Acer em350 my acer em350 cannot detect wireless connection even i have wifi in our house..
Posted by janine_ponce on
General Systems Consulting
    Top Expert:
  • 5,051 Answers
Maybe you don't have your wireless turned on. Look onboth sides and in front for the Wireless Switch and turn it on. Sometimes the wireless switch might be a button to press. Look above the keyboard or sides for a wireless button to press.
Also once the wireless switch is turned on there are keystrokes that can togglethe wireless on or off. Normally you would Press and Hold the FN functionkey located at the lower left of the keyboard, then hit the correct F1 thru F12key that toggles the wireless. The correct F1 thru F12 key to hit willhave the wireless signal icon )))) on it. Or it might have the icon of a towerwith the wireless signal icon )))). Normally the screen will displayWireless On or Wireless Off when you toggle the wireless.
Maybe the wireless card needs to be reseated.
Turn the computer off, remove the power cord, remove the cover from the bottom of the laptop where the wireless card is housed. Sometimes the wireless card might be under the keyboard. Once you find the wireless card, remove the 2 antennas (black and white cables) but remember where they go. Then remove the wifi card from the slot (it might be secured by a screw). Wait 30 seconds then put it all back together and reboot and see if it detects wireless.
You can also try downloading and reinstalling the wireless drivers.
Get onlineand got to www.google.com In the google search box type: "AcerSupport" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operatingsystem when requested. Download and install the Network drivers for the wireless.
Posted on May 29, 2012
  • George depew Apr 13, 2014
    you might have to down load a driver for the wireless card , Atheros has a great one !
5 Related Answers
Ismail Shifau
  • 50 Answers
SOURCE: cannot connect to internet
try running this command "netsh winsock reset" in your dos prompt. to go to dos prompt press the window key+r and type "cmd". then it will popup a new window. type the command and see if you can connect to internet. it might be a problem with spyware as well which infected the winsock or the network drivers. download combofix and run it.see if that helps u.
Posted on Dec 14, 2008
Anonymous
  • 6 Answers
SOURCE: Dell D600 wifi
It might be that your adapter isn't operating at a high enough power. To fix this Click start>right click my computer>properties>hardware>device manager>double click your wireless adapter. In the advanced tab set the power management and transmit power all the way up (but be warned: KILLS battery life). Or your adapter isn't set to the right mode (like if your access point or whatever is 802.11g and the adapter's settings are set to 802.11b only).
Posted on Jan 18, 2009
Anonymous
  • 37 Answers
SOURCE: wireless connection
Settings must have changed and not not changed back, set your friends settings as default settings. He may have accidently reset something etc.
A quick solution is to go to
System Restore and reset it back a day before you gave it to your friend.
go to START > PROGRAMS >
ACCESSORIES > SYSTEM TOOLS and you'll find SYSTEM RESTORE there. Click on it and find the option to set your Notebook to an EARLIER TIME. After selecting that from the list find a date BEFORE YOU LOANDED THE NOTEBOOK TO YOUR FRIEND and left click on it and follow the instructions and your COmputer will restore the system to that earlier date (it could be 1 day before you loaned it). You will not lose any files etc.
After it goes through a cycle of rebooting etc and it resets to the earlier date, your Network should work as it did before you loaned it to your friend.
If you have trouble finding SYSTEM RESTORE go to HELP and look for a link there.
Good Luck !
Cheers !
Posted on Sep 04, 2009
Anonymous
  • 30 Answers
SOURCE: acer wifi
Most Acers use an IPN2220 Wireless card. If yours does and your router is using WPA or WPA2 (TKIP or AES) security then you'll need to update the driver by searching for it manually using the Custom button (Hardware) in Windows update (instead of Express). This driver is not part of XP service pack 2 or 3. In my experience if you don't update to the newest common form of home wireless security (WPA2 AES) then the older formats seem to become unreliable in the way you describe
Posted on Mar 25, 2010
leecom72
Lee Hodgson
  • 4810 Answers
SOURCE: acer aspire 4736z wifi problem.
Try turning off your wireless router and modem for 2 minutes and then turn them back on. Wait another 2 minutes for them to settle down and try connecting to the internet again.
If this does not work you may have to reinstall the drivers for the wireless card in your laptop.
Regards.
Posted on Aug 05, 2010
How to connect the wifi to a acer aspire 5733z - 4851 laptop
Check the wireless router and high-speed modem. If the two are not powered on, or if the Ethernet cable connected the two is not completely inserted into both connection ports, you are unable to access the Internet on the Acer Aspire One laptop computer.
  • 2 Activate the wireless Internet connection on the laptop computer. Right-click the wireless icon on the desktop, then choose "Enable" from the pop-up menu. Without activating the wireless receiver on the Acer Aspire One, the laptop is unable to detect any wireless network.
