Question about Konica Minolta DiMAGE Cameras
Maxxum 7d Battery Holder Clip Clip Broke Off
How much to repair the clip that holds the Battery into the Battery compartment???
3 Suggested Answers
Anonymous
SOURCE: Battery compartment cover
Hi how u going? I just brought a new cover for AUD24.01 which includes postage n tax from Fuji here in Australia.
Fujifilm Australia Ltd 114 Old Pittwater Rd Brookvale NSW 2100 Australia Ph (612) 9466 2600 www.fujifilm.com.au
Freecall 1800 226 355
All the best
Paul
Posted on Nov 19, 2007
Anonymous
  • 619 Answers
SOURCE: I dropped my Lumix and the little lever in a battery compartment got broke.
maybe you can do by yourself but its wise let technician to do it more knoledgeable to do it.
Posted on Dec 28, 2007
tjjfitz
Tom Fitzsimmons
  • 8 Answers
SOURCE: Camera battery clip
Well, I got the latch and spring back into my DX7630, and so far (half an hour after) so good.
To do this, I had a replacement latch from U.S. Camera ($10 total, latch plus shipping and handling) and the original spring on hand. I took all of the eight screws holding the camera body together. I also pulled off the "rubber" hand grip on the front of the camera. I'm not sure if that was necessary or not, but in doing it I broke off one of the "claws" that secure the grip.
Then I turned the camera so the battery door was on top, opened the door, and gently pried the camera body halves apart. I used "square" wooden toothpicks to hold the body apart so I could get at the latch area. (The battery was not in the camera during all this work.)
There are two small slots in the camera body where the latch is held and pivots. The latch pivots can be slipped into those slots if the toothpicks have the body wedged open widely enough.
The hard part of the assembly is getting that latch spring properly mounted. The spring fits over the rod of the latch. The spring wire has two ends: one is shorter. The shorter-end goes behind the latch on the memory card side. The longer-end makes the job difficult. It must be held so that the spring is under tension while the battery side latch pivot is slipped into its slot, then the memory card side latch pivot is slipped into its slot. The longer spring-end presses against the camera body.
The latch and spring only flew away into the darkness of this room once during the effort, and that happened because I tested the latch a few times before closing the camera body. The body halves should be closed before doing any latch testing.
I put all the screws back into the camera snapped the rubber hand grip back in, put in a battery and a memory card, and at this writing, all seems to be working as designed. Hooray!
Posted on Oct 21, 2008
How do I change the battery on my Polo watch?
nnap back
2a 2b
? STEP 2 TOOLS NEEDED:
Prying tool, non-metal tweezers, small screwdriver, battery tester, cleaning cloth, screw holding tweezers, watch closing hand press, polishing cloth
Place the watch in the case holding vise. Clamp the watch in the case holding vise by opening the two halves of the block. Place the watch in the middle, and gently release or tighten the two halves so that they hold the watch firmly (2a).
If the watchband does not unbuckle or unclasp, separate the band by pressing down with the pointed tool to remove the spring-loaded pin that connects the band to the clasp or watch (2b).
3a 3b 3c
? STEP 3
Remove the back. Look for the groove between the round back and the watchcase (3a). Gently insert the case knife beneath the lip which is usually opposite the stem or the nine o'clock position. (3b).
Work the knife into the groove between the round back and the watchcase. Twist the tool to snap off back (3c).
4a 4b 4c
? STEP 4
Remove the batteries. IMPORTANT: Before removing batteries, be sure to note which side is up. You'll have to put the new batteries in exactly the same. In some watches, the batteries are held in by a small metal clip. If so, carefully follow these directions for removing them.
SPRING CLIP: Lift up one end of the metal clip with the fine point tweezers-it will come out. Then, remove the batteries (4a).
SCREW ON CLIP: Remove the screws with the small screwdriver (4b). Be careful not to lose them. Caution: Clip may spring out; maintain pressure or screw may be ejected.
PERMANENT CLIP: Lift the outside edge of the battery out of its compartment with the small screwdriver (4c).
5a ? STEP 5
Test the batteries. See the battery tester for operating instructions. IMPORTANT: If the watch has two batteries and only one tests "replace", replace both batteries. If both batteries test "good", there is some- thing wrong with the watch. Refer to your watchmaker.
