Question about Sony DVP-NC80V DVD Player
Sony DVP-SR401HP Bought the DVD player today. It is hooked up as per directions but disc drawer does not respond to ope/close on the set or the remote.
5 Related Answers
bestdarngood
Benjamin Patri
  • 3037 Answers
SOURCE: Sony DVP-NC675P Multi-disc DVD player will not play dvd's
have you tried cleaning the laser at all?
Posted on Apr 05, 2008
Anonymous
SOURCE: Sony DVP-NS67P DVD player problem
Hi I also have a NS67P and I'm looking for the unlock code so it can play multi -region
PM: [email protected]
Posted on May 25, 2008
Anonymous
SOURCE: Unlocking Code Required to make the Sony DVP-PQ2 DVD PLAYER MULTI-REGION.
sony dvp-fx811 - multiregion codes wanted
Posted on Dec 21, 2008
Paul Hutchinson
  • 909 Answers
SOURCE: How do I unlock my Sony DVP - NS330 player, bought
Codes for-
Sony DVP-NS300, Sony DVP-NS305, Sony DVP-NS400D, Sony DVP-NS700, Sony DVP-S330, Sony DVP-S335, Sony DVP-S360, Sony DVP-S336, Sony DVP-S525D, Sony DVP-S530D, Sony DVP-S535D, Sony DVP-S536D, Sony DVP-S725D, Sony DVP-S735D
Turn on the unit with the remote controller, Wait until "no disc" appears in the unit's display. Press the keys: PAUSE, 3, 1, 4, 1, 5, 9. And "CODE" will appear in the display. Press the number key that corresponds to the disc zone you want to play within the next 5 seconds:0: All regions / 1: Region#1 / 2: R#2/... and so on. Then, within 5 seconds, press: PAUSE, POWER... and voilà. If you don't have good results, disconnect the equipment and repeat.
Or
Put your player in standby mode and then enter: [[0] [ENTER] Default Default region code [1] [ENTER] or [UP] [ENTER] Region 1 [2] [ENTER] or [RIGHT] [ENTER] Region 2 [3] [ENTER] or [DOWN] [ENTER] Region 3 [4] [ENTER] or [LEFT] [ENTER] Region 4 [5] [ENTER] or [TITLE] [ENTER] Region 5 [6] [ENTER] or [DVDMENU] [ENTER] Region 6 [7] [ENTER] or [RETURN] [ENTER] Region 7 [8] [ENTER] or [DISPLAY] [ENTER] Region 8
Or
Put player into standby modes by pressing power button on remote control. Then press Title button. Press Clear button. Press Power button.
Yours is not listed but these may be worth a go.
or try http://www.haldigital.com/hp/dvd.htm
Posted on May 15, 2010
Anonymous
SOURCE: How to turn off the closed captions on my sony dvd
I had the same problem so i simply turned off the CCD on the tv itself and no more captions!
Posted on Jun 12, 2010
I've recently bought a Sony DVD/ CD player DVP-SR650P. Its accessoies includes a remote RMT-D187P. The remote does not have an open/close/eject button. How to eject the disc tray with the above DVD player...
There is no eject etc button on the remote control because what use would it be? To insert or change a disc, the operator would have to be in reach of the drawer with a disc to hand.
Mar 06, 2011 | Televison & Video
I have a sony dvd player model dvp-ns305 i live in rhodes greece family send me films on formatted discs but my player says can not play this disc? can you give me advice or solution
If it plays other bought discs, then maybe your DVD player has been configured not to play pirated discs or the films weren't copied well.
Nov 25, 2010 | Sony DVP-NS305 DVD Player
I need a region unlock code for my Sony DVP-F25 DVD player. Help for the stuff region 1 S
sony dvd player bought in america and canada are designed to play region "1", "0" and "all" discs
Oct 18, 2010 | Sony DVP-F25 DVD Player
Codes for-
Or
Or
May 15, 2010 | Sony DVP-NS330 DVD Player
Sony DVP-CX995V 400 disc DVD Player wont read DVD-
After variety of different tests and findings I have resolved this issue. It appears that the DVD burner was not in good working order and the DVD player was not at fault. Thanks you to all who answered and responded to my problem. Many thanks.
Aug 18, 2009 | Sony DVP-CX850D DVD Player
SONY DVD Player refuses to load DVDs
What you might of done is pushed the dvd tray to close it, so its out slightly.Come across it a couple of times. all i did was, open the tray & before it started to close, switched off the power. pull the tray until it opens fully(dont yank it). when its fully open, try to pull it very slightly more. plug it back in & let it go back its self, if it doesn't. push it. all thats happened is its just out slightly. messing about with it like this will sort it im sure. let us know how you get on. [email protected]
Jan 21, 2009 | Televison & Video
Sony DVP-NS55P subtitles
go to dvd set up menu and reset the settings. try again to see subtitles.
Aug 12, 2008 | Sony DVP-NS55P DVD Player
Cannot Close Sony DVP-NC665P 5 disk tray
There is a possiblity that he may have shifted the unit while discs were in it causing the discs to slip off the tray and into the unit. You have to open the unit to check if there are loose discs.
Nov 12, 2007 | Sony DVP-NC665P/S Multi-disc DVD Player
Sony DVP-NC80V DVD Player Logo
177 people viewed this question
Top Sony Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Nasir Muhammad
Nasir Muhammad
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
