Question about Magic Chef MCBR360S Stainless Steel Compact Refrigerator
Door open all night, compressor hot
Door was open all night. unplugged and plugged back in. no sound compressor and side of fridge hot. now cool, doesnt appear to restart.
Posted by droycemcpeak on
danny Hendrickson
    President:
  • 2,468 Answers
Replace the ptc overload/relay on the compressor this will fix your problem
Posted on May 28, 2012
5 Related Answers
Anonymous
SOURCE: Magic Chief compact fridge motor gets hot but does not cool
Look In the rear bottom where the wires plug into the compressor. There will be a plastic cover plate over the connecting wires. Remove it. Unplug the white wire. note the white wire was plugged into a small black box (3/4"x3/4") pull the black box out. It is connected by 2 prongs. If you open this up you will find a small metal disk that looks like a watch battery. pop it out and clean the contacts. put it all back together and it should work fine. I believe it is the thermostat and many times gets bad contacts and can even crack over time. The compressor will "click" on but the bad thermostat tells it "no"
Posted on Feb 28, 2009
aasc
Mike Smith
  • 1606 Answers
SOURCE: freezer temp is wear fridge shoud be.fridge temp 55 degress.
Check the fan in back which cools the compressor . Also check the coils to make sure they are clean of dust , lint , etc...
Posted on Aug 02, 2009
aasc
Mike Smith
  • 1606 Answers
SOURCE: fridge cooling freeze up i unplug the unit to
You have 2 heaters , behind the inside freezer panel. Both heaters , come together in a kit . This is usually the problem , with magic chef refrigs . When replaceing , use the complete kit with wiring . You will have to put the heater guards , with clips , on the new heaters .
Posted on Dec 09, 2009
kel1guy2002
Kelly
  • 3740 Answers
SOURCE: so my mini fridge seems to have stopped working it
I apologize for being 1 month late in answering your question. I just answered a different post and your question appeared after answering the other post. Having said that here goes.
If the compressor is running reach down and touch the tubing that goes into the compressor. One of them should be very hot and the other one should be much cooler about 2 inches from the compressor. If neither one of the tubes is hot the coolant system it out of coolant probably due to a system leak. (i.e someone poked the coils defrosting the unit or.. there was soldering joint that had a slow leak and allowed the coolant to escape. Make sure to listen for the compressor running continuously vs running every 4 - 6 minutes (thermal overload cycling) If the drier is clogged where the capillary (small tube) connects to it there will be one hot tube at the compressor but no coolant flow.
Thanks for choosing FixYa,
Kelly
Posted on Mar 26, 2011
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: MCBR240s Magic Chef Fridge does
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Jun 12, 2011
LG Fridge LSC26945TT compressor getting to hot and not cooling
if it's not cooling unplug it so you don't damage the compressor,hopefully you just have a bad overload and relay,it's plugged into the side of the compressor,with the machine unplugged remove the bottom back panel,look at the compressor,remove the cover on the side of compressor and remove the start device or ptc assy. call your local parts store and give them the model number and buy a new start device for your machine.if you can hear a clicking sound every once and a while and the compressor is hot change this out first,if it still doesn't start then you have a bad compressor and will be in the market for a new fridge if the compressor is running take everything out of the freezer,remove the back inside wall of the freezer and check the evap coil,if the coil is all iced up you have a defrost problem,if the evap coil doesn't have an even frost pattern covering the whole coil you have a freon leak.if you have a freon leak you'll have to replace the fridge..hope this helps
Jul 04, 2012 | LG Refrigerators
Hiya,i have a hotpoint fridge freezer ffa91 and the fridge is no longer getting cold.The compressor seems is hot but cant hear the normal noises coming from the fridge.The digital display shows an arrow...
1. is light on in side when you open the door. If not check breakers or fuses.
2. Can you hear the compressor running. If not do you hear any clicking sounds.
3. If you hear clicking sounds, try putting a fan on compressor and unplug refrigerator.
4. Wait one hour.
5. plug back in. If compressor starts let it run and see if it cools, if it doesnt, call service man.
6. If it goes back to clicking, call a service man.
try this
Mar 12, 2011 | Hotpoint Refrigerators
My fridge is not working
4. Wait one hour.
Try this and let me know.
have a good day
Feb 23, 2011 | Refrigerators
MSD2454GRW. Clicking noise for about 10 seconds then shuts off. Freezer is thawing. Fridge "appears" to be cooling fine...not sure. Help...don't have the $$ to hire someone.
4. Wait one hour.
try this and let me know if it helps.
Feb 22, 2011 | Maytag MSD2454G Side by Side Refrigerator
My Frigidaire FRS22ZRG freezer is working fine, but the refrigerator has been abnormally hot all night long.
4. Wait one hour.
try this and see if anything happens and let me know.
Feb 22, 2011 | Refrigerators
Left the fridge door slightly open last night and fridge turned off. How do I turn it back on? Freezer is fine
4. Wait one hour.
let me know if this works.
Feb 22, 2011 | Sub-Zero 650 / O Bottom Freezer...
Fridge and freezer not cooling. Hot air coming from front of fridge.( Overly Hot and has a smell of burning )
4. Wait one hour.
please rate my answer.
Feb 21, 2011 | Amana Refrigerators
Fridge and freezer stopped working
you need to unplug asap,your compressor is short cycling,go to the local appliance part store and ask for a 3in 1 starter,this will help you get it started again,the directions are on the starter,very easy,plug frig back in and listen for comp. restart,let me know how you do-mike
Oct 27, 2008 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
Refridgerator/freezer not cooling
It sounds like a faulty compressor and yes you should unplug it until the service man.
Mar 13, 2008 | KitchenAid Superba Architect KSCS25INSS...
Maytag MZD2766GES side-by-side Refrigerator warm
is it frozen up? do you have any air flow thru the air tunnel from the freeze to the fridge? Check your air flow with the door switch pushed in. also check to see if the damper door opens... 1) if it is iced up you have a defrost problem. most likely a defrost timer. Turn off or unplug untill all the ice has melted off the evaporator back of the freezer..plug back in and it will work fine untill the ice builds up again. if this work you do have a defrost problem.. if not let me know and we can go deeper...
Aug 18, 2007 | Maytag MZD2766GES Side by Side...
Magic Chef MCBR360S Stainless Steel Compact Refrigerator Logo
444 people viewed this question
Top Magic Chef Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
Lawrence Oravetz
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