? STEP 6
Locate replacement batteries. Read the number on the old battery. Find the same number in the Star Struck Cross Reference Guide (6a). Choose the corresponding battery listed in the Cross Reference Guide from the Star Struck battery assortment cabinet (6b).
? STEP 7
Clean the battery compartment. Check the battery compartment for dirt and remove it. If you find corrosion, refer to your watchmaker.
? STEP 8
Install new batteries. IMPORTANT: Be sure to test the new batteries before installing. For tester settings, follow manufacturer's instructions. Install the new Star Struck battery(s) with the same side up as the one(s) you replaced. Remember the watch won't work if the batteries are put in wrong.
SPRING CLIP: Place one end of the spring clip in place and push the other end into its slot (8a).
SCREW-ON CLIP: Place the clip over the new batter- ies. Hold the screw with the screw holding tweezers to start it in to the hole. Tighten the screw (8b).
? STEP 9
Close the watch. IMPORTANT: If there is a rubber sealing gasket in the back of the watch, make sure it is lined up properly before closing the back. Snap a metal adapter that is slightly smaller than the watch back into the upper jaw of the press. Place the support plate into the bottom of the press and fit a plastic ring adapter large enough to hold the watch into the support plate. Place the watch face down into the plastic ring adapter and press gently on handle until the watch snaps into place.
6a 6b
7a
9a
8a
8b
? STEP 10Clean the watch. Gently wipe the watch to remove any fingerprints or smudges.
? STEP 11Reset the watch. Reset the watch and make sure it is working. In analog watches, if there is no
second hand, observe the minute hand through a magnifying glass until you detect movement.
Sep 10, 2015 | U.S. Polo Assn Mens Rose Gold & Black...
Can battery compartment be repaired when tabs are broken off which hold lid down?
possibly...if it is the body where the tabs are broken off the manufacturer (Olympus) might be able to replace the body shell. I'd check with them.
Aug 16, 2014 | Olympus SP-600UZ 12MP 15x OPT Zoom Digital...
How to change battery
Hi, try:
To install the battery:
Note: To open the battery door, you will need a paper clip or thin pen.
1. Take the paper clip and use the end to press down on the door latch.
2. Holding the latch down, push the battery door up.
3. The door will slide up and spring open, allowing you to access the batteries.
4. Place the battery into the compartment. Be sure to match the (-) on the
battery with the (-) inside the compartment.
5. Slide the battery cover to its original
Jun 09, 2011 | Disney Pix Micro Digital Camera
How To remove the cover from Samsung SGH M-200
To remove the cover of the phone, you follow the process below:
Remove your back cover by pressing down the black part and sliding it downward, remove your battery and sim. Two screws need to be removed,
There are four slots in battery compartment. Two are by the left side and there are two opposite. Push a mobile phone opening tool into each slot and then turn it. This will release the clips that hold the battery compartment in place, now you have the back cover removed
Next release the clips that hold the front cover,
Just gently unclip the hooks that clips the front cover, there are about 6 hooks by the sides, 3 on each side, now you have both back and front cover removed.
Take care and good luck
Oct 14, 2010 | Cell Phones
My speed don't work
Speed Sensors REMOVAL & INSTALLATION Front Fig. 1: The speed sensor sits directly over the exciter ring in the front knuckle 89609p51.jpg
Fig. 2: Detach the speed sensor connector in the engine compartment 89609p55.jpg
Fig. 3: Remove the speed sensor harness from the routing clips 89609p53.jpg
Fig. 4: A special E6 Torx® socket is required to remove the speed sensor retaining bolt 89609p52.jpg
  1. Disconnect the negative battery cable.
  2. From inside engine compartment, detach sensor assembly 2-pin connector from the wiring harness.
  3. Remove the steel routing clip attaching the sensor wire to the tube bundle on the left sensor or remove the plastic routing clip attaching the sensor wire to the frame on the right sensor.
  4. Remove the rubber coated spring steel clip holding the sensor wire to the frame.
  5. Remove the sensor wire from the steel routing clip on the frame and from the dust shield.
  6. Remove the sensor attaching bolt from the front spindle and slide the sensor out of the mounting hole. To install:
  7. Install the sensor into the mounting hole in the front spindle and attach with the mounting bolt. Tighten to 40–60 inch lbs. (4.5–6.8 Nm).
  8. Insert the sensor routing grommets into the dust shield and steel bracket on the frame. Route the wire into the engine compartment.
