Question about Black & Decker Vector Cable Kit for 1200 Watt Inverter
Manual for black and decker 1200 watt invertor
Looking for the wiring configuration for the accessory port on the vectore 1200 watt invertor
Posted by drledet390 on
binay biswas
    Master:
  • 407 Answers
Some idea for inverter, collect inverter circuit Books from market.
Posted on May 28, 2012
3 Related Answers
al_kupchella
Al Kupchella
  • 843 Answers
SOURCE: I bought a new Black and Decker 200 watt power
Most power inverters supply a modified sine wave output. This is different from the true sine wave you get at home. It's close enough for many applications, but not close enough for many transformers, which is what your laptop power supply is. So the problem is that your laptop's power supply does not work with a modified sine wave input. Some will, some won't. Very common problem.
Posted on Aug 23, 2010
Anonymous
SOURCE: Vector 2000 Max inverter VEC054D turns on, LED
sounds like my inverter im going to change the mofset or.triod it has 3 prongs.
Posted on Jul 27, 2009
Anonymous
SOURCE: Describe your Black &
I have a black and decker 100 watt power inverter. When the led turns red you are ethier overloading it or it overheated. to fix it unplug it and let it sit for 5 minutes. Plug it in. Plug in an item rated for 100 watts or less. Or try to charge somthing on the usb port.
Posted on Jan 03, 2010
11Kw pioneer VF-5000 inverter
please send me the user manual for vf-5000(11Kw)?
Jun 23, 2014 | Black & Decker Vector Cable Kit for 1200...
Where can I order a replacement charger for vector trailtracker sport lantern/weather radio model VEC 1198POB
If charger can be taken apart and the battery removed, try Batteryspec.com for a replacement battery. Worked for my Vector.
Aug 15, 2013 | Black & Decker 50 Watt Electromate with...
With the vector 2000 watt converter do you need to run 2 batterys.
well unless you bought the 24 volt unit no one battery will run the unit, according to black and decker this unit is not being made, did you buy it new or at a yard sale?
one way to tell is look on bottom of unit, it will tell you if it is 24 or 12 volt model.
Mar 06, 2011 | Black & Decker Vector MAXX SST Series,...
I need a replacement charger cord for the Vector 3 Million. I live in Birmingham, MI. Where can I order this from?
In March, 2006, Black & Decker purchased Vector Products, Inc. Since the acquisition, Black & Decker has assumed the manufacturing of all Vector products. For customer service and warranty information for Vector products, please contact Black & Decker Customer Service.
Oct 01, 2010 | Vector 3 Million Candlepower Rechargeable...
I Have a Vector VEC011 Jump Start System and the battery has gone bad. Where can I find a replacement battery (12V, 9A) with Bolt on bus Terminals
Or, you may find a replacement battery here: http://www.batterywholesale.com/battery-store/SLA-batteries/
Sep 25, 2010 | Vector Manufacturing Simple Start Battery...
Good day I've had the unit plug in for 48 hrs and
Aug 08, 2010 | Vector Manufacturing Simple Start Battery...
Batt wont hold charge
Aug 05, 2010 | Vector 1 Million Rechargeable Spotlight
I have a vector 3000 watt inveter red fault light is on, wont power a 6.5 amp fuel pump
Check that ground is correctly connected. If nuetral is provided, ensure it too is connected. Your total load is 780 watts. Check power in and ground out of the supply side. There may be a fuse in the inverter on the output side also, replace if necessary. If fault light does not go out after these checks, you will need to contact Black and Decker who manufactures the vector series now.
Jan 16, 2010 | Vector Power Inverter - 3000 Watt
Fan does not work.
Two things...one the fan only workk when the unit get hot or you created short the inversters are very sinsative and if you make mistake you are dead...see try it for ferw min and see...but first try to reset the unit and that by disconnecting the negative and positive from the back and turn the unit on to get all charges in the unit out then reconnect the cables do not forget to ground the unit to avoid sparks.
Sep 09, 2009 | Vector VEC053D 1200-Watt Power Inverter
Black & Decker Vector Cable Kit for 1200 Watt Inverter Logo
195 people viewed this question
Top Black & Decker Electronics - Others Experts
Sheldon Dedek
Vernon Taylor
Are you a Black & Decker Electronics - Other Expert? Answer questions, earn points and help others
