My kids received a new laptop so I get the old but that don't remember the admin password & on top of that one of them has several thing pw locked such as downloading , installing etc.. Please help windows 7
I forgot windows 7 laptop password, i just reset windows 7 password by the following steps,
Step1: Download Smartkey Windows Password Recovery Professional from http://www.recoverlostpassword.com/products/windowspasswordrecovery.html.
Step2: Install and launch it to any accessible computer.
Step3: Use a blank and writable CD/DVD/USB to burn Windows 7 password reset disk with the tool.
Step4: Boot the locked computer from CD/DVD/USB.
Step5: Start to remove Windows 7 password with the burned disk.
Step6: Reboot computer and login to the locked PC without password.
Hope it can help you well.
SOURCE: need a name of supporting driver for my old laptop
Download the Drivers for XP, and right click on it, and select properties. Under compatibility select "Run in compatibility mode for XP SP2".
Warning, drivers may not behave normally. So be careful
SOURCE: don't have HDD passwords
To clarify the request, it is a harddrive password not a bios password or windows.
SOURCE: i neeed clear bios cmos and cmos run to my hp ze4315us
Restart system holding down f11 key till it beeps. Dont forget to backup your documents.
SOURCE: I can't remember the password on my Toshiba laptop...
Boot your PC using a Knoppix DVD. If you have access to another PC, download the Knoppix iso from Knoppix or other site that has it, burn to DVD, then try to boot with the DVD. You may have to go into the PC setup to set it to boot first from removable media. Boot order is important. Watch the boot screen for the prompt that tells the key to press to get into the setup. Once that boot from removable media, and the order, is set, then boot again with the Knoppix DVD in the DVD drive. Once in Knoppix, which usually has a very familiar-type graphical interface, you may find it simplest to use the built-in Samba server function,where you can set permissions of which other PCs IDs and passwords can access the PC via Samba. Samba server is accessed through one of options that you access from the bottom right. I also have used the opposite function of mapping another PC from the Knoppix. Using this, I was able to retrieve data files from a HDD which had a partition corrupted in such a way that no version of Windows would reinstall/upgrade. My backups were useless until I copied all my data off and repartitioned the HDD.. Of course, you have to have the Hard drive password, but you must have gotten past that since you got to the Windows signon.
Another option is to put the hard drive in an external hard drive USB-based enclosure and attach it via USB to another PC to read the data files. However, this may or may not work if the other PC is Windows based and the partition is corrupted as mine was. You could still boot the other PC with Knoppix DVD and see if it will read that external HDD, That depends on whether Knoppix has drivers to recognize that external HDD.
Testimonial: "Thanks so much for the advice, God Bless!!!"
SOURCE: my hotkey don't work after upgrading to
Go to Sony's website and download all the drivers for your laptop model. That will enable the hotkeys on your laptop.
