What is the rca universal remote code for an element tv
We have an element tv and cannot find a universal remote that will work with it. How do we get it to work?
Posted by brenda_la203 on
    Top Expert:
  • Televison & ... Master
  • 76,466 Answers
Element is not listed to any RCA universal remotes.
Posted on May 29, 2012
Delia
1178 works for me ;), the batteries on the remote fall and to connect it to the tv i use that code RCA to Element ;)
Posted on Mar 27, 2013
alex_simp272
We have a emerson jumbo remote. Code 004 works
Posted on Feb 01, 2013
Frank Knarf
ON THE BACK OF MY RCA REMOTE PACKAGING IT SAYS THAT IT WILL WORK WITH ELEMENT BRAND OF TV
Posted on May 13, 2014
5 Related Answers
SOURCE: RCA universal 3 digit remote code for diamond vision TV
turn on your tv.Then push the code search button until the led still ,when the led keeps on let go the button now push and release the tv button then push and release the power button until the tv goes off,when the tv turn off stop to push the off button now push the set button the code are already set on the remote control( you might got to push the off button almost 100 times or more until you get the right code for your tv.Good luck
Posted on Aug 09, 2008
Anonymous
SOURCE: anyone have the code for a broksonic tv using an rca universal remote control?
I have a rca universal remote tried 191
Posted on Jul 03, 2010
Anonymous
  • 1124 Answers
SOURCE: RCA Universal Remote set to my Emerson TV
RCA Universal Remote Control Programming Codes Programming Your Universal Remote.
The remote may already be set up to operate your brand of TV, VCR, or Cable Box. It is pre-programmed with following codes:
  • TV-000
  • VCR-000
  • Cable Box-000
  • AUX is programmed with VCR code 037
For brands that require programming, there are two ways to program: Using Code Lists or Code Search. Use Code Search if the code lists are not available or if the codes from the lists do not operate a device.
Programming a Device using Code Search:
  1. Manually turn ON your device (TV, VCR, Cable Box)
  2. Press and "HOLD" CODE SEARCH
  3. Press and release the device button you want to set up (TV, VCR, Cable Box) However, if you are using AUX for a device, press and release AUX first and then the device button for the type of device to be programmed (TV, VCR, or Cable). The selected device button will flash once.
  4. Release CODE SEARCH.
  5. Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second).
  6. Once the device turns off, press and release ENTER.
  7. With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6.
Programming a device using the Code Lists:
  1. Find codes for each device and brand below.
  2. Press and "HOLD" CODE SEARCH.
  3. Press and release the TV, VCR or Cable button you want to set up. If programming AUX for a device, press and release AUX first and then the device to be programmed (TV, VCR or Cable). When the selected device button flashes proceed to the next step.
  4. Enter the three digit code from the TV, VCR or Cable Box code lists.
  5. Release CODE SEARCH.
  6. With the device on, press another button, for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-5 using another code number from the lists.
Emerson CODES 011,026,027,028,029,030 031,032,037,042,053,064 065,067,075,076,079
Posted on Oct 12, 2008
Anonymous
SOURCE: lost my manuel "codes" to my rca universal remote control crk74ba3
ineed manual code for rca universal remote for toshiba tv
Posted on Sep 27, 2009
robotek
Graeme Ross
  • 1512 Answers
SOURCE: need code for direct tv for my rca remot universal control rcu600d
The product you are trying to access may be called DirecTV(different spelling). You will need to find the make of your set top box used to decode the DirecTV and then look up satelite codes in the user manual for the remote to select the correct code.
the manual for the remote can be found at
http://www.remotecentral.com/cgi-bin/files/rcfiles.cgi?area=other&db=devices&br=philipsmagnavox&dv=universalremote&md=pm435&kw=pm435s&st=&ar=&dt=&so=&pg=1&file=others/philips/pm435-manual.zip
In case you dont have the book still. Good luck.
