Question about Casio Music
What kind of adapter do i use for my keyboard Casio ca-110
I bought a keyboard Casio ca-110 but i don't have the transformer power cord. I need to know what kind of transfo i should buy
Posted by Bertrand Slight on
James Riley
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 37 Answers
If you don't want to wait, you can go to radio shack and get a universal adapter for a bit more, but it should work no problem.
http://www.amazon.com/HQRP-Adapter-compatible-Keyboards-Replacement/dp/B004TXDL3C
Posted on May 26, 2012
5 Related Answers
Anonymous
SOURCE: i need a power transformer for roland sde -3000
I need a transformer part 32 no:11-32-000 class 2 ac power transformer mod:mw48-090200a Input:120 ac 60hz output:9vac 2000ma.
(UL) US Ite powuer supply made in japan
Posted on Apr 23, 2009
Anonymous
  • 157 Answers
SOURCE: What kind of power source/adapter do I use for my Casio tone bank
Take a close look at where the power source adapter plugs in, there should be something written which will indicate the voltage requirements, write them down, for example it might indicate +plus or minus 12 volts DC at 400 Milliamps. Take the info you write down to Radio Shack and they should be able to sell you a universal power adapter that will work. You should have a power on-off switch some where on the unit.
Posted on Aug 20, 2009
Jim Epptech
  • 101 Answers
SOURCE: what power source/adapter do I need for Casio tone bank CT-670
Look where the power plugs in. There may be a voltage stamped on the keyboard. It may also have a sticker with info. on it telling what the power rating would be. Radio Shack carries a lot of universal adaptors. You don't tell what brand or model it is in your post. That might be more helpful. Hope this is helpful.
Posted on Nov 03, 2009
Fred Yearian
  • 5603 Answers
SOURCE: where in europe can I buy an adapter for the casio WK-110 keybord
The specs for the adapter are:
9 volts DC
850 ma MINIMUM
Center pin of connector NEGATIVE
If you find an adapter meeting these specs it should work, however I would recommend getting a regular Casio unit. They are under $20 USD and the part number is AD5.
Posted on Jan 02, 2010
Fred Yearian
  • 5603 Answers
SOURCE: Casio keyboard lit up, no sound, no responses
Unplug for several minutes and try again.
If that doesn't work, look up the "factory reset" procedure for your particular model via google and follow that procedure. It usually involves holding certain buttons down before and during power up.
Posted on Jul 25, 2010
How can I attach a 1/4 inch cord to my ca-110 tonebank to record the nusic played through a tascam dp-008 pocket studio
There is likely a 3mm connector. Get an adaptor from what you have to the 1/4" size. They're readily available and pretty cheap.
Sep 11, 2014 | Music
I lost my adapter to my keyboard and I need to find either a substitute or a new way to turn it on without the adapter, HELP!!!.
Some Casio Keyboards use 9V DC (center negative) others 12V DC (center negative).
If check what voltage your Keyboard use. Generic AC adapters are usually center positive. So you have to invert the wire with a new DC plug to make it center negative,
Easiest is to buy a Casio ac adapter made for your keyboard from a Casio retailer.
Sep 12, 2013 | Casio Keyboard Power Adapter
Casio lk-33 does not work with external power adapter. The unit will work on battery power. The connector for the adapter provides power to the power board, but the unit does not work. I don't have a...
I once had this problem with another Casio synth.
I hadn't the power adapter ant I tried with an other one, with the same specifications : the synth was apparently powered but it didn't work.
I finally understood that it was a problem of polarity (+/-). You may just have to cut the cable and resold it inverted.
Hope it could help!
Nov 05, 2011 | Casio LK30 Note Lighted Keyboard
Casioik90tv wont work trough power
Likely a problem with the power connector or the power adapter. Make sure you are using the original power adapter as often replacements don't work and universal adapters seldom work.
Nov 05, 2011 | Casio Ctk 496 Electronic Keyboard with 61...
Keyboard not powering up. Want to change the fuse/s. Don't know where fuse is located.
There probably is NOT a fuse and usual cause is problem with the adapter or the power connectors. Broken solder of the connector in the keyboard is common. Broken cords on the adapter is common as well.
Oct 29, 2011 | Casio Ctk 496 Electronic Keyboard with 61...
My keyboard keeps shutting off within a minute or two of playing. The woman I purchased it from told me that it had an auto-off battery saving mechanism if you don't touch a key for a while, but this...
If you are running on batteries, they are either depleted OR may have corrosion on the contacts in the keyboard which is COMMON problem. If using an adapter, the cords chronically work loose. A last problem is the switching for using battery or adapter can have poor contacts. If you don't have an adapter, get one and get one SPECIFICALLY for the keyboard... I don't know how many I have had to tell they have the wrong adapter and that is why their unit won't work.
May 15, 2011 | Casio CTK-720 Electronic Keyboard with...
Need power cord for Casio CA-100 Tone Bank Keyboard
You need a 9 volt DC adapter with at least 850ms (0.85 amp) capabilty with the center the minus polarity. A good place to find thes is thrift shops, but DO be careful that the center is the MINUS polarity.
Jan 21, 2011 | Casio Music
Music Logo
1,259 people viewed this question
Top Casio Music Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Tim Brauer
Tim Brauer
Are you a Casio Music Expert? Answer questions, earn points and help others
