Question about Sony Cyber-Shot DSC-W7 Digital Camera
Memory Stick Problem!
When I turn on my Camera it says "Memory Stick Locked." I can't access my pictures or take pictures. How do I unlock it?
    New Friend:
I have same problem but when i try it and find out some reliable sources
funchowk
onlinesolutionproviders
Posted on May 28, 2012
I cann't access on my compture
if you are using it in a cellphone it is probably locked, try to find in your device memory card settings and unlock it
if it is from camera, try to download data via camera cable, then format it in your computer, then it should work in both devices
Jun 21, 2013 | Sony 1GB Memory Stick PRO Duo Memory Card
Can't find pictures in internal memory
If you can connect the camera to your PC via a cable, normally USB, to browse the contents of the camera's internal memory then try simply to do a search on the camera's 'drive' for .png, .jpeg or .jpg, .bmp or any other filetype that your camera would use.
Your PC should be able to find any files using those file types and display them. From there you can copy or cut and paste them to a location on your PC's hard drive.
You may have to make sure that your computer has Show Hidden Files and Folders turned on under Folder Options.
Normally, a camera saves all videos and pictures in a folder called DCIM, even on internal storage.
Jul 05, 2012 | Kodak EasyShare Z740 Digital Camera
My camera says the memory card is locked and memory card error appears when I turn on the camera. I've read that I have to format the card, but won't the photos be destroyed? How can I get my pictures
There is a tab on the memory card so you will you need to remove it from the camera and change the position of this tab to "unlock" it. DO NOT format the card until you've BACKED UP your files from it (typically to a PC or USB drive (stick or external hard drive).
Nov 18, 2011 | Canon PowerShot SX130 IS Digital Camera
Memory Stick Duo 512MB. Where are no pictures on the card, but it says that "were is no space" when I put it in the camera. What should I do?
First make sure the card is not locked. Do this by checking on the side of the card that the lock notch is not in the locked position. If it is not locked then you should put the card in your computer and reformat it. If this isn't successful then its time to go get a new card. You can get a new one for under $20.
Aug 26, 2011 | Sony 2GB Memory Stick PRO Duo Memory Card
I can't take any more pictures because my EasyShare Z981 says my "internal memory is full." How can I fix my camera so I can continue taking pictures?
I'm assuming you have a memory card inserted into your camera? You can use SD or SDHC cards up to 32GB in size. Then, if you look in your camera's manual (direct link if you don't have yours... http://resources.kodak.com/support/pdf/en/manuals/urg01118/Z981_xUG_GLB_en.pdf ) you can see on page 36 how to copy an image from your internal memory onto a memory card. Also, on page 45 you can learn how to use the menu to tell the camera to use the memory card instead of the internal memory. Good luck!
Aug 25, 2011 | Kodak EasyShare Z981 Digital Camera
When I insert my memory card into my printer, all that pops up is "Memory Card Error." I really want to get my pictures off of the memomry card and into my computer, so this is getting pretty...
make sure that the card is not locked, there might be a little tab on the side of it that slides up and down. If doesn't work, it probably needs to be reformatted once you get all your pictures off of it. (you will lose everything) When reformatting it, make sure that you use the FAT or FAT32 setting.
Jun 04, 2011 | Cameras
I had just completed downloading my pictures and movies from the camera unto a dics. as i always do, after i completed downloading, i delete the pictures from the camera. at the completion, the camera...
Do you remember to use the "safely remove hardware" function when you disconnect? Most times, nothing goes wrong but it only takes once for your current problem to happen. My advice would be to reset the camera. The "reset"command can usually be found in the camera menu.
Jan 13, 2011 | Cameras
My Sony Cyber-Shot camera keeps showing "access" and won't go away. I've taken about 20 photos that show up on the camera, but when I try to download them on to my computer, it says "no...
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
After downloading the pictures to your computer, place the memory card back into the camera and format it.
Nov 12, 2010 | Sony Cyber-shot DSC-W30 Digital Camera
Sony Cyber-Shot DSC-W7 Digital Camera Logo
35 people viewed this question
Top Sony Cameras Experts
Vish Iyer
Vish Iyer
 Larry
Larry
 MikeWang
MikeWang
Are you a Sony Camera Expert? Answer questions, earn points and help others
