Question about Boston Acoustics SoundWare XS 5.1 Speaker System
Zd 3 diode value on boston acoustic soundware xs 5.1 subwoofer
Zd #3 zener diode is shorted, can not read the value.
DragonSlayer2
    New Friend:
Replaced the ZD3 on the Boston Acoustics Soundware xs 5.1 subwoofer with a 18 Volt-1 Watt Zener part number 1n4746a. and works like brand new.
Posted on Sep 12, 2015
  • Christobald
    Christobald May 23, 2020
    I will buy one zener diode or probably 100 (you know why :-D ). And I will test soon.
    Thank very very much for sharing !
    How did you manage to get/guess the zener voltage ?
  • Drew Allan
    Drew Allan Jul 25, 2020
    RS Stock No. 818-4951 its actually a Taitron Part Number TZXJ18B with Marking Code Z18Bhttp://www.taitroncomponents.com/catalog...
leonardo
    New Friend:
  • 3 Answers
Hello
Did you find the value of ZD3.
I need it too.
I have the same problem, and I take out the ZD3 and the subwoofer works. But I'm not sure that is correct. I think it may be the circuit stand by.
Posted on Jul 16, 2014
  • Giuseppe Hormigos
    Giuseppe Hormigos Oct 19, 2014
    Its a Zener diode Z18B
  • Hector C Hernandez Oct 20, 2018
2 Related Answers
Anonymous
  • 93 Answers
SOURCE: how do i connect my boston acoustics pv800
You need to use the LINE LEVEL connection on the pv800 (usually a rca type connector cable) and run this cable into the back of the HK 520 Subwoofer PRE-OUT connector, be sure the HK Receiver menu speaker set-up option is set to SUBWOOFER "YES"
Posted on Jun 12, 2010
prijo_haman
SOURCE: boston soundware 5.1 subwoofer is clicking on and
I read on another forum is to turn your stereo level for the sub all the way to max then dial back the level on the sub to desired level.
Posted on Mar 03, 2012
How do you repair blown Boston Acoustics Subwoofer MCS Amp?
Most often this unit goes dead because of zener diode ZD3 shorting. It is a 18v zener. replace this and you should be back in business.
Feb 20, 2017 | Boston Acoustics Audio Players & Recorders
My subwoofer had no sound or power. I replaced the ZN3 diode and now I have power but still no sound. Any suggestions?
If this is a boston acoustics sub, then I assume you replaced ZD3. You also need to check R9 on the back of the board. It is a surface mount resistor and should read 10 ohms. This resistor sometimes goes open when the diode shorts.
Jun 05, 2015 | Audio Players & Recorders
My subwoofer just starting a clicking noise. what could it be?
You may have dislocated the voice coil. Repair shop may be needed.
Feb 19, 2015 | Boston Acoustics Audio Players & Recorders
Hi i have the Boston acoustics soundware xs 5.1 the sub stopped working the led shines red on stand bye and turns to green when the amp is switched on so i have taken it apart and found ZD3 has blown but...
ZD stands for zener diode and used for exact voltage regulation. Take out a known good one and go to a repair shop to replace. Make sure that when you re install, the striped (polarity) markings are in the same direction!
Mar 14, 2014 | Boston Acoustics SoundWare XS 5.1 Speaker...
MCS 160 Boston Subwoofer ZD3 Zener Diode Value
ZD3 is a 18v zener. Also check the surface mount resistor on the back of the board that is attached to ZD3, I think it is R9. Should be 10 ohms. This resistor sometimes opens when the diode goes short.
Jul 13, 2013 | Audio Players & Recorders
Mcs 160 subwoofer no power
I had the same problem with my subwoofer unit. I found the zener diode ZD3 was fried. The pic below shows the diode and its clearly tagged ZD3. You need a multimeter to check this before you order anything. This diode should only transmit power in one direction. Its size and spec is 18v .5w zener diode. (that's 1/2 w) It's very inexpensive and the whole repair took about an hour. This is from a Boston Acoustics subwoofer MCS 160
Ok..the procedure is easy.
1) unplug the unit and bring it to a well lit work area.
2) remove the panel from the back and locate the board that is held to the panel by 4 screws and has the ZD3 diode. The pic below shows the diode at the end of my test lead. Note the direction of this part and reinstall the new one in the same direction. Its a simple de-solder and re-solder project. I elevated the new diode about 1/8 " from the board with a small strip of copper. This acted as a heat sink during the soldering and elevated the part above the board to help it dissipate heat later when in use.
3) re-install the board and plug in all the connections.
4) this worked for me and I'm enjoying my sound system again!..good luck0482b949-8492-43a6-91df-0fb2f0e6888b.jpg
Jul 24, 2012 | Denon Audio Players & Recorders
Boston soundware 5.1 subwoofer is clicking on and off all the time
I dont have a solution, but Im having the same problem, and so is someone else:
http://www.avforums.com/forums/speakers/1205745-boston-acoustics-soundware-xs-5-1-review-6.html
Bad batch maybe? Lets get your input and maybe we'll get to the bottom of it.
Jul 10, 2011 | Boston Acoustics SoundWare XS 5.1 Speaker...
Boston Acoustics SoundWare XS 5.1 Speaker System Logo
2,689 people viewed this question
Top Boston Acoustics Audio Players & Recorders Experts
 Grubhead
Grubhead
Harrie
Are you a Boston Acoustics Audio Player and Recorder Expert? Answer questions, earn points and help others