  • 3 Select the appropriate network you wish to connect to. Your computer may be attempting to connect to a different Internet connection, preventing you from access the network you desire. Right-click the wireless icon, select "Search for available wireless networks," then choose the network you want to access.
  • 4 Restart the computer. The system may have booted and failed to detect the wireless receiver. Restarting the computer corrects this issue.
  • Oct 09, 2011 | Computers & Internet
    Hi there i have an acer aspire one d255e windows 7 starter,,i cannot connect to a wireless connection in our house,,it happened before and what i did is restore point and it fixed the problem and now it...
    if password or security code is accepted
    nothing to do with restore points or recovery
    will be the wi fi chip inside the laptop
    use the trouble shoot function or check the wi fi set up on the laptop
    either too far away from modem
    or house insulation or construction weakens the signal
    best solution is buy a long Ethernet cable
    Apr 28, 2017 | Acer Aspire One Netbook
    I have an acer extensa 5620z and netgear dg834v5 modem/router. I can connect via ethernet, but even though i have set the router without security, the laptop detects the wireless network, but won't...
    This is worked for me on Vista:
    1. Goto Network and Sharing Center.
    2. Click on your Wireless Connection "View Status".
    3. Click on Propertes.
    4. Uncheck the option that says "Internet Protocol Version 6"
    When I did this, my wireless began working again.
    Jun 11, 2011 | Acer Extensa 5620 Notebook PC
    I have acer laptop 5580. 3 year old. Recently i have installed Windows 7. Wireless was working nice. Now, system is identifying the wireless, but not connecting. After troubleshooting it is giving...
    If your device can detect other acces point then, your wifi device is correctly installed. If not, os will tell your wifi have problem. If you try connect, and have problem with connection, it came from your acces point(wifi router expample). Maybe it have password that have not match with your pc. If that access point is yours, then you can try check the password for wifi using cable connection.
    If that acces point(wifi router) is not yours(public), then you cant get the password unless you try hack using air-ng, backtrend using wifi device that can capture and monitor the network(wifi *** support a/b/g exmple) if it only support b/g, you cant get wep encryption password.
    If it does not have password, and you try to connect, but it still problem, that mean, it have restrictly to MAC address in wifi router.
    May 09, 2011 | Acer (BCM94318MPG) Wireless Adapter
    My laptop (acer aspire 4930) wifi is not able to detect wireless networks. It has been working fine for 1.5 years but something has happened today that it is not able to detect the wireless connections.
    Double check that the Wi-Fi didn't accidentally get turned off. There should be a button on your computer that turns it on and off or a fn key usually fn+f2. Try that first if that doesn't solve the issue try reinstalling your driver which can be found at the following site.
    http://support.acer-euro.com/drivers/notebook/as_4930.html
    Apr 19, 2011 | Acer Aspire 4930-6862 Laptop
    Acer aspire 4736z wifi problem. i have the drivers, it detects the connection but i was mot able to connect on it. it willl prompt that it was out of range but the wifis connectivity was very high.
    Regards.
    Aug 05, 2010 | Acer Aspire 5100 Notebook
    How do I enable the wireless on my Acer Aspire one?
    Open control panel scroll down to Internet connections and click to display. Right click wireless wizard then click choose enable. After this you will be prompted with a box that will show you that the computer has detected wifi connection in the surrounding.
    Jun 22, 2009 | Acer Aspire One PC Notebook
    Wireless problem
    when you install fresh copy system doesnt recognise wifi by default ..goto http://hp.com type in your pc model ...navigate to drivers and download your wifi driver ....once downloaded install driver ...once driver installed system will detect and prepare wifi..
    done.
    Dec 26, 2008 | Acer TravelMate 2300 Notebook
    I need to know how to put wifi on my acer laptop can u help instruction please
    if ur laptop does not have an wifi card...u can buy a USB wireless adapter...it can detect wireless connections
    Sep 02, 2008 | Acer Computers & Internet
    Can't detect network
    Hi, Some models of Toshiba Laptops have a slide switch either on the side or front to physically activate the built-in Wifi. Some models also will not work with some models of Access Points if using the built-in Windows Wireless Configuration Utility. A workaround is to install the Wireless Configuration Utility of the WiFi manufacturer. If your Toshiba is using the Atheros WiFi chipset, you may need to install the Atheros 802.11a/b/g Wifi Client utility to use rather than than that pf Windows. The file name is atheros_wpa_client.exe and you can just Google it. Hope this be of some help. Post back how things stand or should you need additional information. Good luck and kind regards.
    Oct 03, 2007 | Efficient Networks SpeedStream 3510...
    Computers & Internet Logo
    153 people viewed this question
    Muntejaya Ginting
    Muntejaya Ginting
    Marvin
    Marvin
