Question about RCA D61W20 61" Rear Projection Television
RCA rear projection 61
Power button just flashes. I took it apart to clean the lenses and now it does not work. The power button flashes 8-7 or 7-8 times.
Posted by eriklisonbee on
Delton Smith
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 96 Answers
Why did you take apart the lenses did you take other parts a loose. may you unpluged a conniction or you need to back trace what you did if it was working before you did it. did you open the tubes
Posted on May 28, 2012
5 Related Answers
Anonymous
  • 61 Answers
SOURCE: RCA 61" Model P61960 stopped working
You have a flyback transformer and horz output transistor bad
Posted on Mar 07, 2008
Anonymous
SOURCE: my 60 inch rca rear projection tv will not come on
i have had same problem repairman states splitter is bad has an upgrade for $350.00 the next time repaior man could not find part,,advised he would have to replace entire box this cost $275.00 and also states thiis would be a later model than my original box,the picture is great never been this good.note when i say box i ment the box inside tv with all the electronice and projector
Posted on Mar 27, 2009
Anonymous
  • 150 Answers
SOURCE: RCA D52W20 52 in. Rear Projection HDTV power light blinking
Liz, yes it is a power supply problem, better question is; low voltage or high voltage power supply ? count the blink code, it should repeat the code, once you have the code call your local tv shops and give them the model number of your tv and the blink amount and they`ll tell you price to fix, gl, video-tek
Posted on Jun 05, 2009
Slinteriors
Sonny Berry
  • 8617 Answers
SOURCE: I have a RCA R56wh78 projection power button flashing green.
Thats the classisc sign that the CP150, CP114 and CP120 capacitors need replacement. You can get the repair kit called CP150, CP120 and CP114 at www.tvrepairworld.com which contains the capacitors and the CD with step by step instructions on how to do the repair.
Posted on Dec 04, 2009
Testimonial: "Thank you. I will try this. I just dont understand why it worked with all of the button pushing on the front of the tv. Is this going to be a hard job"
rylee_smith
Rylee Smith
  • 8619 Answers
SOURCE: I have a RCA D52W17 rear projection T.V. When I
Hi
Thanks for using FixYa. 3 blinks in your RCA D52W17 rear projection are caused due to 3 capacitors (CP114, 120 and 150) which are located on the deflection board. If any of these capacitors goes bad you’ll have to replace them with the exact same ones. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jun 21, 2010
I have a 61 inch rear projection TV. When moving we took the back off of the TV so that we could navigate it up the stairway to my new apartment. Once in the apartment we plugged it in and it wouldn't go...
Check ur power source?Yes,wait like about an hour later for the tv resetting back to it factory setting.Recheck all connections inside of the tv for loses or untighten connections?Make sure all connections are tighten and no damage to all the PCB boards tries again tv should work now.
Jan 14, 2011 | Hitachi 61SWX10B 61" Rear Projection...
Convergence circuit problem
I would clean the lenses with alcohol and q-tips before i try to change an IC chip. My RCA had the same problem. I tried to use the auto convergence and the picture was out alignment. I took off the button bar by taking off the speaker cover and taking out about seven screws (7/64" allen key type) 3 in the front and 4 in the back. Let the power bar hang. You should be able to get to the lenses. Turn the power on and clean them so you can tell when there is no more streaks.
If that doesn't help maybe your convergence IC is bad. If you have to ask if you can replace it yourself you probably shouldn't try it. It take special tools and some practice to solder IC chips. Good Luck.
Mar 14, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
I was given a rca p61940 rear projection tv. The
It sounds like a convegence problem due to dust on the lenses. Clean the lenses with qtips and alcohol and then use auto convergence in the menu screen.
Mar 08, 2010 | RCA P61940 61" Rear Projection Television
I have an RCA rear projection TV with a dead fly behind the screen, how do I get it out?
pop the speaker grill off, then take out the 1/4 inch screws and remove the screen, if it's behind the screen, simply brust it away, if it's between the 2 screens, then you must take them apart and remove the body. also while your in there, clean the lenses and mirror with some windex, this will greatly improve your picture.
Sep 08, 2009 | RCA P61940 61" Rear Projection Television
The power button on my tv pushed in
The board is fine, unless u cracked it. You need to change the buttons only. Shouldn't be hard to find. Look for RCA microswitches.
Apr 08, 2009 | RCA P61927 61" Rear Projection Television
Rca d61w20b tv
Some set display this problem because of bad capacitors in the powersupply. Take a good LOOK at all large caps on the board.
Aug 06, 2008 | RCA D61W20 61" Rear Projection Television
Tv wont power up
if you can not turn on TV set with the power button on the TV its not astandby problem as this would by pass the standby. Theres most protec,on a set of this age, top have a poiwer regulator,vertical,horzontal/chcroma problem and is goingto need a trained tech to assist you in this repair. www.afiata.com
Aug 01, 2008 | RCA D61W20 61" Rear Projection Television
Power
When i try to turn it on the power button flashes a code. The power button lights up once for a second, then turns off, then flashes quickly nine times and lights up once again for a second before turning off. The screen doesnt turn on at all, nor do the speakers. Any help would be highly appreciated.
Feb 11, 2008 | RCA D61W130 61" Rear Projection Television
61 in rca model # hd661w66
???...if course the green LED will go off ater a few seconds of unpluging it...LOL...anyway....power supply/deflection board will solve this problem
Feb 03, 2008 | RCA P61927 61" Rear Projection Television
Nov 04, 2007 | RCA P61960 61" Rear Projection Television
RCA D61W20 61" Rear Projection Television Logo
Top RCA Televison & Video Experts
Paul Bade
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
