I have found a main harness connector for the unit, however the powers and grounds for the unit very in locations and who knows what else is pinned different. Hard part is finding a harness that is specific for my unit. Can anyone help ?
SOURCE: Kenwood KDC-322
If you have the remote control for the unit, or can buy one then you can reset the code. Just ask me how...
SOURCE: im loose my wires
Here you go:
This is the wiring diagram for most all the kenwood radios for the last few years. Yours included.
If you need more help just ask.
A good rating would be appreciated.
SOURCE: New KDC-135 has Power but Faceplate won't light up
you shold always twist the end of the wiring together and tape them never use connectors, remove the connectors and twist the wires driectly to each other and tape them wiht electrical tape, the connectors almost always can not deliver the proper voltage..
Did you make sure you have the yellow to a constant connect wire and the red to a turn on?if not this can cause the radio not to work......
you can test wich is wich by turning the key off and putting the yellow to the one you think it is and red to the one you think it is, if you have have it right you will hear the CD player make a click run sound...... if not you will not hear any thing.
SOURCE: need color codes for a kenwood kdc- 122p head unit in dash.
Generally you can find these manuals freely available at the manufacturers website, however it usually take ages worth of searching and i thought id save you the hassle,
Head to this link for your units entire manual.. Page 17 i think it is exactly.
http://www.cartoys.com/cartoy/pdfs/kdc-122s_manual.pdf
There a good little unit but sold a few when i was working in the industry.
Otherwise generally you can pick up pre wired pugs that adapt the cars harness via one plug to the back of the stereo avoiding any splicing. If youre interested in them head to this website,
http://www.aerpro.com.au/contents.php?menu=Harnesses
Hope this helps,
Have a happy easter
Cheers
Steve
SOURCE: need wiring harness for kenwood kdc-mp225
Okay there are 2 possible solutions depending on your problem
Number 1
If its the lead that plugs into the back of the headunit then this is the page you need Click Here All you have to do is choose the one you need! just look at how many pins there are pretty simple to work out
Number 2
If its the lead that plugs in from your car loom to the headunit loom then you need to look here and pick out your car
This will solve your problems :)
Upfront Audio
Please dont forget to rate :)
