SOURCE: XO Vision XOD1740BT in dash dvd player bypass code
I solved it By connecting the pink wire to a constant ground this acts as a bypass so the unit plays anytime.
SOURCE: e- brake bypass
Thanks for everyone's help. The bcar screen actually is the backup camera screen which is activated by the orange wire and when I turned on the lights, it got activated. I disconnected the orange wire and everything is fine. When I get a backup camera I'll connect that wire to the backup lights so that it will come on whenever I put the car in reverse. You are right that their manual is not very clear at all. I called their tech support and they couldn't help me trouble shoot the problem either. The unit is functioning perfect now but my next beef is that you can't change the XO vison default screen when a cd is playing. It would have been nice if you can scroll some jpeg shots of anything else besides looking at the xovision logo. I guess I can't have it all for $340 so, I'll stop whinning.
SOURCE: everytime i take turn the car on or off the radio resets to defau
If you are losing the memory (clock and presets) on the unit, you need to make sure that the yellow wire (normally) has 12 volts AL THE TIME and the red (acc) is switched on and off with the key. The battery wire (memory consant 2 volts) is the one that retains memory.
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
SOURCE: xo vision dvd player
hi there
it shouldn't be to hard to install this but it does require cutting a hole in your interior part of roof........a install like this could take anywhere from 30 mins - 1hr for a installer to put it in. to do it yourself it could take 1-3hrs to complete (note for your first time doing this take your time and follow the install manual that will be provided)
SOURCE: help me with back up camera for xo vision xod1740bt
I am just giving a suggestion. I too need to know how to wire this. From what you posted it sounds like you hooked the wire to a constant +12v that is always on. Forgive me if I am wrong. Anyway, Did you connect this wire to rear reverse light power. I think from what you say it is supposed to be connected to the positive side of that light. If this solves your problem can you PLEASE let me know the full details of everything else you hooked up on the circuit to make the backup work. For instance what is the label of the orange wire. TIA.
