TV will turn off then reboot by itself. However when it restarts it freezes anb i have to unplug it to grt it to work. This happens from cold startup and occurs several (3-7) times in a row.
SOURCE: T.V. turns itself off
before any attempt to deep cause of problem, unsolder first all the tack switches in the front panel of tv.then turn on the tv using remote control observe? cuz maybe one of the switches is stock.if not,proceed to eeprom servicing which is u have to look for service mode of ur tv model to unlock it and reset it to factory value.
SOURCE: Samsung hln567w dlp tv
after 3 years it is a good chance that the lamp is going,,however if it plays its melody when it turns off there is a possibility thateither the lamp door switch or the thermostat are failinf
SOURCE: Sony FD Trinitron WEGA KV-24FS100 24" TV On/Off problems
I think I have the solution for you. I have the same tv and it does the
same thing when you turn on the power button on the remote when the tv
turns on you hear a click then the red light flashes about 5 to 6 times
then the tv comes on. on the remote there should be two buttons on top
of the remote one says power and the other one says system hit the
power button to turn on the tv when you hear the click and see the red
light flashing then hit the system button which will turn off the tv
then hit the power button again and it will turn the tv on without the
red light flashing it should work
SOURCE: Samsung DLP freeze and reboot automatically
I do suspect the digital board with the part number of BP96-02084A. You shouldn't have to replace anything but the digital board for a freezing issue. Whn these boards are changed the settings need to be written from the board manually or electronically saved to what they call the DMD board in the TV. If not the possibility of the color looking wrong is great once its replaced.
