Cars & Trucks Logo
Anonymous Posted on May 28, 2012
Whirlpool interior light won't shut off
I unplugged it to paint behind. when plugged back in, interior light won't shut off. tried open and closing door, locking and unlocking the oven, pressing the oven light button, also unplug and plugged back in, it's stays on. is this because i did not set the clock when i plugged it back in?
  • Anonymous May 28, 2012
    THIS IS NOT A CAR, OR A TRUCK!!!! WHY IS MY OVEN QUESTION POSTED UNDER THIS CATEGORY EXACTLY?????
Anonymous
Level 3:
  • Master 4,803 Answers
  • Posted on May 28, 2012
Anonymous
Master
Level 3:
Answers
4803
Questions
0
Helped
2961124
Points
18833
That is a really good question....what category did you post it under?
2 Related Answers
Anonymous
  • Posted on Mar 04, 2010
SOURCE: Our 2004 Jeep Grand Cherokee is having a door
Broken wire in harness feeding door, see other posts
tayjoejoe
Joe Taylor
  • 2229 Answers
  • Posted on Aug 19, 2011
SOURCE: 2003 Monte Carlo SS, FOBS
If the passkey is messed up, there will be a light on the dash that says security, or have a picture of a car with a lock thru it. If there is no light when the key is turned forward, then its NOT a passkey problem.
2012 Equinox dome light won't shut off
one of your door switches is bad or not making contact with the door frame
Eagle vision 1996 interior lights won't turn off
hello , you have to replace the interior light delay relay
2answers
Courtesy light trigger
If the interior lights won't come on with either door open, you might have a blown fuse or the overhead light may be switched off.
Parts book shows a door jamb switch for each door.
My lights on my 1996 caravan won't shut off until the timer shuts them off and they turn on when any door is opened
You are talking about interior lights, right ?
As long as the on-time is under a minute or two, its normal.
The lights are supposed to go off as soon as you start the van tho.
Interior light won't come on when I open the front doors
If you have tried to adjust your interior lights with your dash light adjuster, and it didn't work, I would say you either have a bulb out, or a blown fuse. Hope it's something simple for you. GOOD LUCK
Interior roof lights won't go off
This can be caused by a door or trunk being ajar, be sure you shut all doors firmly, if there is still no resolve check by shutting all doors then open one up and press the button (if any) on the inside of the door jam and see if it is broken or the light goes off.
Interior lights won't go off after shut down
Hello
There are switches in the door, check to be sure the wire didn't get broken otherwise it's most likely a bad switch there.
Best regards,
Ck
1helpful
1998 Ford Windstar Minivan: 1. I sometimes get an extended crank when trying to start engine after I've made a short trip. 2. My interior lights won't go out after I turn the engine off, so I...
YOU MAY HAVE A BAD DOOR AJAR SWITCH. HOWEVER, YO HAVE A TIMER THAT SHUTS OFF THE INTERIOR LIGHTS AFTER 300 MINUTES. IT'S CALLED A BATTERY SAVER FEATURE. TEST IT OUT.
THE EXTENDED CRANK MAY BE A CHECK VALVE IN THE FUEL PUMP IN THE TANK, ALLOWING PRESSURE TO DROP WHEN YOU TURN THE ENGINE OFF.
OR A BAD FUEL PRESSURE REGULATOR ON THE ENGIEN FUEL RAIL.
TRY THIS TEST, TURN KEY TO "ON" POSITION, WAIT 5 SECONDS, SHUT OFF KEY FOR 30 SECONDS. TURN KEY ON, WAIT 5 SECONDS, THEN START ENGINE. IF IT STARTS RIGHT UP, YOU ARE LOSING FUEL PRESSURE WITH ENGINE OFF.
THIS BUILDS UP PRESSURE IF IT DROPPED DURING SHUT DOWN.
REPORT TEST RESULTS.
PLEAE RATE, THANKS
5helpful
Replacing rear brake light bulb
Carefully remove the two trim plugs from each tail light assembly with a small knife blade. Remove the two hex head bolts on each assembly. Insert a small paint stir stick (soft wood won't damage paint) between the fender and the tail light assembly. Gently pull the opposite (inside) side of the assembly off. The paint stick allow the assembly to pop off the ball and socket pin holding the outside part of the assembly in place. Unplug the power plug by releasing the retainer clip. Unscrew the large black plastic nuts on the back of the assembly with a very large screwdriver, if they can't be turned by hand,and remove. Replace burned out bulb/s and reassemble in reverse order. Remember the trim plugs have two prongs on them. Position them with the prongs and the direct top and bottom and press into place.
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
