Adding details will get you a faPlugged in but no lights, now power on. Is switch failure common? Any other ideas before a tear down?ster solution from experts
SOURCE: My toshebia satellite M45-S359 scren only displays the toshiba
Thanks for that.
Ok the onlything that springs to mind is:
1. The bios needs to be reset asit has lost settings. This could happen IF you have installedsomething OR if it has become corrupt. Just access your Biosand reload the standard default settings.
2. Your hard drivehas a fault. The best thing you can do is to boot up from youremergency floppy (if you made one) or from your original windows CD. Once done, simply run scandisk/chkdisk/defrag and let it do what itneeds.
Sorry I could not help you more, but that is the onlything I can think of that would be stopping you booting further. Personally it sounds like the bios has lost settings and may betrying to boot from another drive ... but of cause it may be thatyour hard drive has become "sticky" or has errors that arecausing the problems.
Good luck with it.
SOURCE: Internal Hard Disk Upgrade
Yes, there is. Match the type of drive (Serial ATA or Parallel ATA) you get with what you have. Make sure your Satellite sees the drive in the BIOS. For drives larger than 120 GB, recommend operating systems Windows XP (Service Pack 2 or higher) or Vista. Older OS's have a 137 GB limitation (they only see the first 137 GB of the hard drive despite its size).
SOURCE: I have a Toshiba Satellite M45-S359, Power Supply Problem.
Hi there.
It is a possibility that the motherboard has blown, as a PC technician i would also check other possibilities first before condemning it.
The components to check are the power adapters, both on the power supply and the adapter socket on the laptop, check that the pin is not loose or gone completely, if its very loose or missing then you have your answer and it can be repaired.
Also have the PB (power board) checked, it could also be that.
You can check the pin yourself but a technician will have to check the PB.
Good luck and thanks for using Fixya!!!
SOURCE: Toshiba Satellite Notebook M45-s359 i had
GO to this site and enter your model number and you'll get a list of driver. Download and install
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp
SOURCE: how to calibrate battery laptop toshiba satellite
Calibrate laptop battery pack under the following conditions:
? When the battery status display seems inaccurate.
? When you observe a significant change in normal batteryrun time.
? When the battery pack has not been used for one monthor more.
How to Calibrate laptop battery
To Calibrate laptop battery pack, you must fully charge, fullydischarge, and then fully recharge the battery pack.
Discharging the Battery Pack
Disabling Hibernation
To fully discharge the battery pack, disable Hibernation temporarily.
To disable Hibernation:
? Select the Power Meter icon on the taskbar or access Power Options
> Hibernate, and clear the Enable Hibernate support check box.
To fully discharge the battery pack:
