Question about Schiller Welch Allyn Cardiovit At 2 Interpretive Ekg Machine
Ekg machine keeps beeping out of paper --- it has paper !
WE PUT A NEW PACK IN ---
Electro Med Services
  • Schiller Master
  • 6,694 Answers
Check is the paper is properly installed or not. Here i have added a video wich will help you to proper installation of paper in the try. keep in mind the you have to use Schiller orginal paper.
Ajin
Posted on Jun 10, 2012
Why does it keep indicating 'end of paper' or 'paper jam'?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
How to load paper
How to load paper - Fixya
www.fixya.com > Forum > EKG/ECG Machines
39 mins ago - How to load paper - EKG/ECG Machines question. ... Machines. Open Question ... Aug 30, 2012 ' Schiller Cardiovit At 2 Light Ecg Machine.
Loading paper into the MAC 1200 ecg machine - Fixya
www.fixya.com/.../t4590309-loading_paper_into_mac_1200_ecg_mach...
Apr 19, 2010 - loading paper into the MAC 1200 ecg machine how to load the paperinto the machine? ... Ge Medical Systems Ge Marquette Mac 1200 question.
Contec ECG Monitor & pulse oximeter Ekg printed sheet ...
www.hcuck.com/search/p1207318-contec_ecg.../ekg_printed_sheet
Question about Ge Medical Systems EKG/ECG Machines ... Open the . ... ...ekg-manual The paper is is backwards, there are 4 ways to load paper BUT only 1 ...
Electrocardiograph (EKG / ECG) Questions and Answers
Dec 21, 2015 • Medical
Whats the size paper
50mm x 100mm
Discount Cardiology sells the ekg paper that you need
Can a Schiller AT2 ECG paper size ( 8.5 * 11) inches be used on a GE MAC 1200 EKG machine?
hi,
Both machines uses the same dimension paper ( 8.5 * 11 Z fold paper ). You can use the paper in GE MAC 1200 EKG machine.
ok
2answers
I have EKG machine GE MAC 1200. I change the paper now it is not printing with new paper. What should I do?
Our EKG machines at work have specific paper that will only work with them, are you using the same type as before? Also, it is possible to put the paper in upside down and it will not print on that side. Have you tried to turn the paper around? Good luck
Apr 26, 2011 • GE Medical
The ECG machine expels the paper but with no ecg record on it, please advise?
hi,
Your machines thermal printing head have some problem. Thats why it doesn't print any thing on the paper. Not possible to repair thermal head. You have to replace it with a new one..
ok
Trying to refill paper and when i do that it stills says refill paper
hi,
use only paper for schiller AT1 . also check the paper sensor. slide the paper cover then look at is printer head side , u can see a small black square portion in the side . clan it with an ear bud. do not use any solution. after cleaning put the paper back and test again. use paper with black spot on the side. machine counts the black spot.
ok
1helpful
3answers
Schiller AT-2 Plus, placed new paper in machine and machine keeps stating "out of paper" and will not print unless I hold down the manual print.
Your machine has the wrong paper in it or the paper sensor is not working properly.  There should be a black mark on the top left hand corner of each page.  The correct ekg paper and ekg repair is available from Medical Device Depot.
Manual how in install new paper
I have the manual, send me an email and I will send it to you. [email protected]
4helpful
2answers
The schiller at 2 plus ecg machine not printing ecg
Does it work in auto mode ? are you putting paper correctly means , there is a black mark on paper which is sensed by paper sensor .If you put paper up side down then paper sensor won't be able to sense any paper & gives you error for rifilling paper .If this doesn't help you then You need to replace battrey . Thanks
Schiller Welch Allyn Cardiovit At 2 Interpretive Ekg Machine Logo
Top Schiller Medical Experts
Mark Ultra
Tom Chichester
Are you a Schiller Medical Expert? Answer questions, earn points and help others
