Question about Pentair Minimax NT Heater
Pentair Minimax NT heater -- panel doesn't respond.
I have the Pentair Minimax NT heater. When I turn it on, the POWER and PRESSURE SW indicator lights up which is normal. The POOL indicator lights up as well. But when I try to push any button on the panel, nothing responds. Can't turn it off, change the temp, etc... I've recycled the power (both inside the unit and outside) but am stumped. Is there a deep level reset for this unit? Any help would be appreciated! Thanks, Mike.
Posted by Mike Sousa on
  • Mike Sousa May 26, 2012
    Update: I held the POWER OFF button for 10 seconds and it responded. However, now when I hit the POOL button, the temp up/down buttons do not respond... Getting closer!
David Spradling
    Top Expert:
  • Pentair Master
  • 11,347 Answers
If connected to control make sure heat is enabled
Posted on Aug 30, 2017
2 Related Answers
SHANEOK
Pj Kiley
  • 21 Answers
SOURCE: I have a 2003 400K btu Pentair MiniMax NT pool
have you tried the thermister?
Posted on Oct 02, 2009
Testimonial: "THANKS FOR YOUR ADVICE!!! Checking the thermister, I found that one of the white wires had broken....spliced ends together and heater now functions!"
Anonymous
SOURCE: Pentair minimax pool heater (1 year old)
Board problem? Did you fix the problem?
Posted on Oct 19, 2009
Pentair Minimax NT 250k - ERR blinks 3 times
check pressure switch or tubing to it then gas and ignitor
Mar 22, 2012 | Pentair Minimax NT Heater
Only the pressure sw light is on. No other lights come on. Cycled on off switch and circuit breakers, yet still only pressure sw light comes on
The indicator light means your pressure switch is not closing therefore the heater will not fire. It can be as simple as cleaning your filter to clear the error and get the heater running again. If the filter cleaning still doesn't solve the issue then the switch itself has likely failed and needs to be replaced. Jump the lead wires coming to it to verify the switch is bad. If the wires jumped together gets the heater going, replace the switch.
John
Sep 08, 2011 | Pentair Minimax NT Heater
Pentair MiniMax NT pool heater not working
check breaker maybe popped check ignitor
Sep 29, 2017 | Pentair Minimax NT Heater
Pentair Minimax NT 400 heater. fan keeps coming
Sounds like the controller is the problem. This is the circuit board that has the display and controls on it. You can swing that panel open and try tapping on the white plastic cover the controller is under that. This might get the fan relay to release but you will have to replace the controller it will stick again
Jun 06, 2009 | Pentair Minimax NT Heater
My pool heater will not start. The power light is off and the pressure sw is lit.
You must turn on the pump and let water circulate through the pool and the heater before you turn on the heater otherwise you will ruin the heater
Apr 16, 2009 | Pentair Minimax NT Heater
Pentair Minimax NT Heater Logo
437 people viewed this question
Top Pentair Pool & Spa Experts
Bill Jordan
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
