Televison & Video Logo
Posted on May 29, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Zenith concierge code
Its a hotel / motel tv from a thrift store no remote with it but i do have a dish dvr remote
Anonymous
Level 3:
Top Expert:
  • Zenith Master 14,553 Answers
  • Posted on May 30, 2012
Anonymous
Zenith Master
Level 3:
Top Expert:
Answers
14553
Questions
Helped
2718676
Points
48227
The Hotel sets use a special remote--only way to get one is via the Zenith division of LG. Not cheap and likely why someone got rid of the set.
2answers
Can I do a Factory default reset on a Zenith Concierge Series H2530Y7 Model Television without the remote control?
ZENITH SC652 Concierge Commercial TV Remote Control buy a master remote then,
  • Press the "Power" button on the Installer's remote control to turn on the TV.
  • 2 Press and hold down the "Menu" button on the remote for about six seconds until the menu disappears.
  • 3 Press the "9," "8," "7," "6" and "CC" buttons in succession. This resets the TV to factory default settings
  • Read more : http://www.ehow.com/how_7393497_reset-zenith-concierge-television.html
    Zenith concierge tv code
    The Dish remote only has about 60 possible codes built into it--try to Google the model number of that remote to locate (also can ask Dish) a manual with possible codes.
    Not all remotes will program for all sets.
    How to set dish remote for a zenith concierge tv
    See previous answers for duplicates of this question you posted.
    We have a zenith concierge tv that was donated to a group home. WE have tried programming it so that the cable tv stations can be used but it has a lock on the auto program and I can't figure out how to...
    You have to purchase the master remote from Zenith or a hotel supply company. This is the only way to gain access to programming the concierge. The remote is currently $24.99.
    1helpful
    I cannot reset the channels on my TV. It is the Concierge TV from a hotel. Will I need to buy a Zenith Remote from the store to do the channel programming. It says it is locked
    You have a hotel/motel model that cannot be programmed or any of the settings changed without a special Master remote. Sorry, doubt that you can buy one from the store, they are not sold to the public. Contact the hotel where you bought the set and try to get the model number for the remote from them. This is a different number than the model number of your tv.
    7helpful
    My tv wont let me auto program the channels
    if you can get to menu to unlock the channels type in 0000 or 1234 or 9999 or 0001 orif this doesnt work you could take back off tv and remove the little battery that looks like a coin out. becareful, this is high voltage in there.........
    20helpful
    6answers
    Zenith TV not programmed for home purpose
    If you have a remote that can access menu and your remote has number buttons and an enter key, you can follow this instructions to go to installer menu. Note that the installer menu is slightly different for each model, eg. some options are not available.
    I was able to go to installer menu using two universal remotes. The remotes that I used were Dish Network 3.0IR and RCA RCU300WBL. Both remotes programmed for Zenith H2531DT TV. The reason why I had to use two remotes is that Dish Network remote was only able to access menu. It did not have ENTER key but RCA remote had ENTER key but I wasn't able to go to menu with that.
    To go to installer menu (different from regular menu):
    - Hold MENU for 8 seconds.
    - Press 9, 8, 7, 6 and ENTER in the sequence.
    You should be in the installer menu now. There should be a line that looks something like this:
    03 VERT POS 13
    Use SELECT button to scroll through each option, and ADJ button to adjust the values for each option. For example, to enable the front panel buttons on your tv, set KEY DEFEAT to 0. Other options that you might want to check:
    CHAN LOCK which locks your TV to a single channel and wont let you change (set 0 to turn off)
    START CH/VOL will set your tv to a specified channel when you turn on tv. (set 255 to disable)
    You will have to look in the menu for some of the options because they are different for different TV series. A good place to find manual is on www.zenith.com or http://safemanuals.com/
    I work in an old hotel and it took me few hours to figure out how to disable start channel lock. It drove me nuts. I hope someone finds this useful.
    2helpful
    4answers
    Zenith Concierge hotel tv wont work with my xbox 360
    I doubt the TV even has a tuner if it is designed for a hotel. It may be a "dumb" receiver, nothing else. Do to channel 2 and then press the down arrow for channel, does it flip to 138 or AV1?
    2helpful
    3answers
    Zenith Concierge H25W35DT 27"
    The CORRECT answer is you must purchase a LP702 remote. Google it to find one to buy. You must unlock channels and program the channels fresh.
    Some standard zenith remotes allow you to reset the tv by popping off the cover of the remote and pressing an unmarked button.
    Top Zenith Televison & Video Experts
    matt martin
    matt martin
    Grand Canyon Tech
    Grand Canyon Tech
     Grubhead
    Grubhead
    Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
