SOURCE: thermostat problem Daihatsu Applause a101 engine
The new thermostat will be marked with an arrow,the spring side points towards the motor.
SOURCE: 1994 daihatsu Applause handbrake light wont go off!
check your brake fluid level i had same problem on a different car with handbrake light staying on and when i checked brake fluid it was on minimum light went back to normal after topping up fluid in the reservoir check the fluid "DOT" rating before buying this should be on the cap (ie DOT 4 fluid only)
SOURCE: A friends car is overheating. Just had a head
chances are the back coolant passages in the engine block are probably plugged up. resurfacing the head don't help with cleaning the passages. best thing is to get something like prestone super flush and flush the block thoroughly. follow the instructions step by step to be sure it reaches optimum operating temperature, then the thermostat opens and the HOT flushing fluids can do the intended job, scrub the gunk and deposits away. it being an older car may take 2 or 3 thorough flushes, or take it to a place like firestone for a good, strong, powerful 'backflush'...
SOURCE: 1991 Daihatsu Applause, 1,6 lt 16 valve carburated
head gasket ,sorry ,its leaking through the feed to the valve gear in the head gasket .easy to change though on these cars just make sure the parts are available as i cannot get any spares here in spain for this make of vehicle
