Sony HDR-SR12  HDD Camcorder Logo
Posted on May 26, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sony hdr sr12 screen won't open
Door opens approximately 1/3 to 1/2 way, seems physically blocked.
AMJAD HUSSAIN
Level 3:
  • Sony Master 586 Answers
  • Posted on Aug 22, 2012
AMJAD HUSSAIN
Sony Master
Level 3:
Answers
586
Questions
Helped
205859
Points
1533
HI,
A component called hing needs replacement.
5 Related Answers
AMJAD HUSSAIN
  • 586 Answers
  • Posted on Mar 02, 2010
SOURCE: The Touch screen on my Sony HDR-SR12 stopped
A flexible board (seems like a strip in pale yellow color) worn out and it needs replacement.
The detail of part is given below:
187480611 PWB, FP-807 FLEXIBLE
This part number needs replacement.
Thanks
ginko
Ginko
  • 19396 Answers
  • Posted on Apr 28, 2011
SOURCE: Is it possible to replace
Hi.
Yes it is possible. The hard drive is a 2.5 hard disk as the ones used in laptops.
Here a free service manual with disassembling instructions. The replacement must be done by an experienced repairer, as there is risk to damage the camcorder.
Regards.
Ginko
Anonymous
  • 1812 Answers
  • Posted on Jul 21, 2011
SOURCE: My Sony HDR-SR12 touch screen
The most likely cause for this is a damaged or defective flexible ribbon cable that connects the LCD to the camera body and can be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com.
caroldon
  • 17130 Answers
  • Posted on Aug 16, 2011
SOURCE: sony dcr-dvd408 can't open the
This can be due to failure of the loading motor mechanism . Since you are hearing the clicking sound , it is possible that the motor is working to the command from the processor but there is failure in the mechanical drive., This can be due to pulley slipping , gear failure or belt failure.
Unless the camera is opened to remove the covers and get access to the mechanism , the exact fault cannot be confirmed.
d0ugparker
Doug
  • 5 Answers
  • Posted on Dec 08, 2011
SOURCE: HDR-SR12 - LCD Touch screen very dim , screen
My camera's backlight went dark. Occasionally it would work if I pressed just the right way, but it was basically toast.
Search ebay for an HDR-SR11 or HDR-SR12 flex cable similar to this one:
http://r.ebay.com/L4dWDQ
It's not impossible to replace, but it's definitely not for the faint of heart. Some offer a replacement service with it. I'm doing mine myself. Results to follow, maybe, if I remember to post following the repair.
My Sony HDR-SR12 touch screen don't show anything when i open the camera. when i pust it a little in front of the camera it start to display, but otherwise it don't. I think there is a contact...
HDR-SR12 - LCD Touch screen very dim , screen works but almost completely dark. tried increased brightness etc no help
My camera's backlight went dark. Occasionally it would work if I pressed just the right way, but it was basically toast. With the right external light you could sort of make out what was on the screen by back reflection of what was on the LCD screen.
It's not impossible to replace, but it's definitely not for the faint of heart. Some offer a replacement service with it. I did mine and it works excellently. An $8 cable and about an hour (plus a lot of pictures-as-you-go for reassembly) is all it takes.
I bought a used sr12 Sony camera, and need a manual.
http://esupport.sony.com/US/perl/model-documents.pl?mdl=HDRSR12&LOC=3
3helpful
The Touch screen on my Sony HDR-SR12 stopped working. Is there a diy fix? screen now shows as it should but does not respond to touch
Thanks
Top Sony Video Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
