The subwoofer on my Cambridge Soundworks speaker system has never worked properly with my new receiver. Today we found out that the Harmon Kardon receiver needs a subwooder with an RCA type input plug. Can we modify our subwoofer? If not where can we buy this type subwoofer? BestBuy and Radio Shack doesn't have it.
SOURCE: Harmon/kardon computer speakers bought on ebay missing power adaptor
Get the speakers with you walk a distance for your Nearest electrical shop as quickly as possible and your roblems will be solved...
SOURCE: lost the power cable from subwoofer of my harmon Kardon
If you go to the Harmon/Kardon website, you can find where to buy replacement parts.
http://www.harmankardon.com/
Select product support on the front page, then go to parts.
Then select your product as Harmaron/Kardon SoundsticksII and select your country.
Hope this helps,
Nathan.
SOURCE: How do I disassemble + clean Harmon Kardon SoundStick subwoofer?
Check for a Fuse. Mine is an older model and has a Fuse right next to the power cord. It probably has a slot for a flathead screwdriver.
SOURCE: Does my Harmon Kardon HK595 subwoofer need to have
does the sub have a power supply, ie a power cord, if it does this is do able if it does not, then it has no amp for the sub and would require that
SOURCE: I have a HK 595 sub. with no sattelite cables.
you need the the satellite speakers hooked up in order for the sub to work. its not a standalone sub the volume control knob on the satellite speaker is what powers on the sub. i have extra speakers i wish i could give you cuz my sub just blew out.
