Question about Humminbird 997c Si Combo Color Fish Finder And Gps Chartplotter, Without Transducer
My Humminbird 997c SI is stuck in loading screen
I had downloaded latest software updates for my Humminbird 997c SI and my 1197c SI.Then was attempting to update them one ata a time following typical software updates for these units like I had done in the past, resetting factory settings then running software update. My 1197c SI update perfectly with no problem, then moved up front to perform update on my 997C SI and went through same process as mentioned before. I turned around for less than a minute and turned back around to a black screen. When attempting to turn the power back on it started the loading screen and then stayed there for over an hour. I brought the unit inside and connected to the PC via USB cable and opened my HumminbirdPC. I made it to the Matrix Boot screen by holding the "View" button down and proceeded to toggle down to the #9 "Program" command and again pressed "View" to start to HumminbirdPC recognition sequence. My unit is not recognized by the software and the unit came back with a "Programming Failure" response. I have attempted this several times and even brought the 119c Si in to try,keep in mind the 1197C Si is up to date... However thinking that the 1197C SI would load and be rcognized, now both units have the "Pragramming Failure" response when trying to get Humminbird PC to recognize them!? I have my PC with Windows Vistaup to date as I just went through a 26 item update with windows, including service pack 2. I have all Drivers up to date, all Security updates and still no recognition. I thought maybe it was something with my PC... So I borrow my wife's work computer which is a Dell with Wi ndows XP and her company keeps it updated thoroughly. Same result... Then borrowed my Sons MAC that runs Parallels and has Windows 2000 on it. No Luck!! I have exhausted all ideas and could use some additional ideas if someone has any. Any input would be appreciated to get the 997C SI up to date. I have heard tha it is appx $200 to send it in to Humminbird and the new 998c is outrageuosly expensive. Thank you in advance for any HELP!?
Posted by SKEzell on
2 Related Answers
jwsmith180
  • 29 Answers
SOURCE: bought a 987c si hd.
If you have put power to the gps antenna then there is going to be a problem with your gps antenna. The Humminbird gps antenna gets it power from the unit. If you have done this you will need to contact our customer service group to get it resolved. There number is 800-633-1468.
Joby @ Humminbird
Posted on Feb 01, 2011
I cant restore iphone. I keep getting error number 9006
Try the following tips to resolve error 9006 in iTunes if you encounter the error problem when updating iOS system software.
  1. Insure that you have an active network connection and are connected to the internet
  2. Quit out of iTunes
  3. Update iTunes and also install any available software updates to Mac OS (or Windows, if applicable)
  4. Reboot the computer (Mac or PC)
  5. Temporarily disable any and all software firewalls, including anti-virus (if applicable)
  6. Try using a different USB port on the computer and updating again
Jun 12, 2017 | Cell Phones
Will power up, but won't advance to menu
May require a software update.
register your unit at OnixSeries (this is a link to humminbird)
On your "My humminbird" page you will find free software updates for your particular unit.
download the latest update to an SD card and follow the instructions for the installation process.
Apr 20, 2015 | Humminbird 581I Hd Di Sonar/Gps Combo
Software update
You can:
1. type *#0000# to check the current software installed in your phone.2. select options then select check for updates3. if there are available new updates just select start update.4. follow the process for software update.
You can also:1. go to settings2. select icon for "software update"3. it will provide you access doing the update to the latest version available for you phone4. start update5. follow instructions for update
*you can also update via pc suite from your pc, you need to download the latest pc suite from nokia.com/softwareupdate*you can go to www.nokia.com/software update then select your phone model and the just follow the instructions
Thank you for choosing www.fixya.com.If you have any other issues under the sun, just post your questions here and we will provide you the answer.
Nov 29, 2011 | Nokia 1280 Cell Phone
My software is 2008. How can i download the latest software for navman s75?
Please follow this link for North America: http://www.navman.com/in-car/North-America/USA/Customer-Support/6296/
Please follow this link for UK: http://www.navman.com/in-car/europe/uk/Customer-Support/Software-Updates/
Select "Download Software Update 145MB" under Select S-Series Software Update (SP2)
*Note: this only downloads the software update not a map update. For the latest maps or safety camera subscriptions please visit the Navman Store. You will have to pay to update your map.
Mar 02, 2011 | Navman e Series GPS Receiver
Hw to uptodate my phone
Click on the link below to download and install the Motorola ROKR Update for your phone.
