SOURCE: delonghi magnifica eam 3200 won't descale
we are encountering some connection problem that's teh reason why our converastion are always in cut.
if you read this let me know here i can help you to solved your problem.
thanks,
SOURCE: Coffee machine Delonghi Magnifica grinding function not working
There are two reasons for this usually. Either the grinder is jammed or the grinding wheel or wheels have broken. Your machine needs to go to a repair shop to be looked at.
SOURCE: where can I get the parts for delonghi magnifica
Howdy:) You can get parts and accessories for your Magnifica here: http://www.delonghiusa.com/index.php?texts&pid=15
Hope you are up and espressing asap:)
SOURCE: We understand that your problem
Based on the information provided above the machine is a bit old as 3 years of regular use is quite a while. If the frothing wand is the only part of the machine which leaks water it can be presumed that a replacement of the part is in order.
It will be advicable if you can afford a new machine to get a new one otherwise get an expert to replace the frothing wand and run a general service of the entire machine.
Water leakages around electrical appliances are very dangerous and the consequences are always disastrous. So ensure that either the device is handled by an expert or replace the unit completely.
Hope this solution has been helpful?
SOURCE: delonghi magnifica rapid cappuccino model EAM
try cleaning any old bean dust ect with vacuum ... refit or replace infuser lot better . if still no good you need someone to check pcb assy ... bsc appliances 07779933829 we cover repair service anywere via post.