  9. Install the rubber coated steel clip that holds the sensor wire to the frame into the hole in the frame.
  10. Install the steel clip that holds sensor wire to tube bundle on left side or plastic clip that holds sensor to frame on right side.
  11. Reconnect the 2-pin connector to wire harness. Connect the negative battery cable.
Rear Fig. 5: Detach the speed sensor connector in the luggage compartment 89609p04.jpg
Fig. 6: Grasp the harness and . . . 89609p37.jpg
Fig. 7: . . . remove it from the routing brackets 89609p36.jpg
Fig. 8: The rear speed sensor is mounted on the back of the hub assembly 89609p32.jpg
Fig. 9: Remove the sensor retaining bolt and remove the sensor from the hub 89609p34.jpg
  2. From inside luggage compartment, detach 2-pin sensor connector from wiring harness and push sensor wire through hole in floor.
  3. From below vehicle, remove sensor wire from routing bracket located on top of rear axle carrier housing and remove steel clip holding sensor wire and brake tube against axle housing.
  4. Remove screw from clip holding sensor wire and brake tube to bracket on axle.
  5. Remove sensor to rear adapter retaining bolt and remove sensor. To install:
  6. Insert sensor adapter and install retaining bolt. Tighten to 40–60 inch lbs. (4.5–6.8 Nm).
  7. Attach the clip holding the sensor and brake tube to the bracket on the axle housing and secure with the retaining screw. Tighten the screw to 40–60 inch lbs. (4.5–6.8 Nm).
  8. Install steel clip around axle tube that holds sensor wire and brake tube against axle tube and push spool-shaped grommet into clip located on top of axle carrier housing.
  9. Push sensor wire connector up through hole in floor and seat large round grommet into hole.
  10. Reconnect sensor 2-pin connector to wiring harness inside luggage compartment.
Aug 03, 2010 | 1992 Ford Crown Victoria
Opening battery compartment on Midland LXT80 2-way radios
First take the clip off by pulling the tab while sliding it down. Then once the clip is off, push in and down on the top of the battery compartment and it should come off.
Jul 07, 2010 | Midland LXT80 Two Way Radio
My sandisk sansa clip 1gb wont turn on
Make sure the player is fully charged. 1. Connect the player to the PC. 2. Make sure the computer detects the player.
NOTE: If needed, switch the player to MSC mode, 1. Turn device OFF. 2. Slide the Hold switch down to Lock (orange color showing). 3. Press and hold the center button while connecting the device to the PC.then connect it to the PC. Next Be sure the battery is charged 1. Leave the player connected for approximately 2 hours to charge. 2. Disconnect the player from the PC. 3. Verify if you can turn on the player. 4. Reset the player if necessary.
To reset the player: 1. Press and hold the Power/Menu button for approximately 20 seconds. 2. Release the Power/Menu button. 3. Press the Power/Menu button again to turn on the player.
If that does not do it, re-seat the battery: Here is how to get to the battery, 1. Press the battery compartment in while sliding to the right. 2. Remove old battery. 3. Insert new battery or reset the old battery. 4. Close the battery compartment. Then try and see if it will come on with out the battery hooked to your computer. 1. Remove the battery. 2. Connect the player to the PC to verify if it turns on. 3. Re-seat the battery to ensure proper connection. 4. Verify if the player turns on.
Jan 29, 2010 | SanDisk Sansa Clip MP3 Player
The orange plastic clip that holds in the battery broke.
use some tape, or put a piece of something on top of the battery, when you close the battery door and latch it, it should hold the battery in place. That orange clip just holds the battery low enough that it comes in contact with the terminals at the bottom of the compartment.
Hope this helps
Jer
Jan 16, 2010 | Pentax Optio T20 Digital Camera
Fujinon Technostabi 14x40--battery compartment,clip that holds battery in place broke off,need new battery compartment
I had this problem a couple of years ago. I bought a new battery compartment from Fujinon's US repair center: http://www.bakermarineusa.com. It was about $38. Unfortunately I now have the same problem with the new battery compartment. I'd like to find a source of the metal spring clips.
Nov 28, 2009 | Fujinon Techno-Stabi Jr. (12x32) Binocular
Cameras Logo
47 people viewed this question
Top Konica Minolta Cameras Experts
Ekse
 Larry
Larry
Pierre Laplante
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
