Hisense do make Service Manuals available, but there isn't one online for that set. Contact them direct in your country. We are Fixya, not Hisense, we just have a Hisense category.
Open your TV/s back cover. Pull out the printed circuit board. Place it at a convenient position. Locate the vertical output section. Locate the vertical output IC. Desolder it out from the board. Replace a good one in place. Solder all its solder terminals. That is all.
USALLY FLASH 7 IS SC BOARD ON SC BOARD THERE ARE MANY MOSSFETTE TRANSISTERS THAT ARE SHORT CHECK TO SEE IF YOU HAVE SHORT TRANSISTER IS YES REPLACE SC BOARD 150 DOLLARS DONT FORGET TO MAKE FIRMWARE UPDATE OR PROBLEME WILL COME BACK !!!!!!!FIST PICTURE TRANS SECOND C BOARD
Try emailing [email protected]. Also visit his website at http://weltenschule.de/TableHooters/index.html. Look at the TableHooters modification FAQ. He has some good info on circuitry and components. I hope this helps somewhat.
There should be circuit designations printed on the PC board. Without those, there are too many possibilities to give you anything useful. Can you provide those please?
check on crt board green amp transister and associated ckt should be short. or green drive transister,or main jungle ic which drive green signal is sure defective, i had the same problem in rca 32 inch tv for all screen red,replacing chroma ic solved the problem.
