Garden Logo
Anonymous Posted on May 26, 2012
I have a honda 4213 riding mower thatacts like the clutch is slipping it goes but takes a second to get moving
  • Anonymous Jun 08, 2012
    IT DOSENT HAVE A DRIVE BELT IT HAS A SHAFT RUNNING OFF THE MOTOR TO THE REAREND
  • Kevin Getz
    Kevin Getz Jun 10, 2012
    I would have the gearcase checked for a gearing issue.
Kevin Getz
Level 3:
Genius:
  • Master 1,032 Answers
  • Posted on May 27, 2012
Kevin Getz
Master
Level 3:
Genius:
Answers
1032
Questions
Helped
324641
Points
3063
Your drive belt may be stretched. Check it for proper tension.
5 Related Answers
Fahr Quad
  • 776 Answers
  • Posted on Apr 07, 2009
SOURCE: snapper rear engine riding mower clutch
It is time to replace the driven wheel. When you flip the mower up on the back end (after closing the vent on the top of the fuel cap), the driven wheel is the disc that has rubber on the outer edge that rides on the silvery disc that comes off the end of the motor. The last time I bought one was about 7 years ago, at which time it cost me about $7.85. I would expect it to be around $11-12 these days.
Anonymous
  • 155 Answers
  • Posted on Jul 23, 2009
SOURCE: We mow 2 acres with a Greenfield ride-on.
Hi i have seen this with most greenfield models The only way to fix this problem is to replace the drive clutch assy as it ends up to costly to replace the worn parts : shaft,clutch plates & drive pulleys.
In most cases replacing these parts has led to a new assy six months later.
Mark.
Anonymous
  • 299 Answers
  • Posted on Sep 30, 2009
SOURCE: Craftsman riding mower won't move.
yes it is a bad belt unless it is a hydro-stat(no clutch) you need to look under the mower and see if the belt is on correctly
Anonymous
  • 2468 Answers
  • Posted on May 02, 2010
SOURCE: Snapper Rear Engine Riding Mower
if they have been adjusting it for you this many times they have done it wrong and have ruined the clutch face plate material by letting it slip and sand off the facing material,now its down to the metal back plate and its now metal to metal,you need to have the clutch replaced soon or your going to ruin more drive components
Anonymous
  • 51 Answers
  • Posted on Aug 08, 2010
SOURCE: snapper riding lawn mower loosses
if it is belt driven yes it sounds like its slipping may be worn or some idler pullys are adjustable via a slot in bracket where bolt goes through pully if it is disc driven the rubber disc is probably worn. if mower is a rear engine rider close vent on gas cap,set brake then lift mower from front and stand up on rear bars at bottom by floor you will see a rubber disc which is held on by 4 nuts. if has electric start try not to leave up for too long,should only take 15 min to replace hope this helps
1helpful
2answers
Honda self-propelled 21" mower (HRB216TDA). Will not self-propel. Not sure which part is bad.
If belt is ok, then likely the rear wheel dogs have seized. Review the following PartsTree diagram, what they call ratchet key item 3.
https://www.partstree.com/parts/honda/mowers-walk-behind-lawn-mower/hrb216-tda-honda-walk-behind-mower-made-in-usa-sn-maaa-1000001/rear-wheel .
When the mower is off, you would normally hear the dogs click as you pushed the mower. These get dirty from debris and then rust up and seize (no longer click). Once seized, the transmission drive shaft just spins inside the drive gear. Remove bolt wheel and wheel to access and clean out all the dirt and debris. Inspect inside side of rear wheel and verify wheel gear is in good condition. If all looks good then onto the drive gear. You could try penetrating oil, but if dogs are seized you'll likely need to remove the gear... the key is spring loaded so take not to loose the key and spring. They're small pieces and once they launch they may be lost forever.
I don't remember if the "cover" has to be removed. If it does, there are a lot of small parts, be careful not to loose and keep in correct order. Consult diagram frequently.
2helpful
My craftsman tractor wont pull itself up a hill. Runs fine but just comes to a stop when trying to go up a hill. Maby the ground drive belt is slipping????
Sounds like your drive belt is slipping alright. Need to tighten your clutch rod. One end of rod adjust. Have someone help you, move the clutch petal and your helper watch and see rod moves.
Clutch function provided by idler wheel tensioning
is this a troy bilt and have you just replaced the front drive belt if so if the belt is a pix belt then you need to take it back you need a belt that is oem onley i know this for a fact i have tore up some ones hood if you havent done any of this then ck the pulley were the front and back belt goes on thats called a varspeed pulley i have had them lock up some times thay go out or the bearings on them go out and you can bearings them let me know if you need any thing [email protected] ill help you
Mar 06, 2010 • Garden
7helpful
We mow 2 acres with a Greenfield ride-on. Sometimes have to cut long grass by slipping the clutch to get slow forward speed. Problem is that the clutch system occasionally locks into forward or (worse...
Mark.
Jul 18, 2009 • Garden
1helpful
Honda HTR3009 riding mower runs great but won't engage in any high speeds. It slowly goes forward and in reverse - no power. When cutter is engaged, it won't move at all. What might be the problem?
sounds like your drive belt is slipping.
look under your engine (you may have to raise the cover to engine to do this), see if the belt that is around the pully which is on your engine drive shaft is on correctly or is in need of replacing.
2answers
Clutch slipping
I had the same problem with my Yamaha 650. Either the clutch cable is misadjusted or you are using the wrong oil. Since the clutch assembly and all that is built into the crankcase, you need motorcycle oil. Are you using motorcycle oil or regular automotive oil.
Im sure there could be more serious issues, but I would check these first.
1helpful
Clutch issues: release clutch and mower doesnt move.
"....I just took off the right rear tire to replace."
Make sure the key hasnt fallen out of the right rear tire. It has to have the key to work. Its a peice of metal about 3 inches long and flat on all sides. It should slip into the grove on the tires shaft. Hope that helps.
Top Garden Experts
Jay Finke
Jay Finke
john h
