Top Fisher Audio Players & Recorders Experts
ray gallant
Are you a Fisher Audio Player and Recorder Expert? Answer questions, earn points and help others
