Question about Samsung Galaxy Cell Phones
Samsung galaxy s2 says unregistered sim
Everything else works but i cant connect to my network because it says either no service or unregistered sim
Posted by pearly666 on
Lyndon John Brooks
    New Friend:
Remove sim the reinsert. turn phone on again
Posted on May 29, 2012
5 Related Answers
Anonymous
  • 7 Answers
SOURCE: Need to reset samsung galaxy s2 phone. Can't
If you want to try a simple solution, Go to Settings, Wireless and Networks, then Turn on "Airplane Mode" wait until you see an airplane on the top status bar of your phone... then Turn OFF "Airplane mode"
If that doesn't work, and you want to reset your phone, take it to the place you bought it or any place that is on your carrier.
Posted on May 18, 2011
sidhuu
sidhuu
  • 40 Answers
SOURCE: Samsung Galaxy S GT- I9000 Sim Network Unlock
By using the codes, you can remove your sim lock..This unlocking code will be provided by your network provider or you may get it from Classicunlocking.com ..They will help you to unlock your mobile..
Posted on Aug 11, 2011
dR-deviL
adeel malik
  • 258 Answers
SOURCE: sim network unlock code for samsung galaxy s,what
possible ways to get an unlock code:
-ask ur current operator to give u an unlock code
-go to any mobile repair shop and get ur mobile unlocked via box device
-follow the links below:
http://www.mrunlock.com/
or
http://www.moneysavingexpert.com/phones/unlock-mobile-phone
or http://unlock-zone.com
Posted on Mar 10, 2011
Dushyant verma
  • 99 Answers
SOURCE: my samsung galaxy s keeps
There are two probable causes.
1. You have inserted sim incorrectly. Remove SIM and insert properly with golden contacts facing the contacts in phone.
2. Your SIM card might be damaged. Try with another SIM card and if it works, then you have to replace your sim card.
If nothing works, you have to take your phone to some service centre
Posted on May 31, 2011
kerguney
Kazim ERGUNEY
  • 577 Answers
SOURCE: I own Samsung galaxy s2.
please visit the URL below which has perfect explanation with pictures and do everything in reverse..since this explains "How to Disable Data Network on Samsung Galaxy S GT-I9000"
so you need to make it ABLe...
Hope this helps! Take care and please Remember to rate/vote and give me
4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
http://droidbar.net/2010/12/how-to-disable-data-network-on-samsung-galaxy-s-gt-i9000/
Posted on Jul 01, 2011
How to use bsnl sim card in forin samsung galaxy 2s
Do you want to use your BSNL SIM card on your Samsung Galaxy S2 which was from any foreign country? If so, first ensure that the device is free from network restriction. If so, you can just insert your BSNL SIM card and start using it. If it is network restricted, you need to unlock the device in prior. You can unlock a Samsung Galaxy S2 safer and easier using unlock code. You can get the unique unlock code for a Samsung Galaxy S2 from WickedUnlock.com at an affordable cost. Good luck.
.................UNLOCKING INSTRUCTIONS.................
1 - Switch ON your Samsung Galaxy S2 with a NOT ACCEPTED SIM Card.
2 - Compose : #7465625*638*CODE# (or *#7465625*638*CODE#).
Nov 27, 2014 | Cell Phones
My Samsung Galaxy S2 GT-I9000 doesn't read my SIM Card
Can't figure out exactly what the problem is. Try with the following methods.
1) The SIM card might be damaged. To check this, Try inserting the SIM card into any other active network free phone. If it doesn't work then sure the SIM card is damaged. If it works fine then the SIM card is in good condition.
2) The SIM port on your phone might be damaged. Try inserting any other active SIM card to it. If it doesn't work, then sure the SIM port is damaged. If it work fine, Then the SIM port is in good condition.
3) The phone might be network locked. If the phone doesn't allow any network SIM cards to work with it except any one specific SIM card, Then it is sure network locked. You can unlock a Samsung Galaxy S2 safer and easier using unlock code. You can get the unlock code for a Samsung Galaxy S2 from ProUnlocking.Com at affordable cost with easy unlocking guide. Good luck.
May 30, 2014 | Samsung Galaxy S GTI9000 Smartphone
Go unlock
You can get the sim network unlock pin for your Samsung Galaxy S2 I9100 from Prounlocking.com by specifying the country and network to which the mobile is locked to.Based on the availability you will receive the unlock code along with free unlock instructions.
Apr 28, 2013 | Samsung Galaxy S Ii S2 I9100 16gb Unlocked...
S2 sim network unlock pin
Hi, to which network has your Samsung Galaxy S2 been locked to? you can visit www.ClassicUnlocking.Com to get the accurate unlock code for your Samsung Galaxy S2 at affordable cost with free step by step unlocking instructions. Good luck mate.
Feb 15, 2013 | Samsung Galaxy SII Unlocked Android Cell...
How to unlock Samsung Galaxy S2?
To unlock SAMSUNG GALAXY S2 use unlock code...Visit the site WWW.THEUNLOCKARENA.COM get unlock code and unlock it from network lock easily.To buy code you need to specify current network,country it is locked now and get code unlock it....
Samsung Galaxy S2 Unlocking InstructionsWarning : Do not enter any wrong unlock codes on your Samsung Galaxy S2 mobile phones. If you enter over a certain amount of wrong unlock codes on your Samsung Galaxy S2 mobile phone, your phone may get hard locked and sometimes become unusable.
NOT ACCEPTED: We mean, to use a sim card from a network other than the network your Samsung Galaxy S2 is locked to.
CODE: Its the unique Unlock Code for your Samsung Galaxy S2.
Oct 28, 2012 | Samsung Galaxy S2 S II i9100 16GB -...
When am unlock samsung s2 is not coming ?
What Not coming..?You need to decode from service provider lock?You can get the Unlock code for SAMSUNG GALAXY S2 at
Theunlockarena.com/samsung/rs13wp8/ and unlock it easily..Specify the current network and country it's locked now and get the code and unlock it easily....You can follow the instructions below and unlock it step by step...
Oct 12, 2012 | Samsung Galaxy S Ii S2 I9100 16gb Unlocked...
How to turn on 3G network on Samsung galaxy s2?
Settings > More Setting > Network Settings > Mobile Networks > Network Mode > WCDMA Only or WCDMA/GSM (auto connect)
WCDMA Only is is you only want to use 3G.
If you want that your phone should switch between 2G and 3G mode automatically, use auto connect option.
For this, your SIM Must support 3G services.
Jul 18, 2012 | Samsung Galaxy S2 GT-I9100 Unlocked GSM...
I own Samsung galaxy s2. I have activated the data network mode but still not getting internet connection. even i cant see the ikon of data network activation on the screen
Thanks
Jul 01, 2011 | Samsung Galaxy S GTI9000 Smartphone
Cell Phones Logo
905 people viewed this question
Top Samsung Cell Phones Experts
Muntejaya Ginting
Muntejaya Ginting
Michael Thomas
Michael Thomas
Marvin
Marvin
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
