Question about Garden
Troy Bilt 8000 watt generator is not puting out full 120 Volts after converting to run on propane.
Converted to use propane, generator does not put out 120 volt
Posted by Robb Simer on
  • Robb Simer May 29, 2012
    Will speeding up the egine raise the output of the generator?
mike butler
    Brigadier General:
  • 6,468 Answers
If the rpm's are not right the voltage regulator can't put out more than its putting out
Posted on Aug 12, 2012
2 Related Answers
Anonymous
  • 113 Answers
SOURCE: replacement blades for Troy-Bilt chipper-shredder
The knife kit for the 47042 and 47044 Tomahawk Pro chipper is part number 1772231MA.
There are several for sale on Ebay or from a Murray dealer
Posted on Aug 18, 2010
freders0
  • 6 Answers
SOURCE: finding a shredder screen for troy-bilt
contact Fred at [email protected] or 651-786-4277 he had them made
Posted on Oct 17, 2009
Won't start. Just put in a new spark plug and fresh gas. filter is clean and so is the oil
Take it back to the dealer. These small units have a 12 volt DC
generator that is internally converted to 120 volts AC. As such
they are fairly complicated.
May 17, 2015 | Honda Eu-1000i Inverter Generator
Honda eu3000is generator surges
Inverter Generator Benefits
  • The EU3000 series generators are inverter generators. The generator features an alternator, which produced high-voltage, multi-phase AC power. This power is converted to DC power and then converted back to AC. This process is controlled by a microprocessor and is necessary to provide stable, consistent power capable of running equipment sensitive to power surges. This type of generator provides higher fuel efficiency and lower operational noise ratings in a lighter model than home and work generators produced by Honda.
EU3000i Handi Specifications
  • The Honda EU3000i Handi is a 3,000-watt inverter generator that features wheels, folding handle and a recessed convenience light. The engine is a Honda GX160, which features a 163-cc displacement. The AC output is 120 volts, with an average rating of 2,600 watts and a maximum production of 3,000 watts. There are three receptacles to include a 20A, 125-volt duplex and a 30A, 125-volt locking plug. The DC output is 12 volts and 100 watts. The EU3000i can hold 1.56 gallons of unleaded fuel, which will provide consumers with 3.6 hours of run time at 25 percent load for 7.7 hours.
performance chips of BMW.
May 31, 2012 | Honda Eu3000is
My generator is not putting out the proper voltage? it's only putting out approx 75 volts on the 120 volt circit. i adjust the idle to full out and i get approx 112v.
Most low voltage conditions on generators are simply due to a low engine rpm. Most modern generators are 2- pole windings. So your engine rpm should theoretically run @ 3600 rpm. which will produce 120/240 volts @ 60 HZ. In actuality You want to set your rpm's @ Approx. 3720rpm no load. About 62.5 Hz. Without getting to technical this will give you your desired 120/240 volts loaded. Hope this helps.
Aug 09, 2010 | Northstar Electrical Supplies
Hi output from generator
I found out that the gasoline motor was turning too fast so I had to turn down the speed of the motor with the adjustment screw.
Sep 06, 2009 | Northstar Generator 9 Hp, 5500 Watt,...
Yamaha Generator YG 4000 Dies when load is applied.
turn the throtle knob to while checking voltage & hertz
Jun 05, 2009 | Reliable Yamaha YG4000D 4000 watts/33.0...
Propane-converted generator sometimes sputters out and dies
I believe the problem may be with the propane. Have him call his propane provider and get them involved. good luck
Dec 26, 2008 | Coleman Powermate Premium Plus 6250W...
Coleman Powermate Generator 4600 series
Starts Generating 120 volts and whitin 30 seconds is putting out 0 volts, and the generator has high speed
Feb 19, 2008 | RIM BlackBerry Pearl 8100
Garden Logo
226 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
