Arris Modem Style:mstatea Logo
A
Anonymous Posted on May 28, 2012
Flashing red dsl light on a motorola mstatea modem
1helpful
I can not run 192.168.01 on my computer to change it to ppoe,i have a di-524 dlink and a motorola mstatea dsl modem,the other computers desk top and laptop can connect to the internet,but the one these...
you should type in 192.168.0.1.
In your request you have:
i can not run 192.168.01 on my computer to change it to ppoe,i have a di-524 dlink and a motorola mstatea dsl modem,the other computers desk top and laptop can connect to the internet,but the one these componets are hardwired to cannot.has worked fine for years but stopped suddenly!!!!!!!!!!!
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Ethernet Hub EN104 Hit and Miss.
Are you sure you got a compatible modem? They are not all alike.
1helpful
WEP key
Your DSL modem does NOT have wireless capabiltiy and therefore has no WEP. Do you have a wireless router attached to the MSTATEA? If so, it has WEP security encryption. Please let us know make and modl of the wireless apparatus you are using.
Motorola MSTATEA takes long time to "reconnect"
Check the speed and call ISP tech support to run the line test
Before calling them do a complete power cycle
Turn the modem off and the computer off and router if any
Wait for 30 seconds and turn the modem on and wait for the lights to turn solid
Once ready turn router if you have else computer
Delete the temporary internet files browsing cookies,cache memory.
If the modem turns too hot after running for an hour please replace the modem
DSL light blinking green indicates that there s no proper signal to the modem
Check the wall jack for any loose contacts
If you have any filter check them too
Isolate them and try with it
Change them if possible
5helpful
My Motorola Modem Mstatea
When the DSL light turns red it indicates that the modem has no internet signal.
So please check if the cables are connected properly
Also ensure that there is a proper signal to your premises without any interference
This is called intermittent connection
If the DSL light turns red it indicates that there is a problem with the cables connected or the DSL line
Please check your DSL connection with ISP
There is on another reason that the modem might have gone bad.
If all the above steps are executed and if this issue still persists replace the modem
5helpful
3answers
Recently I subscribed ATT DSL Service conflict IP Address
the motorola modem that att is using uses 192.168.1.x subnet. log onto your router and change it to 192.168.b.x where b is any number between 2 and 254 (just not 1). You should also log onto the modem and change the setting that allows it to share the external ip address with the router. You will need to do this if you plan on accessing your network from the internet.
Motorola router
Modem light goes RED if No external Ethernet device has been attached and detected OR The Ethernet link is down.
in your case it is going to be the DSL MODEM ....
Second cause could be The WAN interface has been disabled by the firmware.
TO enable it log on to your router's address http://192.168.10.1.
and look for WAN options.
http://broadband.custhelp.com/cgi-bin/broadband.cfg/php/enduser/std_adp.php?p_faqid=17058&p_sid=rTOCxT5j&p_lva=17178&p_accessibility=&p_redirect=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9ODAsODAmcF9wcm9kcz02MzAsNjQ0JnBfY2F0cz0mcF9wdj0yLjY0NCZwX2N2PSZwX3BhZ2U9MQ%2A%2A&p_li=
Thanks ,, please let me now it worked or not
Top Arris Computers & Internet Experts
Jesse Walters
Jesse Walters
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
