Question about JVC HD-52G786 52" Rear Projection HDTV
My jvc hd-52g786 does not recognize the remote. What do I replace?
I have tried replacing the remote a few times. I have used the original remote and a few universal remotes. none of which work. How do I fix this problem?
Posted by christopher on
SD Tech
    Top Expert:
  • JVC Master
  • 14,553 Answers
The set has a receiver inside that the remote transmits a infrared signal to--if remotes known to be good do not work on set the receiver is bad.
Posted on May 29, 2012
2 Related Answers
Anonymous
SOURCE: JVC HD-52G786 shuts off
Do you have your TV plugged directly into the wall? You cannot plug into a power strip, it needs its own direct power source. Also, I have heard that there can be electrical problems inside. I have this same model, I love it, picture and sound. I just replaced the bulb for the first time last night. It was a little premature to replace it now but I know what caused it. I bought a new bulb and it works like a gem. If you ever need to change the bulb do it yourself. It takes maybe 2 minutes. The bulb looks like the Flux Copassitor and all you do is remove the door in the back on the side. Unscrew the the 2 screws that hold the bulb in and just pull out. When you put the new one in make sure you do NOT touch the glass on the new lamp. Just slid it in and screw the 2 screws back in and make sure the door is closed and tight. My uncle had a service guy do his and he got raked for 5-$600, The bulb costs about $200. Should last about 5-6 years at a rate of 5-6 hours of TV on time. Hope this helped. If not, sorry, but at least you know how to change the bulb. Good Luck!!!
Posted on Apr 08, 2008
Anonymous
SOURCE: JVC HD-52G786 Service Mode
Sure. I'm not sure if you can do it without the original remote, though. On my remote, you need to have the tv turned on, then press the sleep timer, then press the display and video status buttons simultaneously. This enters the service mode. Then, you should see an option for self-check (#2 i think). Enter that, then you should see 2 vertical columns of different inputs. From that screen, power the tv off. This resets all the ports on the tv.
Posted on Jun 20, 2008
How to replace a lamp on my jvc tv
If you haave the original manual, this is discussed at the start of page 91. If you dont have manual, it can be obtained at books.jvc.com
1. Purchase lamp TS-CL110UAA
2. Turn Off and unplugg set
3. Remove lamp cover located on the left side of TV
4. Remove and replace lamp
5. Reset lamp counter in menu for accurate hour information.
Jul 26, 2014 | JVC HD-52G786 52" Rear Projection HDTV
Picture has progressively darkened over the past few months. Replaced the lamp which did not help. Next place suggested replacing te lamp ballast which did not help either. Now I'm being told it s
You might want to talk to JVC as this model had all kinds of issues--missing any color, picture inverted or backwards just to mention a few.
The solution was to connect it to a computer and use a jig from JVC and download two up grades on sd cards and install them manually.
I mention this as the Light engine in the set communicates with the main chassis and you in fact may have a issue with that.
At least make a call to JVC---saw about 40 sets with this model where this cures all sorts of communication issues--the engine if "set" wrong could easily cause this problem.
Dec 19, 2012 | JVC HD-52G786 52" Rear Projection HDTV
Can't get volume on jvc hd 52g786
This set is prone to the audio board inside failing---all the audio is on one board, last one I replaced was just over 100 dollars.
Oct 30, 2012 | JVC HD-52G786 52" Rear Projection HDTV
My jvc HD-52G786 TV channel will freeze then
most likley you need to see ure dealer about that as it cost to buy the program and the cord just to do an update every 2yrs
Apr 27, 2010 | Televison & Video
How do I replace the bulb on JVC HD-56G786?
Lamp replacement procedure is written in instruction manual of TV page-93 and if you need copy of same, click JVC Support.
Jun 18, 2009 | JVC HD-52G786 52" Rear Projection HDTV
No picture
The lamps life span is 1 - 3yrs, Purchase your lamp directly from JVC.com $199 they back up there products. Good luck
Jan 27, 2009 | JVC HD-52G786 52" Rear Projection HDTV
JVC HD-52G786
you will need to have a tech come out to do a convergence( replace chips and resistors)they control the vertical , horizontal and color alignment
electech
Oct 31, 2008 | JVC HD-52G786 52" Rear Projection HDTV
Jun 18, 2008 | JVC HD-52G786 52" Rear Projection HDTV
Jvc hd-56g786 hdmi black screen
how do i get into my service menu to powerdown; please explain
Dec 31, 2007 | JVC HD-52G786 52" Rear Projection HDTV
Convergence
Sounds like your convergence amp may be failing. If you replace it, you'll need to replace both at the same time.
Jan 12, 2007 | JVC HD-52G786 52" Rear Projection HDTV
JVC HD-52G786 52" Rear Projection HDTV Logo
116 people viewed this question
Top JVC Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Todd Hill
Todd Hill
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
