Jet stream 1400 xc6
SOURCE: Zanussi jetsystem 1200 XC leaking from underneath
Check the door below, it's pretty vulnerable.
SOURCE: zanussi jet stream 1400 wiring to motor
its a block connector and it can only go on 1 way and a single wire to each brush
SOURCE: problem
Check the drain hose, and inspect the filter for any foreign object.
I report :"E20 means your fluff filter / waste pipe is getting blocked and the
machine cannot pump out the water. Try unblocking the fluff filter
first at the bottom of the machine. This should work, if the fault
appears again though and the fluff filter is clean your waste pipe is
blocked and you need to flush this through. Can you tell what I've just
spent my weekend doing, I have had to get the most unbelievable amount
of limescale out of these 2 areas but machine is now working fine again."
From how to mend it
See also E20 Zanussi Washer Dryer WJD1667
SOURCE: water in the fabric softner compartment after wash cycle
You need to poke all the holes clear in the top of the dispenser housing with a piece of wire or similar.
This should solve the problem.
SOURCE: Zanussi Jet Stream 1600 is displaying E10 as it
I found that the water pipes were frozen! so I have 'gently' defrosted them and we are now working...
Thanks
