Question about Furniture
Can I keep red and white wine in the same temperature?
Posted by Sarah james on
GeorgeCook
    New Friend:
    Problem Solver:
  • 10 Answers
No. You need to keep them at a different temperature. Both have different taste and preservation. White Wines should be stored at 9.5-13.3 C, whereas Red wine should be stored at 12.7-15.5 C. You can also go through Wine News, here you will get all the information about storage and serving temperature of wine!
Posted on Jul 30, 2018
Wine Winer
Not recommended. Red and white wines are different worlds and in order to preserve the wine better you need to keep the wine in the recommended temperature: Red wines at 12.7-15.5 C and white wines at 9.5-13.3 C
Posted on May 29, 2012
What is the correct temperature for beer? Or wine. Or pop? Please
Hi Laraine:
Beer:
- If you're British, warm. Canadian, wet. Otherwise, who cares?
Wine:
- white - chilled, red - warm. If you're Canadian, wet.
-Pop - cold, but if you're Canadian, stick to beer and wine so....... Who cares?
Cheers
Jun 06, 2016 | Furniture
What is the appropriate serving temperature of wines?
There are four different types of wine with different temperatures. Deep red wines should be served in 15-19 Celsius. Light red wine should be served in 13 Celsius. Sparkling wines and Champaign should be served in 6-8 Celsius. Dry white wines like rose and blush should be served in 8-14 Celsius.
Aug 13, 2012 | Furniture
What kind of cooler should I get if I plan on storing both red and white wines in the same fridge?
You need a dual zone wine cooler. They have two temperature controls and the storage space is divided in such a way that each temperature control has its own section inside the cooler; allowing you to store both red and white wines properly.
Jul 31, 2012 | Furniture
What is the best temperature for white wine to be in?
It is important to keep the wine cool and in stable temperature that doesn't fluctuate very often. Bright tart white wine: 48-52 degrees; sparkling wine: 50-55 degrees and rich white wines: 58-62 degrees.
May 29, 2012 | Furniture
Are red wines stored on the top or bottom of the Haier BC112G wine cooler? How about white wine? Have lost my owners manual and don't know where to put red wine when the temp is set cooler for white wine
http://www.haieramerica.com/en/asset/archived/BC112G.pdf
is the link to your manual.Typically in a dual temperature zone wine cooler whites are stored in the bottom and reds on top as whites are better a little colder and the cold air will drop to the bottom of the unit.
Hope this helps!
Jun 14, 2010 | Haier BC112G Wine Cooler
What is the temperature setting for normal wine cooling?
It's between 55 and 65 degrees fahrenheit. If you're storing a lighter red wine, you'd want to keep it on the lower end (55 degrees). And for the darker (deep) red, you'd want to keep it on the higher end (65 degrees). All white wines should be on the lower end, and below. You can drop down to 50 degrees if you'd like. I hope this helps. Good Luck!
Mar 29, 2010 | Emerson (025806803716) Wine Cooler
Magic Chef Dual temp. wine Cooler #MCWBC77DZC
I suspect the cooler can only actually regulate one of those temperatures and the other one just drags along behind. Perhaps the weather is now warmer and the cooler has to keep the motor on longer to keep cool. The unregulated bottom temperature ends up cooler as a consequence.
Either that or the opposite effect is doing it.
The answer might be to find a 61 degree place in your house to keep the reds.
Apr 28, 2017 | Magic Chef MCWC30MCG Compact Wine Cooler
I have a magic chef wine cooler (Model MCWC50DBT) and the labels keep falling off of the bottles. The temperature is set to red and we don't seem to have any other problems.
All the wine chiller set 2 temp red and white, red wine temp only for 18- 20 oC , your using white wine don't set red wine temp , set only for white temp mode,white and red wine set temp are different temp
May 27, 2008 | Magic Chef MCWC30MCG Compact Wine Cooler
Furniture Logo
684 people viewed this question
Top Furniture Experts
Tom Chichester
Andrew Taylor
Andrew Taylor
Are you a Furniture Expert? Answer questions, earn points and help others
