Recently the keyboard stopped working, it has worked once or twice in the last week but only for afew letters, then stops again, turning it off makes no difference, pulled it apart, all connections look ok
SOURCE: keyboard stopped working
Try Swapping The Mouse for The Keyboard ?
you may have a faulty USB Port On The Computer/Laptop.
Also Which operating System Are You Using Windows 98/2000/ME/XP ?
Another possible Fix, is to wipe the USB Connectors/Contacts on the End of The USB Plugs. ( Computer And Keyboard ) use A Cotton Bud/Swab *****lightly****** soaked with lighter fluid/Petrol/methylated Spirits.
Mike @ Compurepair.
SOURCE: laptop keyboard not working medion mim2120 notebook pc
this and my mouse have also stopped working, idk the problem but i fixed it once and whenever i wanted to turn it off i just put it into sleep and it worked fine when i started it up. i came to a situation where i had to restart the computer and it didnt work again and now i cant fix it.
SOURCE: The letter l is not working on Toshiba Satellite r25-s3503, running xp
You dont have to buy a diferent laptop for this. Just get the keyboard circuitory checked
SOURCE: the keyboard has a keypad, but when y turn on the
Sorry but you found what is NORMAL for laptops. this is not a bug, error, fault, etc.
It does exactly what it is supposed to do even though it may have a proper number pad too. leave num lock off
SOURCE: compaq presario cq60 keyboard
If the problem is intermittent then the problem could just be
foreign objects like crumbs and hair that's trapped under the keys.
Turn
the laptop off and stand it on it's side with the lid open. Get a soft,
dry paintbrush and brush the keys, gently tap the keyboard in various
places with the back of the paintbrush to help dislodge anything that's
trapped.
Once your satisfied all the keys are clear turn the laptop on and see if it has made any difference.
If it has not then you may need to replace the keyboard.
Good luck.