Download Update Setup
You need the following USB cable type to perform the Software Update : Mini USB Data Cable.
If you don't have a USB cable, you can purchase it here.
Motorola Software Update provides the latest approved software for devices that are in warranty.
Please note that your device's warranty status will be automatically verified prior to proceeding with an update. Please also note that your device may already contain the latest software available for your product.
Motorola Software Update will notify you if an update is available once you download the update application and connect your device.
Thank you for contacting FixYa
*Please rate this solution with Thumbs Up
Nov 24, 2010 | Motorola Mobility ROKR E6 Smartphone
How to upgrade the firmware of MT6225 Nokia N97?
Hi. To upgrade your phone to the latest firmware, please follow instruction from Nokia's website.
How to update:
http://europe.nokia.com/support/download-software/device-software-update/how-to
Download device driver updater:
Good luck. Thanks for using FixYa.
Aug 17, 2010 | Cell Phones
Stuck on loading page
Hi!
I suspect that the software is corrupt in your unit.
Being a newer model, if it's still under warranty, contact humminbird or one of their service centers for repair:
Authorized Service Centers - Canada Bay Distributors
119 Progress Ct.
P O Box 70
North Bay, Ontario, Canada P1B 8G8
Tel: (705) 476-6010
Email: [email protected]
Mike's Reel Repair
#108-31060 Peardonville Rd
Abbotsford, BC V2T 6K5
Tel: (604)855-1119
www.mikesreelrepair.com
PTG Electronics Ltd.
3092 Portage Ave
Winnipeg, MB R3K 0Y2
Tel: (204)831-0862
Fax: (204-888-6207
Where to ship your items:
(if you live in the U.S.)
Humminbird
Attn: Service Dept.
678 Humminbird Lane
Eufaula, AL 36027
Who to call:
Toll-free: 1-800-633-1468
Monday - Friday
8:00am - 4:30pm CST
Apr 11, 2009 | Humminbird 997C SI COMBO W/TM GPS SENSOR,...
Need a manual
Humminbird - Support Your product is listed. However, when you click to download the manual, the page is not available. Fill in the question, for support.
Feb 16, 2009 | Humminbird Smartcast Rf 35 Dual Display...
Open Questions:
My Humminbird 997c SI is stuck in loading screen I had downloaded latest software updates for my Humminbird 997c SI and my 1197c SI.Then was attempting to update them one ata a time following typical software updates for these units like I had done in the past, resetting factory settings then running software update. My 1197c SI update perfectly with no problem, then moved up front to perform update on my 997C SI and went through same process as mentioned before. I turned around for less than a minute and turned back around to a black screen. When attempting to turn the power back on it started the loading screen and then stayed there for over an hour. I brought the unit inside and connected to the PC via USB cable and opened my HumminbirdPC. I made it to the Matrix Boot screen by holding the "View" button down and proceeded to toggle down to the #9 "Program" command and again pressed "View" to start to HumminbirdPC recognition sequence. My unit is not recognized by the software and the unit came back with a "Programming Failure" response. I have attempted this several times and even brought the 119c Si in to try,keep in mind the 1197C Si is up to date... However thinking that the 1197C SI would load and be rcognized, now both units have the "Pragramming Failure" response when trying to get Humminbird PC to recognize them!? I have my PC with Windows Vistaup to date as I just went through a 26 item update with windows, including service pack 2. I have all Drivers up to date, all Security updates and still no recognition. I thought maybe it was something with my PC... So I borrow my wife's work computer which is a Dell with Wi ndows XP and her company keeps it updated thoroughly. Same result... Then borrowed my Sons MAC that runs Parallels and has Windows 2000 on it. No Luck!! I have exhausted all ideas and could use some additional ideas if someone has any. Any input would be appreciated to get the 997C SI up to date. I have heard tha it is appx $200 to send it in to Humminbird and the new 998c is outrageuosly expensive. Thank you in advance for any HELP!?
May 29, 2012 | Humminbird 997c Si Combo Color Fish Finder...
Humminbird 997c Si Combo Color Fish Finder And Gps Chartplotter, Without Transducer Logo
526 people viewed this question
Top Humminbird Boating Experts
Bill Eager
Mike
ray gallant
Are you a Humminbird Boating Expert? Answer questions, earn points and help others
