Question about Samsung RS2530B Side by Side Refrigerator
Samsung rs2530b refrigerator making loud noise...why?
Loud humming noise from freezer fan. My husband is currently disassembling the freezer to get a better look.
Posted by Cherese Tardy on
Daniel TheDutchOwner Oosterhuis
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 32 Answers
It might have dust in it. It can drain the fan speed, which makes odd sounds. It could be something else jammed in there too. Clean the fan and see if that works.
Posted on May 28, 2012
Whirlpool Side by Side. Husband replaced fan motor inside freezer. Ever since it's been replaced, it runs frequently and hums loudly. Any suggestions. He took the interior back out and it doesn't hum.
The fan blade touching the interior back cover????
May be the fan motor shaft is too long or may be he did not push the fan blade well inside into shaft so it is to much out. Thus touching the wall cover plate..????
Sep 24, 2014 | Whirlpool Refrigerators
Loud humming noise
Have you had the noise before or did it just start?
Try to isolate where the noise is coming from. From under the fridge? On the back wall of the freezer side? If those two, could possibly be one of the fans.
Dec 03, 2013 | Whirlpool ED5GHGXMQ Side by Side...
My Maytag MFD2560HES bottom fridge is making a loud humming noise.
Any time there is the sound of humming it is important to locate where the noise is coming from. Sometimes fans wear to a point that at one speed the sound as if humming. Sometimes compressors hum with more catastrophic results. Because your model is a bottom freezer it would be a good idea to open drawer to freezer and see if the sound is from fan in freezer or if pulled away from wall is the sound the fan or compressor area? I believe I will be able to locate a service manual but I will need you to help me pinpoint the location of the loud sound so we can get the sounds back to normal. Let me know if you are able to try that and what you find, Sea Breeze
Mar 23, 2010 | Maytag MFD2560HES Bottom Freezer French...
My fan in my freezer makes a humming sound
it;s best to replace the fan / or find why the noise . it will probably stop due to this problem. and you may loose food . noises generaly are the first clues . and like i'v said before . if you can hear it it's running . but if your cant it may have quit . . then not cool and food loss . **** / hope this helped mm / feed back pls .
Jan 16, 2010 | GE Hotpoint Top-Freezer Refrigerator
The ice fan is making a loud humming noise
Hello and thank you for using Fixya's services.
I am not an expert in this field but I did have the same exact problem and called a service technician. There was huge block of ice in the back panel of the freezer.
Get everything out of the freezer and take the panel off the back (inside of freezer) with a screwdriver. Look by the fan and check the bottom to see if there is a build up of ice. You can pry it off or take the blowdryer to it.
Please take precaution when doing this and I would unplug the fridge just to be on the safe side.
We paid $180.00 for someone to do this....if I would have known...lol. The technician did tell us we would need to replace the fan eventually but we haven't yet. I would say that it hums (loudly) every six months and we (my husband) have to repeat the steps above.
Hope this helps!
Nov 19, 2009 | LG LFX23961SW Bottom Freezer French Door...
Loud humming noise
Stick you hand in the freezer, touch the back wall of freezer, see if you feel a strong or lite vibration equal to the hum you are hearing. If so, the you have a bad evap fan, if not then pull unit out from wall and see if hum is load toward the bottom rear portion of the frig, if so contact a repair tech.
Oct 01, 2009 | GE GSS25JEMWW Side by Side
Ge eterna refrigerator loud humming
suspect you have a problem with the defrost system and hence the noise with the fan. take back panel off inside the freezer and if i'm right, melt ice off with a hairdryer. get back to me to say the results if you want
Aug 23, 2008 | GE Profile PSW26P Stainless Steel Side by...
Loud humming noise as fridge is running
Sounds like the freezer fan is rubbing some wires or possible some foam insulation around the fan. I would look into the freezer compartment fan and go from there. The fan Will Shut off when you open the doors. Let me know how you make out and if you need anymore help.
Thanks,
Bill
Apr 27, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Samsung RS2530B Side by Side Refrigerator Logo
520 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Michael Thomas
Michael Thomas
jasbo
jasbo
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
