Question about Shop Vac 333-32-08 Blower Vac Wet/Dry Vacuum
SOURCE: Need an owner's manual on line
http://geeksquad.fixya.com/ThreadView.aspx?prdid=19255&thid=658668
Posted by LinJay on Jun 09, 2008
I have lost my owner's manual for my shop vac and need to figure out how to set it up so I can pump out my flooded basement using a garden hose.
Is there anywhere I can find an owner's manual on line??
The model stated on my vac is not what I clicked on your site....my vac states:
Model QPV 10.5
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. I am supplying you with the contact for the Shop Vac Factory Service for owner’s manuals listed below: for the website and the customer service line, but make sure you include the Shop Vac Model # and the Serial # as well. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://shopvac.com/contact.asp Customer Service 570-326-0502 Phone #
Shop-Vac Corporation Customer Service 570-326-7185 Fax #
2323 Reach Road
P.O. Box 3307
Williamsport, PA 17701
Hours are: Monday thru Friday 8:00 am to 5:00 pm (EST)
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jun 09, 2008
SOURCE: shop vac 90L400 stopped working won't start
I had the same problem with the same model. Turned out to be the thermal fuse on the motor housing, between the switch and the windings. Took it apart and replaced the melted solder with 14 guage copper wire. Works fine! No thermal protection but I don't use it for long at a time anyway. Check the switch for continuity, if good then check the thermal fuse for continuity. If good, it's the motor.
Posted on Sep 28, 2009
SOURCE: How do I change my Shop Vac QPV 10.5 from a wet to
you need to go get some bags and srew on the nozel and then put the bag inside the vac it will then act like a dry vac.
Posted on Nov 05, 2009
SOURCE: vacuuming up water with Shop Vac model 84M200
when picking up dry materials use the foam sleeve that slips on and the blue cloth (assuming there all blue) over it, there should be a ring that slides over blue cloth to hold it in place over the foam sleeve, for wet pick up u can use the foam sleeve minus the blue cloth but let it dry out before picking up dry stuff, you can pick up both wet and dry with a cartrige filter that looks simular to a car air filter and it slips over the foam sleeve, but let it dry out after picking up water before picking up dry cause itll just clog it up
Posted on Aug 29, 2010
SOURCE: I can't find the owner's
generally you remove the filter and just use the foam sleeve (if it has one) it should have a float ball in a cage under the filter. this is to keep the water from going into the motor if it gets too full. That is pretty much it. You should have it plugged into a GFCI outlet when using it for wet pick up, also do not pick up flammable or hazardous liquids.
Posted on Jul 23, 2011
Oct 18, 2015 | Shop Vac Vacuums
Jun 07, 2014 | Shop Vac 584-06-00 Canister Wet/Dry Vacuum
Mar 11, 2010 | Vacuums
Jan 23, 2010 | Craftsman 17765 Canister Wet/Dry Vacuum
Nov 04, 2009 | Shop Vac 584-06-00 Canister Wet/Dry Vacuum
Jul 17, 2008 | Kenmore Progressive Bagless Upright with...
Jun 10, 2008 | Shop Vac 584-06-00 Canister Wet/Dry Vacuum
Jun 09, 2008 | Shop Vac 584-06-00 Canister Wet/Dry Vacuum
Nov 05, 2007 | Shop Vac 584-06-00 Canister Wet/Dry Vacuum
1,616 people viewed this question
