Undo the needle/s at the holder screw in needle arm and gently manouver any fabric out of the way ... enough to access the screw holding the needleplate on.....very gently try to loosen & remove the needle, needleplate and fabric in one bunch.........cut threads a few inches from the jam and try to ease the whole jam away from the needles and looper, you can then sort that mess out later........
During all these processes, Do Not pull or force anything as you may bend something or throw the timing out (if it is not already out)
Once all is clear, replace only the R needle at this stage and very slowly rotate the handwheel towards you and watch the motion carefully to ensure that there are no drastic collisions of loopers and needle.
If all appears well, re-thread and do a sample test.
If things are not so rosy, you may contact me via the "contact us" page at
www.bargainbox.com.au and I shall see what can be done for you to reset the timing and clearances.......if you feel up to the challenge.