Any drama, get back to me here.
regards
Graeme
Posted on Jan 28, 2008
Need remote code list for my element tv
Element TV remote codes
Codes to operate your Element TV:
Newer codes 5 digit:
11886
10178
11687
12183
Older codes 3 digit:
046
005
028
043
048
076
096
155
004
051
127
151
153
154
231
236
238
247
252
168
121
ON MOST REMOTES:
1. Turn on the TV.
2. Press and hold the TV and SEL buttons simultaneously for 3 seconds. The button will light.
3. With the button lit, point the remote at the TV and enter the TV's 3, 4, or 5 digit code.
4. Verify by pressing the VOLUME + button. This should turn the TV VOLUME up.
5. Press the TV button to store the 3, 4, or 5 digit code. The button will blink twice to confirm the code is stored.
Your Element TV can be controlled with a universal remote and work with RCA remotes, Comcast, DirecTV, Charter, and more.
Jan 29, 2018 | Element Televison & Video
How can I program my RCA universal remote to my element tv , what button to press for the light to blink and the code to put so it can work on my tv
RCA does not have for a code Element TV. With that being said there is a work around:
Turn on your TV.Then push the code search button until the LED still ,when the LED keeps on let go the button now push and release the TV button then push and release the power button until the TV goes off, when the TV turn off stop to push the off button now push the set button the code are already set on the remote control( you might have to push the off button almost 100 times or more until you get the right code for your TV. Best of Luck
Aug 26, 2015 | RCA Televison & Video
Need a code for 19 inch Element FLW-1920B tv or a remote.
Check these codes.
003/ 004/ 009/ 022/ 133
0002 0014
Apr 30, 2012 | Televison & Video
I bought a Radio Shack universal remote. It does not list Element codes. I've done the suggestions but it doesn't work. What are Element's codes??
hello!
"Element" codes could be: Polaroid, MAG, LG, Vizio.
Have you tried "code search" mode on universal remote? If you won't find the luck of those "brands" I suggested, do "code search". Refer to remote's owners manual. I did the same for myself: obtained RCA convertor box, without remote, RCA codes won't work, RCA is out of TV business. By using "code search" I made it work. Then, you may want to do "code retrieval" option, to know the correct code.
good luck,
Alex.
Feb 16, 2012 | Televison & Video
I have a RCA model RCU703SPR remote control nad an element TV model ELDHT241 I need the code # to program the remote to the TV.
element is an emerson product try emerson codes 0236. I also have a code 11523 that has worked for some, then their are others who claim to use the goldstar codes for these. I have these for goldstar( 0004, 0009, 0005, 0227, 0338, 0012, 0057, 0080, 0156 ) Try one of these and see if you can get it to work. Element does not have a universal code published, but these solutions have worked for others.
Here is a link to a new remote for element tv's. http://api.viglink.com/api/click?format=go&drKey=256&loc=http%3A%2F%2Fwww.remotecentral.com%2Fcgi-bin%2Fmboard%2Frc-remote%2Fthread.cgi%3F9014&v=1&libid=1311639534146&out=http%3A%2F%2Fwww.newremotecontrol.com%2FMfrs%2FOtherBrands%2FDef%2FOtherBrands.php%3Fbl_brand%3DELEMENT%2520ELECTRONICS&ref=http%3A%2F%2Fwww.google.com%2Fsearch%3Fq%3Duniversal%2Bremote%2Bcode%2Bfor%2Belement%2Btv%26rlz%3D1I7DKUS_en%26ie%3DUTF-8%26oe%3DUTF-8%26sourceid%3Die7&title=RC%20Forums%3A%20Need%20code%20for%20Element%20TV&txt=newremotecontrol.com
These also claim to have worked. 1431 and 1343, some element tv's respond to code 10178 in the white directv remotes, then that equates to code 0128 in the peanut remotes.0011 also has worked for some. But 0128 seems to work for most folks.
Jul 25, 2011 | RCA Televison & Video
I NEED PROGRAM CODES AND PROCEDURES FOR RCR312W
I can help. I too have an RCR312W remote and it did not work.
I found this code on bobvila.com message board. The code from the RCR311W remote works.
1) turn on unit
2) press and hold componet button on remote (TV, VCR, etc)
until On/Off lights up
3) press and hold On/Off while holding component button. Light will go out. Continue hoding both buttons until light comes back on.
4) release both buttons. On/Off should stay on.
5) Press On/Off repeatedly until unit turns off.
6) Press the Stop key at bottom.
7) light goes off. Remote is programmed!
Oct 17, 2008 | RCA Universal Remote Control
Televison & Video Logo
7,367 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
