Question about Mad Catz PS3 Bluetooth® Headset Wireless Headset
Madcatz bluetooth Item#88606 user guide
There is a buzzing sound and people can't hear me
Daniel T Craddock II
    New Friend:
I can not get the device to work with anything,phone or my pc . how do I get this device to connect with anything. It was sopposed to be rebuilt . I have noway to send it to be fixed. can you help. [email protected]
Posted on May 12, 2013
1 Related Answer
Anonymous
  • 40 Answers
SOURCE: My MadCatz PS3 Bluetooth is
On the PS3 try going to Settings -> Accessory Settings -> and see if you can turn up the voice volume. Another option is to have Voice Chat played through the TV instead of the headset.
Also check the settings of the game you are playing to make sure it is not turned down.
Hope this has been helpful!
Posted on Mar 06, 2011
Motorola elite flip Bluetooth. Lost the manual. I can hear people but they can't hear me very good. They say I sound muffled.
Hello
I would recommend you to do a reset to the device, here is the link of the user guide so you can perform the reset.
http://bit.ly/1GRqnxc
Regards
Kenny
Motorola Support
Make noise
I'm sorry but intermittent noise is like telling your mechanic you hear a rattle somewhere in your car. Like that poor mechanic, I'm going to take a stab at your problem. Check pages 6-8 in the user guide below and see which "noise" best fits your situation. You can generally fix it by powering down your headset and then powering back up (instructions are in the same guide).
Plantronics Explorer 240 User's Guide
Good luck from Headsets Direct!
1helpful
Bluetube is connected to my cell phone but I can't hear anything
There may be linking issues between the headset and the phone. Page 11 of the user guide offers these suggestions. Also, here is a link for re-pairing your headset to the phone:
Plantronics Explorer 230 Pairing Instructions
Remember that you want to purge any possible bluetooth interference from your phone.
"Callers cannot hear me or I cannot hear caller/dialing tone:
The headset is not turned on or the headset is not connected to mobile phone. Press the call control button for 2 seconds until you hear a beep or see the indicator light glow blue to turn headset on.
Your headset is out of range. Move the headset closer to the phone or Bluetooth device.
Your headset battery is drained. Charge your battery using the AC power adapter supplied.
The listening volume is too low. Press the volume key up (toward the earloop) to increase the sound heard in the headset."
1helpful
How to connet bluetooth on nokia 5230
Bluetooth is a wireless technology that allows devices to communicate via high-frequency radio signals. Bluetooth headphones are just one of the many devices designed to work with portable music devices as well as ordinary phones. With Bluetooth headphones, you can listen to music as well as make and receive calls--all from the same device. Connecting them is a snap.
  • Turn on your cell phone. Enable Bluetooth by accessing your phone's general or network settings. Your phone will search for Bluetooth signals in the area--they are usually denoted by a small icon displayed on the screen. If you don't know how to turn on Bluetooth or aren't sure whether your phone supports Bluetooth technology, refer to your phone's user guide.
  • 2
    Turn on your Bluetooth headphones while near your cell phone. Turning on a Bluetooth-enabled device will usually put it in pairing mode, meaning it is actively searching for a device to connect to. Since your phone also is actively searching for a Bluetooth device, it should find it right away and prompt you to connect to it. It may ask for a password--refer to your headset's user manual for the default password and how to change it.
  • 3
    Test your connection. Once your headset is paired, the phone will usually start sending calls and audio to it without any additional configuration. Some phones may prompt you and ask which device to use. Try making calls and/or playing music. If you hear music from only one ear, your phone may not support stereo Bluetooth. If you don't hear anything, re-pair the headphones. Power off your phone and headphones, then turn them back on and repeat steps 1 and 2.
  • 0helpful
    Need manual for Panasonic RQ-335 recorder... LOUD SOUND WHEN I TRY TO USE. Not used in years... cannot play anything... just real loud buzz sound. Help
    Try
    mauritron.com
    They have the world's largest library of
    owners user instructions operating guides
    and
    technical repair schematics circuits service manuals
    I'm not connected to them, just a satisfied user.
    Also if you don't find your item in their listing then ask and they will get it for you
    1helpful
    How can i connect my bluetooth headphones
    Things You'll Need
    • Bluetooth capable phone
    • Bluetooth headphones
      • 1 Turn on your cell phone. Enable Bluetooth by accessing your phone's general or network settings. Your phone will search for Bluetooth signals in the area--they are usually denoted by a small icon displayed on the screen. If you don't know how to turn on Bluetooth or aren't sure whether your phone supports Bluetooth technology, refer to your phone's user guide.
      • 2 Turn on your Bluetooth headphones while near your cell phone. Turning on a Bluetooth-enabled device will usually put it in pairing mode, meaning it is actively searching for a device to connect to. Since your phone also is actively searching for a Bluetooth device, it should find it right away and prompt you to connect to it. It may ask for a password--refer to your headset's user manual for the default password and how to change it.
      • 3 Test your connection. Once your headset is paired, the phone will usually start sending calls and audio to it without any additional configuration. Some phones may prompt you and ask which device to use. Try making calls and/or playing music. If you hear music from only one ear, your phone may not support stereo Bluetooth. If you don't hear anything, re-pair the headphones. Power off your phone and headphones, then turn them back on and repeat steps 1 and 2.
    Jun 12, 2011 • Cell Phones
    2answers
    User has a iCom Bluetooth Hearing Aid adapter paired with her Plantronics Voyager 500A base station on a Cisco 7940. When on an active call and she receives another incomming call, her current call is...
    Make sure that the Plantronics 500A base inteli-sensor switch is set to the number one setting (should be set on the one line, not the two line setting, on the right side of the 500A base unit). Also if you are using an EHS (Electronic Hook Switch) instead of an HL10 Handset Lifter, that could be the issue as well. The only other thing is to check the user guide for the hearing aid and make sure that there is not an "auto answer" setting that may need to be turned off. Here is a link below for the 500A / 510S user guide.
    Plantronics 500A/510S User's Guide
    My MadCatz PS3 Bluetooth is on and fully charged, however, I can't hear a thing. Others online can hear me, and it registers as making sound, but then I can no longer hear the other players. What could...
    2helpful
    I cant figure out how to talk
    The instructional booklet that came with your MadCatz item usually explains what you need to do. If it didn't come with a booklet, try charging it, then syncing it with your PS3 using the PS3's bluetooth sync capability.
    My headset from madcatz wont do anything
    I may be able to help you.
    You may want to review this guide for connecting a bluetooth headset to a PS3:
    (Click here)
    http://boardsus.playstation.com/playstation/board/message?message.uid=26900460
    If you found this information helpful, please give me a big thumbs-up when you rate my answer. Thanks!!
    Mad Catz PS3 Bluetooth® Headset Wireless Headset Logo
    Top Mad Catz Radio Communications Experts
    eradiostore
    eradiostore
    Ekse
    Are you a Mad Catz Radio Communication Expert? Answer questions, earn points and help others
