RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
Kenneth Boucher Posted on May 28, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Vertical hold the picture flickers, or jumps, periodically
Anonymous
Level 3:
Top Expert:
  • RCA Master 14,553 Answers
  • Posted on May 29, 2012
Anonymous
RCA Master
Level 3:
Top Expert:
Answers
14553
Questions
Helped
2718523
Points
48227
No vertical hold control on the model listed here.
My RCA tv picture is jumping
Vertical jumping may have a vertical hold issue, horizontal may have a horizontal hold issue. Most older tv sets will have some knobs or adjustable screws for vertical and horizontal hold. Turn your set on and check for these knobs on the back of your set and adjust until your picture is in as well as you can get it
Sanyo dp26648 has sound, but has vertical lines w/picture popping in periodically.
change your device cables or try to put at a pc to check if isworking your pc
Its a zenith 27in the sound is good but the picture only shows a line across the screen
Make a fist with ur hand and bang on the tv bazel frame.The tv picture flickers back or bounces back to a normal picture.The tv have a vertical or a horizontal hold ics have coldsoldering joints and requiring resoldering.If u bang on the tv bazel frame picture don't flickers back or bounces back to a normal picture.The tv have a vertical or a horizontal hold ics are dead require changes those ics chips.If u don't have all the tools.Can't do a basic soldering work or able to changes those ics chips.Shop around for tv shops for estamate and repairing prices for repairing.
Picture shrinks to the center and start flickering
When Posting, its a good idea to always give the make and model number.
But it appears you have a vertical deflection problem.
being that is works for a while consistantly I am to believe it is just bad solder around the vertical IC.
If you give the model number I will assist you as to what the vertical ic is. :)
I have a Sanyo Model number DS25530 that has a Flickering Screen
well sounds like vertical issue take to tv shop vertical ic or bad caps
Sony Trinitron Colour TV Stopped showing and switch light flicker
The vertical output IC has failed/Power to the vertical IC is out/ or there is bad solder on the pins of the vertical output IC.
2answers
Westinghouse 27" lcd hdtv
My Wesinghouse 27" lcd hdtv jumps and vertical hold is out of control after being on 15 mins. The cable company checked the connection and it is clean. We did not damage the tv. It has been doing this since we got it. We did not get a service contract. Sometimes the screen goes black with a small rolling picture on top. Help me please. Can the maufacter still help us?
we lost all the papers when we moved.
Vertical hold problem
Maybe sync separator transistor is faulty
Jumpy picture
If this set uses a picture tube then your problem may be in the vertical deflection circuit. Also an unstable power supply will cause this problem. Stargazer
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
