Question about Rowenta Commercial Garment Steamer - White
ROWENTA IS8050 INSTRUCTION MANUAL
WON'T TURN ON
asher1
    New Friend:
    Problem Solver:
  • 7 Answers
Rowenta IS8250 Garment Steamer instructions are no longer available from Rowenta.
Posted on Jun 17, 2012
1 Related Answer
DiYerTech
Roland Wong
  • 70 Answers
SOURCE: Rowenta DM273 Self Cleaning Function
Attached below is the Rowenta website to obtain PDF copies of the manuals. If the hyperlink does not work, cut and paste it into your browser's address line. There are also links to download Adobe Acrobat Reader to allow you to view and print the documents if you do not have this program. Please advise if you find this helpful...
http://www.rowenta.com/rowenta/frame.aspx?page=http://www.rowenta.com/rowenta/consumer_care/use_n_care/downloadInstructions.aspx?RblCategory=Download
Posted on Jul 14, 2008
Rowenta Dz9080
Check or replace fuse in plug. If that don't do it, then change fuse inside iron. Make sure iron is not plugged to supply.
Apr 28, 2013 | Irons
Rowemta DA1560 won't turn on
1) No voltage to receptacle
2) defective cord or terminal connection
3)open thermostat
4) open heating element
4a) the heating fuse blown
5) test the outlet wal with lamp desk, if work, the iron is the problem follow the steps before mentioned. reset the c.breaker or change the blown fuse is necessary.SEE the diagram
God bless you
Sep 09, 2012 | Rowenta DA1560 Iron
Instruction Manual for Rowenta surefine Inox Steam Iron Model DE-57 1C
Ah, simply search for it online, or go to the manufactors website. I am sure you will find it on the internet.
Jul 22, 2012 | Rowenta Irons
How do I put water in it (dx8800) ? I see a slider but don't want to break it.
the manual says to slide to left you can download manual at rowenta.com customer service on irons 8000 series
Sep 23, 2011 | Rowenta Professional DX8800 Iron
My Iron will not turn on! It hasn't seemed to heat up right lately anyway,but now it won't heat up at all.
Has found all with detailed operation and with comment that from itself this model.Manual HERE
Jul 29, 2011 | Rowenta Irons
My iron won't heat. it has electricity but won't heat
Here is a tip that I wrote about Electric Irons and why they do not heat....
Electric Ironnot Heating Up or not Working Right heatman101
Jun 25, 2011 | Rowenta DE-480 Iron
IRon heats standing but the light goes out when I set it horizontal to iron a garment. I think the cord is needing replacement but need advice.
If the iron is not moved while it is plugged
in, an internal safety switch will turn it off.
- It will turn off in 8 minutes if left vertically or
in 30 seconds if left on its soleplate or tipped
over. A red flashing light indicates that the
auto-off has been activated.
The above information is from the Rowenta DX1700 Owner's Manual. I think most, if not all Rowenta irons have the "auto off" safety feature. If your iron is going off before the 30 seconds idle time, the sensor may be defective. If you are letting it sit on the sole plate longer than 30 seconds, you may just need to work faster. ;-)
Jun 11, 2011 | Rowenta Irons
Jul 05, 2008 | Rowenta Perfect Iron
Rowenta Commercial Garment Steamer - White Logo
1,153 people viewed this question
Top Rowenta Irons Experts
Paul Bade
Fahr Quad
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
