The colors will change colors for example the red will turn into green over time. The picture will flicker the colors. Any suggestions?
SOURCE: being on for while color goes makes humming sound when turned on
Your color wheel is most likely the culprit. Mine also started humming and and it got louder and more annoying.
You could try cleaning it with an air can, but it sounds like it needs replacing.
I replaced mine myself last week and it works great!
Unfortunately, the site I bought mine from is now out of stock. for the 51" Vivitek I have, but they may have yours since they had parts for the 56" as well.
http://www.vancebaldwin.com was the site I went to.Login as guest and then type model number into corresponding box and see if they are in stock.
I changed mine myself and would be glad to give any help I can.
SOURCE: I have a vivitek 56"
Yes, that guy is right, its color wheel that giving whirring sound and causing problem.
Good to know that our experts were able to help you out in any way.
Thanks.
SOURCE: I replaced the lamp im my vivitek 56 inch dlp tv.
my vivitek RP56HD22A 56" dlp tv has a new lamp and will not turn on. when i push the on button is whines and wont come on
SOURCE: Have replaced projector bulb,can not reset lamptimer
turn the tv ON: On the side of the TV press the menu and volume up buttons at the same time for three seconds. The 'reset lamp timer?' will appear on the screen. Press the OK button to accept. You're done!
SOURCE: I have a Vivitek RP51HD41-A TV. Yesterday it made
Hi ryser,
Pop sound is coming from the parts either on the ballast board(lamp's driver) or power supply(ballast board supply). It means that you're bulb is not the issue that's why you've not encountered the led lamp indicator. Check the ballast board for faulty electrolytic capacitor, blown fuse/fusible resistor, shorted ballast transformer. Also check the power supply parts like bulged electrolytic capacitor, shorted voltage regulator transistor. If you don't have necessary tools and test instrument and can't do the job yourself, I would advice you to look for an experienced technician to troubleshoot the problem.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
